<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[出现这种情况怎么办]]></title><description><![CDATA[<p dir="auto">套餐1包含Vscode及其容器插件，开始安装。。<br />
欢迎使用一键安装Vscode,本工具由作者小鱼提供<br />
开始根据系统架构,为你下载对应版本的vscode~<br />
Run CMD Task:[sudo wget <a href="https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb" target="_blank" rel="noopener noreferrer nofollow ugc">https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb</a> -O /tmp/vscode.deb]<br />
--2024-10-19 15:55:00--  <a href="https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb" target="_blank" rel="noopener noreferrer nofollow ugc">https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb</a><br />
正在解析主机 <a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a> (<a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a>)... 119.0.92.108, 119.0.92.68<br />
正在连接 <a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a> (<a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a>)|119.0.92.108|:443... 已连接。<br />
已发出 HTTP 请求，正在等待回应... 200 OK<br />
长度： 99776494 (95M) [application/octet-stream]<br />
正在保存至: ‘/tmp/vscode.deb’</p>
<p dir="auto">/tmp/vscode.deb                           100%[=====================================================================================&gt;]  95.15M  8.80MB/s    用时 12s</p>
<p dir="auto">2024-10-19 15:55:13 (7.94 MB/s) - 已保存 ‘/tmp/vscode.deb’ [99776494/99776494])</p>
<p dir="auto">下载完成,接下来为你安装Vscode~<br />
Run CMD Task:[sudo dpkg -i /tmp/vscode.deb]<br />
[-][8.32s] CMD Result:success</p>
<p dir="auto">Run CMD Task:[rm -rf /tmp/vscode.deb]<br />
[-][0.00s] CMD Result:success</p>
<p dir="auto">安装完成~<br />
Run CMD Task:[code --install-extension ms-vscode-remote.remote-containers --user-data-dir]<br />
Option 'user-data-dir' requires a non empty value. Ignoring the option.<br />
Installing extensions...<br />
Extension 'ms-vscode-remote.remote-containers' v0.388.0 is already installed. Use '--force' option to update to latest version or provide '@&lt;version&gt;' to install a specific version, for example: 'ms-vscode-remote.remote-containers@1.2.3'.<br />
===========================后续使用指令=================================<br />
后续可在任意终端输入melodic1来启动/停止/测试/删除容器<br />
==============================文件存储位置===============================<br />
你的主目录已经和容器的对应目录做了映射<br />
==============================问题反馈&amp;&amp;更新讨论=============================<br />
请访问社区的一键安装版块：<a href="https://fishros.org.cn/forum/topic/112">https://fishros.org.cn/forum/topic/112</a><br />
欢迎加入机器人学习交流QQ群：438144612(入群口令：一键安装)<br />
鱼香小铺正式开业，最低499可入手一台能建图会导航的移动机器人，淘宝搜店：鱼香ROS 或打开链接查看：<a href="https://item.taobao.com/item.htm?id=696573635888" target="_blank" rel="noopener noreferrer nofollow ugc">https://item.taobao.com/item.htm?id=696573635888</a><br />
如在使用过程中遇到问题，请打开：<a href="https://fishros.org.cn/forum">https://fishros.org.cn/forum</a> 进行反馈</p>
<p dir="auto">检测到本次运行出现失败命令,直接退出按Ctrl+C,按任意键上传日志并退出</p>
<ul>
<li>
<ul>
<li>列表</li>
</ul>
</li>
</ul>
]]></description><link>https://fishros.org.cn/forum/topic/3183/出现这种情况怎么办</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 06:49:10 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/3183.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Oct 2024 08:03:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 出现这种情况怎么办 on Sat, 19 Oct 2024 08:21:48 GMT]]></title><description><![CDATA[<p dir="auto">根据您提供的日志信息，问题主要出现在使用 <code>wget</code> 命令下载 Visual Studio Code (VSCode) 的 <code>.deb</code> 文件时，由于域名解析失败导致无法下载。这可能是由于网络连接问题、域名服务器问题或者指定的 URL 已经更改。以下是一些解决步骤和建议：</p>
<ol>
<li>
<p dir="auto"><strong>检查网络连接</strong>：<br />
确保您的设备可以访问互联网，并且网络连接稳定。</p>
</li>
<li>
<p dir="auto"><strong>验证 URL</strong>：<br />
访问 Microsoft 官方网站或使用搜索引擎查找最新的 Visual Studio Code <code>.deb</code> 文件下载链接。可能您使用的 URL 已经过时或不再有效。</p>
</li>
<li>
<p dir="auto"><strong>使用不同的下载工具</strong>：<br />
如果 <code>wget</code> 出现问题，您可以尝试使用其他工具如 <code>curl</code> 或直接在浏览器中下载文件。例如，使用 <code>curl</code> 的命令可能如下：</p>
<pre><code class="language-bash">curl -L -o /tmp/vscode.deb https://&lt;正确的URL&gt;/code_&lt;version&gt;-&lt;build&gt;_amd64.deb
</code></pre>
</li>
<li>
<p dir="auto"><strong>检查 DNS 解析</strong>：<br />
如果您怀疑是 DNS 问题，可以尝试更换 DNS 服务器，例如使用 Google 的公共 DNS（8.8.8.8 和 8.8.4.4）。</p>
</li>
<li>
<p dir="auto"><strong>清除本地缓存</strong>：<br />
有时候，旧的 DNS 缓存或本地缓存可能导致解析问题。您可以尝试清除这些缓存，具体方法取决于您的操作系统。</p>
</li>
<li>
<p dir="auto"><strong>重试下载</strong>：<br />
一旦您有了正确的 URL 和确保网络连接无误，再次尝试下载文件。</p>
</li>
<li>
<p dir="auto"><strong>安装 VSCode</strong>：<br />
在成功下载 <code>.deb</code> 文件后，再次尝试使用 <code>dpkg</code> 安装 VSCode：</p>
<pre><code class="language-bash">sudo dpkg -i /tmp/vscode.deb
</code></pre>
</li>
<li>
<p dir="auto"><strong>安装扩展</strong>：<br />
如果 VSCode 已成功安装，但您遇到扩展安装的问题，确保使用正确的命令格式。如果需要更新或安装特定版本的扩展，可以使用 <code>--force</code> 或指定版本。</p>
</li>
<li>
<p dir="auto"><strong>查看日志和错误</strong>：<br />
如果问题仍然存在，请仔细查看所有输出和错误消息，以获取更多关于问题的线索。</p>
</li>
<li>
<p dir="auto"><strong>社区和支持</strong>：<br />
如果以上步骤都不能解决问题，您可以考虑访问相关的技术社区或论坛（如您提到的 <a href="http://fishros.org.cn" target="_blank" rel="noopener noreferrer nofollow ugc">fishros.org.cn</a>），寻求更具体的帮助。</p>
</li>
</ol>
<p dir="auto">希望这些步骤能帮助您解决问题！如果还有其他问题，欢迎继续提问。</p>
<hr />
<p dir="auto">以上为生成回答，仅供参考～</p>
]]></description><link>https://fishros.org.cn/forum/post/13427</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/13427</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 19 Oct 2024 08:21:48 GMT</pubDate></item><item><title><![CDATA[Reply to 出现这种情况怎么办 on Sat, 19 Oct 2024 08:21:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> Run CMD Task:[sudo wget <a href="https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb" target="_blank" rel="noopener noreferrer nofollow ugc">https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb</a> -O /tmp/vscode.deb]<br />
--2024-10-19 16:18:23--  <a href="https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb" target="_blank" rel="noopener noreferrer nofollow ugc">https://vscode.download.prss.microsoft.com/dbazure/download/stable/903b1e9d8990623e3d7da1df3d33db3e42d80eda/code_1.86.2-1707854558_amd64.deb</a><br />
正在解析主机 <a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a> (<a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a>)... 失败：域名解析出现暂时性错误。<br />
wget: 无法解析主机地址 ‘<a href="http://vscode.download.prss.microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">vscode.download.prss.microsoft.com</a>’<br />
[-][0.06s] CMD Result:code:1</p>
<p dir="auto">检测到本次运行出现失败命令,直接退出按Ctrl+C,按任意键上传日志并退出<br />
重新安装后又出现这种情况，怎么办</p>
]]></description><link>https://fishros.org.cn/forum/post/13426</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/13426</guid><dc:creator><![CDATA[2137896421]]></dc:creator><pubDate>Sat, 19 Oct 2024 08:21:16 GMT</pubDate></item><item><title><![CDATA[Reply to 出现这种情况怎么办 on Sat, 19 Oct 2024 08:08:35 GMT]]></title><description><![CDATA[<p dir="auto">您遇到的问题主要涉及到两个方面：Docker 权限问题和 ROS 环境设置问题。下面我将分别给出解决方案：</p>
<h3>1. Docker 权限问题</h3>
<p dir="auto">错误信息 <code>permission denied while trying to connect to the Docker daemon socket</code> 表明您的用户账户没有足够的权限来访问 Docker 守护进程。这通常是因为 Docker 守护进程默认只允许 root 用户或 docker 用户组的成员访问。</p>
<p dir="auto"><strong>解决方案</strong>：</p>
<ol>
<li>
<p dir="auto"><strong>将您的用户添加到 docker 用户组</strong>：<br />
打开终端，执行以下命令（这里假设您的用户名是 <code>xu</code>）：</p>
<pre><code class="language-bash">sudo usermod -aG docker xu
</code></pre>
<p dir="auto">注意：修改用户组后，您需要重新登录或重启计算机以使更改生效。</p>
</li>
<li>
<p dir="auto"><strong>检查 Docker 服务状态</strong>：<br />
确保 Docker 服务正在运行：</p>
<pre><code class="language-bash">sudo systemctl status docker
</code></pre>
<p dir="auto">如果服务未运行，使用以下命令启动它：</p>
<pre><code class="language-bash">sudo systemctl start docker
</code></pre>
</li>
<li>
<p dir="auto"><strong>重新尝试您的 Docker 命令</strong>：<br />
在重新登录或重启计算机后，尝试再次执行您的 Docker 命令。</p>
</li>
</ol>
<h3>2. ROS 环境设置问题</h3>
<p dir="auto">错误信息 <code>bash: /opt/ros/melodic/setup.bash: 没有那个文件或目录</code> 表明 ROS Melodic 的环境设置脚本不存在于您期望的路径中。</p>
<ol>
<li>
<p dir="auto"><strong>确认 ROS Melodic 是否已正确安装</strong>：<br />
检查 <code>/opt/ros/melodic</code> 目录是否存在。如果不存在，您可能需要重新安装 ROS Melodic。</p>
</li>
<li>
<p dir="auto"><strong>设置 ROS 环境变量</strong>：<br />
如果 ROS 已安装但环境变量未设置，您可以在您的 <code>.bashrc</code> 或 <code>.bash_profile</code> 文件中添加以下行：</p>
<pre><code class="language-bash">source /opt/ros/melodic/setup.bash
</code></pre>
<p dir="auto">然后，重新加载配置文件：</p>
<pre><code class="language-bash">source ~/.bashrc
</code></pre>
<p dir="auto">或者如果您使用的是 <code>.bash_profile</code>，则可能需要重新登录或执行 <code>source ~/.bash_profile</code>。</p>
</li>
<li>
<p dir="auto"><strong>检查 ROS 安装路径</strong>：<br />
如果 ROS 安装在不同的路径下，请相应地修改上述命令中的路径。</p>
</li>
</ol>
<p dir="auto">通过以上步骤，您应该能够解决遇到的 Docker 权限和 ROS 环境设置问题。如果问题仍然存在，请检查您的安装步骤或寻求更具体的帮助。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/13425</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/13425</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 19 Oct 2024 08:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to 出现这种情况怎么办 on Sat, 19 Oct 2024 08:08:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> xu@xu-Redmi-Book-Pro-15-2023:~/桌面$ melodic1<br />
请输入指令控制melodic1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):<br />
t<br />
permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.47/containers/melodic1/json": dial unix /var/run/docker.sock: connect: permission denied<br />
bash: /opt/ros/melodic/setup.bash: 没有那个文件或目录<br />
xu@xu-Redmi-Book-Pro-15-2023:~/桌面$ t<br />
t：未找到命令<br />
t：未找到命令<br />
xu@xu-Redmi-Book-Pro-15-2023:~/桌面$<br />
现在又出现问题了，这种情况又该怎么办</p>
]]></description><link>https://fishros.org.cn/forum/post/13424</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/13424</guid><dc:creator><![CDATA[2137896421]]></dc:creator><pubDate>Sat, 19 Oct 2024 08:08:04 GMT</pubDate></item><item><title><![CDATA[Reply to 出现这种情况怎么办 on Sat, 19 Oct 2024 08:04:16 GMT]]></title><description><![CDATA[<p dir="auto">从您提供的输出信息来看，VSCode 及其 Remote Containers 插件的安装过程已经顺利完成，但在尝试通过 <code>code --install-extension ms-vscode-remote.remote-containers --user-data-dir</code> 命令安装或检查插件时遇到了一个小问题。这个问题是因为 <code>--user-data-dir</code> 选项后面没有提供具体的目录路径，所以被忽略了。不过，这并不影响 Remote Containers 插件的安装，因为插件已经安装过了（根据输出信息）。</p>
<p dir="auto">以下是您可能需要注意的几个点：</p>
<ol>
<li>
<p dir="auto"><strong>插件已安装</strong>：<br />
如输出所示，<code>ms-vscode-remote.remote-containers</code> 插件已经安装并且是最新版本（v0.388.0）。如果您想更新到最新版本或指定版本，可以在命令中添加 <code>--force</code> 或指定版本如 <code>ms-vscode-remote.remote-containers@指定版本号</code>。</p>
</li>
<li>
<p dir="auto"><strong>忽略的 <code>--user-data-dir</code> 选项</strong>：<br />
<code>--user-data-dir</code> 选项用于指定 VSCode 的用户数据目录，通常用于在不同的用户或配置之间隔离 VSCode 设置。如果未提供具体路径，VSCode 将使用默认路径。这通常不会影响插件的安装或 VSCode 的基本功能。</p>
</li>
<li>
<p dir="auto"><strong>后续使用</strong>：<br />
您可以使用 <code>melodic1</code> 指令来管理容器（启动、停止、测试、删除）。请确保您已经正确设置了该指令对应的脚本或别名。</p>
</li>
<li>
<p dir="auto"><strong>文件存储位置</strong>：<br />
您的主目录已经与容器目录映射，这意味着您可以在主目录和容器目录之间共享文件。</p>
</li>
<li>
<p dir="auto"><strong>问题反馈与更新</strong>：<br />
如果遇到问题，可以访问提供的论坛链接进行反馈，或者加入 QQ 群获取更多帮助。</p>
</li>
<li>
<p dir="auto"><strong>日志上传</strong>：<br />
如果系统提示您上传日志，这通常是为了帮助开发者或社区成员更好地理解问题。您可以根据需要选择是否上传。</p>
</li>
</ol>
<p dir="auto">总的来说，您的 VSCode 和 Remote Containers 插件已经安装成功，可以正常使用了。如果遇到其他问题，可以按照提供的联系方式进行反馈或寻求帮助。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/13423</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/13423</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 19 Oct 2024 08:04:16 GMT</pubDate></item></channel></rss>
