<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[虚拟机上ros2 建立pkg失败]]></title><description><![CDATA[<p dir="auto">(base) ros2@gs-ros2:~/test1$ ros2 pkg create --build-type ament_python --license Apache-2.0 demo_python_pkg<br />
Failed to load entry point 'create': No module named 'catkin_pkg.package'<br />
Traceback (most recent call last):<br />
File "/opt/ros/humble/bin/ros2", line 33, in &lt;module&gt;<br />
sys.exit(load_entry_point('ros2cli==0.18.11', 'console_scripts', 'ros2')())<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 52, in main<br />
add_subparsers_on_demand(<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/command/<strong>init</strong>.py", line 250, in add_subparsers_on_demand<br />
extension.add_arguments(<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2pkg/command/pkg.py", line 25, in add_arguments<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/command/<strong>init</strong>.py", line 237, in add_subparsers_on_demand<br />
extension = command_extensions[name]<br />
KeyError: 'create'<br />
退出base环境后<br />
KeyError: 'create'</p>
]]></description><link>https://fishros.org.cn/forum/topic/3660/虚拟机上ros2-建立pkg失败</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 12:12:31 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/3660.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jan 2025 06:49:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Thu, 24 Jul 2025 01:30:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/16680">@3513232534</a> 简短回答：从 <a href="https://github.com/ros-perception/vision_msgs" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ros-perception/vision_msgs</a> 下载后放在workspace/src目录下，然后在workspace中执行<code>colcon build</code>即可。</p>
<p dir="auto">详细回答：你遇到的错误是因为你在 ROS2中使用了已经弃用的 catkin 相关构建工具，这是由于你下载的 vision_msgs 包是 ROS1 的，所以你只需要下载 ROS2 的包即可，而现在（2025-07-24），<a href="https://github.com/ros-perception/vision_msgs" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ros-perception/vision_msgs</a> 中默认分支就是 ROS2 的分支，所以你可以直接下载。</p>
<p dir="auto">关于从 github 下载仓库，有多个方法：git  clone、下载 zip 等。无论哪个方法，通常都需要设置代理（翻墙），否则无法连接，所以你在执行 git clone 时遇到了错误。</p>
<p dir="auto">另外论坛的 AI 小伊其实给出了一些有用的提示，但它的上下文关联较差，思考深度也不够，给了你一些错误的引导，让你越走越远，让人无语，我建议关闭这个AI的自动回复，因为它不并可靠。</p>
]]></description><link>https://fishros.org.cn/forum/post/18731</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/18731</guid><dc:creator><![CDATA[wsxq2]]></dc:creator><pubDate>Thu, 24 Jul 2025 01:30:22 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Tue, 21 Jan 2025 11:42:39 GMT]]></title><description><![CDATA[<p dir="auto">在ROS2 Humble版本中安装<code>vision_msgs</code>通常涉及到添加相应的ROS 2包存储库，并使用包管理器进行安装。以下是一个详细的步骤指南，帮助你安装<code>vision_msgs</code>：</p>
<ol>
<li>
<p dir="auto"><strong>确保系统环境</strong>：</p>
<ul>
<li>操作系统：Ubuntu 22.04（或其他支持ROS 2的Linux发行版）。</li>
<li>确保系统语言环境支持UTF-8。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>更新系统并安装必要的依赖</strong>：</p>
<pre><code class="language-bash">sudo apt update
sudo apt upgrade
sudo apt install -y python3-venv software-properties-common curl gnupg lsb-release
</code></pre>
</li>
<li>
<p dir="auto"><strong>添加ROS 2存储库</strong>：</p>
<p dir="auto">首先，添加ROS 2的GPG密钥：</p>
<pre><code class="language-bash">curl -fsSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
</code></pre>
<p dir="auto">然后，将ROS 2存储库添加到系统的源列表中：</p>
<pre><code class="language-bash">echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/ros2.list &gt;/dev/null
</code></pre>
</li>
<li>
<p dir="auto"><strong>更新apt存储库缓存</strong>：</p>
</code></pre>
</li>
<li>
<p dir="auto"><strong>安装ROS 2 Humble</strong>：</p>
<p dir="auto">你可以选择安装ROS 2的桌面版（包含RViz等工具）或基础版。这里以基础版为例：</p>
<pre><code class="language-bash">sudo apt install ros-humble-ros-base
</code></pre>
</li>
<li>
<p dir="auto"><strong>安装vision_msgs</strong>：</p>
<p dir="auto"><code>vision_msgs</code>通常作为某个ROS 2包的依赖项而被安装。但是，如果你需要单独安装它，可以尝试在ROS 2的包索引中搜索并安装。不过，在ROS 2 Humble中，由于<code>vision_msgs</code>可能已经被包含在某些核心包或元包中，因此你可能不需要单独安装它。</p>
<p dir="auto">如果你确实需要单独安装（例如，因为它没有被自动包含在你安装的ROS 2包中），你可以尝试使用以下命令（但请注意，这可能需要你知道<code>vision_msgs</code>的确切包名和仓库地址）：</p>
<pre><code class="language-bash">sudo apt install ros-humble-&lt;vision_msgs-specific-package&gt;
</code></pre>
<p dir="auto">或者，如果它是一个独立的仓库，你可能需要从源代码构建它：</p>
<pre><code class="language-bash">mkdir -p ~/ros2_ws/src
cd ~/ros2_ws/src
git clone &lt;vision_msgs-repository-url&gt;
cd ~/ros2_ws
colcon build
</code></pre>
<p dir="auto">但是，请注意，上述从源代码构建的步骤通常用于那些不在官方ROS 2存储库中的包。对于官方包，使用<code>apt</code>安装通常是更简单和推荐的方法。然而，由于<code>vision_msgs</code>通常是作为依赖项被安装的，因此你可能需要先安装一个依赖它的包（例如某个视觉处理包）来自动获取<code>vision_msgs</code>。</p>
</li>
<li>
<p dir="auto"><strong>配置环境</strong>：</p>
<p dir="auto">安装完成后，你需要加载ROS 2的环境变量：</p>
<pre><code class="language-bash">echo "source /opt/ros/humble/setup.bash" &gt;&gt; ~/.bashrc
source ~/.bashrc
</code></pre>
</li>
<li>
<p dir="auto"><strong>验证安装</strong>：</p>
<p dir="auto">你可以通过运行一个使用<code>vision_msgs</code>的ROS 2节点来验证它是否已正确安装。例如，如果你有一个使用<code>vision_msgs</code>的视觉处理节点，你可以尝试运行它来检查是否有任何关于缺少<code>vision_msgs</code>的错误。</p>
</li>
</ol>
<p dir="auto">请注意，由于ROS 2的生态系统不断发展和更新，上述步骤可能会随着时间的推移而发生变化。因此，建议始终参考ROS 2的官方文档和社区资源以获取最新和最准确的安装指南。</p>
<hr />
<p dir="auto">以上为生成回答，仅供参考～</p>
]]></description><link>https://fishros.org.cn/forum/post/15834</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15834</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Tue, 21 Jan 2025 11:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Tue, 21 Jan 2025 11:41:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> ros2humble版本里的vision_msgs怎么安装</p>
]]></description><link>https://fishros.org.cn/forum/post/15833</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15833</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Tue, 21 Jan 2025 11:41:36 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Tue, 21 Jan 2025 09:50:04 GMT]]></title><description><![CDATA[<p dir="auto">在您的错误输出中，主要问题是 <code>ModuleNotFoundError: No module named 'catkin_pkg'</code>。这表明在尝试构建 <code>vision_msgs</code> 包时，Python 环境中缺少 <code>catkin_pkg</code> 模块。<code>catkin_pkg</code> 是用于解析和处理 catkin 包 XML 文件的 Python 库，尽管 ROS 2 主要是基于 ament 的构建系统，但在某些情况下（如处理旧代码或兼容性问题），可能仍然需要 <code>catkin_pkg</code>。</p>
<p dir="auto">关于 <code>BUFFERED_OPT</code> 的问题，这通常与 <code>empy</code> 库有关，但您的错误信息中并未直接提及 <code>empy</code>。<code>BUFFERED_OPT</code> 是在较新版本的 <code>empy</code> 中引入的一个选项，用于模板渲染时的输出缓冲。不过，您的当前问题似乎与 <code>empy</code> 无关，而是与缺少 <code>catkin_pkg</code> 模块有关。</p>
<h3>解决步骤：</h3>
<ol>
<li>
<p dir="auto"><strong>安装 <code>catkin_pkg</code></strong>：<br />
由于您使用的是 ROS 2 Humble，通常不需要 <code>catkin_pkg</code>，但如果遇到依赖问题，您可以尝试安装它。在您的 ROS 2 环境中安装 <code>catkin_pkg</code>：</p>
<pre><code class="language-bash">source /opt/ros/humble/setup.bash
rosdep install --from-paths src --ignore-src --rosdistro humble -y
</code></pre>
<p dir="auto">注意：<code>rosdep</code> 可能会尝试安装所有依赖项，但这里主要是确保所有必要的包都被考虑。如果 <code>catkin_pkg</code> 是缺失的依赖之一，它应该会被安装。然而，对于 ROS 2，通常不需要这样做，因为 ROS 2 使用 <code>ament</code> 而不是 <code>catkin</code>。</p>
</li>
<li>
<p dir="auto"><strong>检查 <code>ament_cmake</code> 和相关依赖</strong>：<br />
确保您的 ROS 2 环境设置正确，并且所有相关的构建工具都已正确安装。可以尝试重新安装或更新 <code>ament_cmake</code> 和其他相关包。</p>
</li>
<li>
<p dir="auto"><strong>检查 Python 环境</strong>：<br />
确保您使用的 Python 环境与 ROS 2 兼容。由于您使用的是 Conda 环境 (<code>my_torch</code>)，请确保该环境中安装了所有必要的 ROS 2 依赖项。</p>
</li>
<li>
<p dir="auto"><strong>清理和重建工作空间</strong>：<br />
清理您的工作空间并尝试重新构建：</p>
<pre><code class="language-bash">cd ~/chapt9/chapt9_ws
rm -rf build install log
colcon build
</code></pre>
</li>
<li>
<p dir="auto"><strong>检查 <code>vision_msgs</code> 包</strong>：<br />
如果 <code>vision_msgs</code> 是一个自定义包或来自第三方，请确保它兼容 ROS 2。如果是从 ROS 1 迁移过来的包，可能需要进行一些修改才能与 ROS 2 兼容。</p>
</li>
</ol>
<p dir="auto">如果上述步骤仍然无法解决问题，您可能需要更详细地检查 <code>vision_msgs</code> 包的 <code>CMakeLists.txt</code> 和 <code>package.xml</code> 文件，以确保它们是为 ROS 2 正确配置的。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15831</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15831</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Tue, 21 Jan 2025 09:50:04 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Tue, 21 Jan 2025 09:49:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15829">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
<p dir="auto">BUFFERED_OPT 应该在哪个版本的 empy 中可用</p>
</blockquote>
<p dir="auto">my_torch) (base) ros2<a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/20355">@ros2</a>:~/chapt9/chapt9_ws$ colcon build<br />
Starting &gt;&gt;&gt; vision_msgs<br />
--- stderr: vision_msgs<br />
File "/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 22, in &lt;module&gt;<br />
from catkin_pkg.package import parse_package_string<br />
ModuleNotFoundError: No module named 'catkin_pkg'<br />
CMake Error at /opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:95 (message):<br />
execute_process(/home/ros2/miniconda3/envs/my_torch/bin/python3<br />
/opt/ros/humble/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py<br />
/home/ros2/chapt9/chapt9_ws/src/vision_msgs/vision_msgs/package.xml<br />
/home/ros2/chapt9/chapt9_ws/build/vision_msgs/ament_cmake_core/package.cmake)<br />
returned error code 1<br />
Call Stack (most recent call first):<br />
/opt/ros/humble/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:49 (_ament_package_xml)<br />
/opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:226 (ament_package_xml)<br />
CMakeLists.txt:37 (rosidl_generate_interfaces)</p>
<hr />
<p dir="auto">Failed   &lt;&lt;&lt; vision_msgs [0.45s, exited with code 1]</p>
<p dir="auto">Summary: 0 packages finished [0.67s]<br />
1 package failed: vision_msgs<br />
1 package had stderr output: vision_msgs<br />
2 packages not processed</p>
]]></description><link>https://fishros.org.cn/forum/post/15830</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15830</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Tue, 21 Jan 2025 09:49:29 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Tue, 21 Jan 2025 09:35:38 GMT]]></title><description><![CDATA[<p dir="auto">这个错误发生在尝试构建 <code>vision_msgs</code> 包时，涉及到 <code>rosidl_adapter</code>，这是 ROS 2 中用于接口生成的一部分。错误信息显示，在处理模板 <code>msg.idl.em</code> 时遇到了 <code>AttributeError</code>，这表明 Python 环境中存在问题，特别是与 <code>em</code> (可能是指 <code>empy</code>，一个用于模板处理的库) 相关的问题。</p>
<p dir="auto">以下是一些可能的解决步骤：</p>
<ol>
<li>
<p dir="auto"><strong>确认 <code>empy</code> 库的版本</strong>：<br />
<code>empy</code> 库是处理模板的依赖，错误表明 <code>em</code> 模块没有 <code>BUFFERED_OPT</code> 属性。这可能是因为 <code>empy</code> 的版本不兼容。尝试更新或重新安装 <code>empy</code> 库。</p>
<pre><code class="language-bash">pip install --upgrade empy
</code></pre>
<p dir="auto">如果你在使用 Conda 环境，可以尝试：</p>
<pre><code class="language-bash">conda install -c conda-forge empy
</code></pre>
<p dir="auto">或者，如果你已经安装了 <code>empy</code>，尝试更新到最新版本或检查是否有特定版本的要求。</p>
</li>
<li>
确保你的 Python 环境（在这种情况下是 Conda 环境 <code>my_torch</code>）配置正确，并且所有相关的 ROS 2 和其他依赖都已正确安装。</p>
</li>
<li>
<p dir="auto"><strong>清理构建目录</strong>：<br />
有时候，旧的构建文件可能会导致问题。尝试删除构建目录和安装目录，然后重新构建。</p>
<pre><code class="language-bash">rm -rf chapt9_ws/build chapt9_ws/install
colcon build
</code></pre>
</li>
<li>
<p dir="auto"><strong>检查 ROS 2 安装</strong>：<br />
确保你的 ROS 2 安装没有损坏。可以尝试重新安装 ROS 2 或至少重新安装相关的 ROS 2 包。</p>
</li>
<li>
<p dir="auto"><strong>查看 <code>vision_msgs</code> 的 CMakeLists.txt</strong>：<br />
检查 <code>vision_msgs</code> 包的 <code>CMakeLists.txt</code> 文件，确保 <code>rosidl_generate_interfaces</code> 调用正确无误，并且所有需要的依赖都已正确声明。</p>
</li>
<li>
<p dir="auto"><strong>搜索类似问题</strong>：<br />
在网上搜索错误消息，看看是否有其他人遇到过类似问题，并找到了解决方案。</p>
</li>
</ol>
<p dir="auto">如果上述步骤都不能解决问题，可能需要更深入地检查 <code>rosidl_adapter</code> 和相关工具的源代码，看看 <code>BUFFERED_OPT</code> 应该在哪个版本的 <code>empy</code> 中可用，或者是否有其他配置错误。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15829</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15829</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Tue, 21 Jan 2025 09:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Tue, 21 Jan 2025 09:35:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> (my_torch) (base) ros2<a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/20355">@ros2</a>:~/chapt9/chapt9_ws$ colcon build<br />
CMake Error at /opt/ros/humble/share/rosidl_adapter/cmake/rosidl_adapt_interfaces.cmake:59 (message):<br />
execute_process(/home/ros2/miniconda3/envs/my_torch/bin/python3 -m<br />
rosidl_adapter --package-name vision_msgs --arguments-file<br />
/home/ros2/chapt9/chapt9_ws/build/vision_msgs/rosidl_adapter__arguments__vision_msgs.json<br />
--output-dir<br />
/home/ros2/chapt9/chapt9_ws/build/vision_msgs/rosidl_adapter/vision_msgs<br />
--output-file<br />
/home/ros2/chapt9/chapt9_ws/build/vision_msgs/rosidl_adapter/vision_msgs.idls)<br />
returned error code 1:</p>
<p dir="auto">AttributeError processing template 'msg.idl.em'</p>
<p dir="auto">Traceback (most recent call last):</p>
<pre><code>File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 51, in evaluate_template
  em.BUFFERED_OPT: True,
</code></pre>
<p dir="auto">AttributeError: module 'em' has no attribute 'BUFFERED_OPT'</p>
<p dir="auto">During handling of the above exception, another exception occurred:</p>
<pre><code>File "/home/ros2/miniconda3/envs/my_torch/lib/python3.10/runpy.py", line 196, in _run_module_as_main
  return _run_code(code, main_globals, None,
File "/home/ros2/miniconda3/envs/my_torch/lib/python3.10/runpy.py", line 86, in _run_code
  exec(code, run_globals)
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__main__.py", line 19, in &lt;module&gt;
  sys.exit(main())
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/main.py", line 53, in main
  abs_idl_file = convert_to_idl(
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 19, in convert_to_idl
  return convert_msg_to_idl(
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/msg/__init__.py", line 39, in convert_msg_to_idl
  expand_template('msg.idl.em', data, output_file, encoding='iso-8859-1')
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 23, in expand_template
  content = evaluate_template(template_name, data)
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 69, in evaluate_template
  _interpreter.shutdown()
</code></pre>
<p dir="auto">AttributeError: 'NoneType' object has no attribute 'shutdown'</p>
<p dir="auto">Call Stack (most recent call first):<br />
/opt/ros/humble/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:130 (rosidl_adapt_interfaces)<br />
<hr />
<p dir="auto">Failed   &lt;&lt;&lt; vision_msgs [1.17s, exited with code 1]<br />
这个报错应该怎么处理</p>
]]></description><link>https://fishros.org.cn/forum/post/15828</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15828</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Tue, 21 Jan 2025 09:35:05 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 16:21:13 GMT]]></title><description><![CDATA[<p dir="auto">在 ROS 2 (Robot Operating System 2) 中，没有直接提供显示文件结构图的命令，但你可以使用其他工具或命令来实现这一功能。对于你提供的文件结构，可以使用 <code>tree</code> 命令（如果已安装）来显示目录结构。以下是如何在 Linux 或 macOS 系统上安装和使用 <code>tree</code> 命令的步骤：</p>
<h3>在 Linux 上</h3>
<ol>
<li>
<p dir="auto"><strong>安装 <code>tree</code> 命令</strong>（如果未安装）：<br />
在大多数 Linux 发行版上，你可以使用包管理器来安装 <code>tree</code>。例如，在基于 Debian 的系统（如 Ubuntu）上，你可以使用以下命令：</p>
<pre><code class="language-bash">sudo apt-get update
sudo apt-get install tree
</code></pre>
<p dir="auto">在基于 Red Hat 的系统（如 Fedora 或 CentOS）上，你可以使用：</p>
<pre><code class="language-bash">sudo dnf install tree  # Fedora 22+ 或 CentOS 8+
sudo yum install tree  # 较旧的版本
</code></pre>
</li>
<li>
<p dir="auto"><strong>使用 <code>tree</code> 命令显示文件结构</strong>：<br />
在你的 ROS 2 工作空间（或任何你希望查看的目录）中运行以下命令：</p>
<pre><code class="language-bash">tree
</code></pre>
<p dir="auto">这将显示当前目录及其子目录的结构。</p>
</li>
</ol>
<h3>在 macOS 上</h3>
<ol>
<li>
macOS 通常不自带 <code>tree</code> 命令，但你可以通过 Homebrew 来安装它。首先，如果你还没有安装 Homebrew，可以从 <a href="https://brew.sh/" target="_blank" rel="noopener noreferrer nofollow ugc">Homebrew 官网</a> 获取安装命令。</p>
<p dir="auto">安装 Homebrew 后，运行以下命令来安装 <code>tree</code>：</p>
<pre><code class="language-bash">brew install tree
</code></pre>
</li>
<li>
与 Linux 类似，在你的 ROS 2 工作空间目录中运行：</p>
</code></pre>
</li>
</ol>
<h3>示例输出</h3>
<p dir="auto">对于你提供的目录结构，<code>tree</code> 命令的输出可能类似于：</p>
<pre><code>.
├── models
│   └── experimental.py
├── utils
│   ├── general.py
│   └── torch_utils.py
└── your_script.py
3 directories, 4 files
</code></pre>
<h3>注意事项</h3>
<ul>
<li>如果你在 Windows 上工作，你可以使用 PowerShell 或 Windows Subsystem for Linux (WSL) 来运行 <code>tree</code> 命令，或者寻找类似的工具，如 <code>TreeSize Free</code> 或 <code>Directory Print</code>。</li>
<li>如果你只是想在 ROS 2 环境中快速查看文件结构，而不关心具体的命令，你也可以使用文件管理器（如 Nautilus 在 GNOME 中，Dolphin 在 KDE 中）来浏览目录结构。</li>
</ul>
<p dir="auto">希望这能帮助你更好地管理和查看你的 ROS 2 项目结构！</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15760</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15760</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 16:21:13 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 16:20:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15758">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
<p dir="auto">project/<br />
├── models/<br />
│   └── <a href="http://experimental.py" target="_blank" rel="noopener noreferrer nofollow ugc">experimental.py</a><br />
├── utils/<br />
│   ├── <a href="http://general.py" target="_blank" rel="noopener noreferrer nofollow ugc">general.py</a><br />
│   └── torch_utils.py<br />
└── your_script.py</p>
</blockquote>
<p dir="auto">ros2什么指令能显示出这样结构图</p>
]]></description><link>https://fishros.org.cn/forum/post/15759</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15759</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 16:20:39 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 16:05:32 GMT]]></title><description><![CDATA[<p dir="auto">当你遇到“无法解析导入”（Unresolved import）的问题时，这通常意味着Python解释器无法在指定的路径中找到这些模块。这种情况在使用第三方库或自定义项目结构时尤为常见。针对你提到的<code>models.experimental</code>, <code>utils.general</code>, 和 <code>utils.torch_utils</code>，这些模块很可能是来自某个特定的项目或库，如YOLOv5（一个流行的目标检测模型）。下面是一些解决步骤：</p>
<ol>
<li>
<p dir="auto"><strong>确认项目依赖</strong>：<br />
确保你已经正确安装了所有必要的依赖。如果这是一个第三方库（如YOLOv5），你需要按照该库的安装指南来安装。对于YOLOv5，通常可以通过Git克隆仓库并安装依赖来开始：</p>
<pre><code class="language-bash">git clone https://github.com/ultralytics/yolov5.git
cd yolov5
pip install -r requirements.txt
</code></pre>
</li>
<li>
<p dir="auto"><strong>检查PYTHONPATH</strong>：<br />
确保Python解释器知道在哪里查找这些模块。你可以通过设置<code>PYTHONPATH</code>环境变量来包含这些模块的路径。例如，如果你的项目结构是这样的：</p>
<pre><code>project/
├── models/
├── utils/
│   ├── general.py
└── your_script.py
</code></pre>
<p dir="auto">你需要将<code>project/</code>目录添加到<code>PYTHONPATH</code>中。在Linux或macOS上，你可以这样做：</p>
<pre><code class="language-bash">export PYTHONPATH="${PYTHONPATH}:/path/to/project"
</code></pre>
<p dir="auto">在Windows上，你可以：</p>
<pre><code class="language-cmd">set PYTHONPATH=%PYTHONPATH%;C:\path\to\project
</code></pre>
<p dir="auto">或者在你的IDE（如PyCharm）中设置项目根目录作为源根。</p>
</li>
<li>
<p dir="auto"><strong>使用正确的导入语句</strong>：<br />
确保你的导入语句与项目结构相匹配。如果你已经正确设置了<code>PYTHONPATH</code>，你的导入语句看起来应该是正确的。但是，如果项目结构有所变动（例如，使用了包管理器或改变了目录结构），你可能需要调整这些导入语句。</p>
</li>
<li>
<p dir="auto"><strong>检查是否有初始化文件</strong>：<br />
确保在<code>models/</code>和<code>utils/</code>目录下存在<code>__init__.py</code>文件，这会使Python将这些目录视为Python包。这些文件可以是空的，但它们必须存在。</p>
</li>
<li>
<p dir="auto"><strong>IDE特定的设置</strong>：<br />
如果你使用的是IDE（如PyCharm, VSCode等），确保IDE正确设置了项目的根目录和Python解释器。有时候，IDE可能没有正确更新其内部索引，你可能需要重启IDE或手动触发索引更新。</p>
</li>
<li>
<p dir="auto"><strong>虚拟环境问题</strong>：<br />
如果你在使用虚拟环境，确保你正在使用的虚拟环境已经安装了所有必要的依赖，并且该虚拟环境是当前激活的。</p>
</li>
</ol>
<p dir="auto">按照这些步骤操作后，通常可以解决大部分导入错误的问题。如果问题仍然存在，请检查是否有打字错误或路径错误，并确认你遵循的是正确的安装和配置指南。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15758</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15758</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 16:05:32 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 16:04:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> from models.experimental import attempt_load<br />
from utils.general import non_max_suppression, scale_coords<br />
from utils.torch_utils import select_device这三行代码都显示无法解析导入models.experimenta，utils.general，utils.torch_utils应该怎么解决</p>
]]></description><link>https://fishros.org.cn/forum/post/15757</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15757</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 16:04:55 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 16:00:12 GMT]]></title><description><![CDATA[<p dir="auto">在你提供的这行代码中，出现了变量 <code>x</code>, <code>y</code>, <code>w</code>, <code>h</code> 未定义的错误，这通常是因为在解包操作 <code>*xyxy, c, label</code> 中，<code>xyxy</code> 的结构不符合预期，或者 <code>pred</code> 中的元素结构不正确。为了解决这个问题，我们需要确保几个关键点：</p>
<ol>
<li>
<p dir="auto"><strong>确认 <code>pred</code> 的结构</strong>：<code>pred</code> 应该是一个列表或可迭代对象，其中每个元素都包含至少 6 个部分：前 4 个部分代表边界框的坐标（通常是 x, y, w, h），第 5 个部分是置信度 <code>c</code>，第 6 个部分是标签 <code>label</code>。</p>
</li>
<li>
<p dir="auto"><strong>解包操作</strong>：<code>*xyxy, c, label</code> 这部分代码尝试将每个元素的前 4 个值解包到 <code>xyxy</code> 列表（然后分别代表 x, y, w, h），第 5 个值到 <code>c</code>，第 6 个值到 <code>label</code>。这里 <code>xyxy</code> 是一个列表，你需要进一步从它中提取 <code>x</code>, <code>y</code>, <code>w</code>, <code>h</code>。</p>
</li>
<li>
<p dir="auto"><strong>修改代码</strong>：由于 <code>xyxy</code> 是一个列表，你可以通过索引来访问这些值。这里是如何修改你的代码：</p>
</li>
</ol>
<pre><code class="language-python">result_msg = ' '.join([f' {xyxy[0]} {xyxy[1]} {xyxy[2]} {xyxy[3]} {c} {label}' for *xyxy, c, label in pred if det is not None and len(det)])
</code></pre>
<p dir="auto">但是，更清晰的写法可能是直接解包到具体的变量，而不是先到一个列表 <code>xyxy</code> 中：</p>
<pre><code class="language-python">result_msg = ' '.join([f' {x} {y} {w} {h} {c} {label}' for x, y, w, h, c, label in pred if det is not None and len(det)])
</code></pre>
<p dir="auto">注意这里直接使用了 <code>x, y, w, h, c, label</code> 进行解包，这是假设 <code>pred</code> 中的每个元素都是一个包含这六个值的可迭代对象。</p>
<ol start="4">
<li><strong>检查 <code>det</code> 的使用</strong>：在你的代码中，<code>if det is not None and len(det)</code> 这个条件判断可能也会影响代码的执行。确保 <code>det</code> 在这个上下文中是定义过的，并且这个条件是你想要的逻辑。如果 <code>det</code> 与 <code>pred</code> 无关，可能这个条件判断是多余的或者需要调整。</li>
</ol>
<p dir="auto">确保以上所有点都符合你的数据结构和逻辑需求，这样代码应该就不会再报 <code>x, y, w, h</code> 未定义的错误了。如果 <code>pred</code> 的结构或 <code>det</code> 的使用与预期不符，你需要根据实际情况调整代码。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15756</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15756</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 16:00:12 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:59:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> result_msg = ' '.join([f' {x} {y} {w} {h} {c} {label}' for *xyxy, c, label in pred if det is not None and len(det)])这行代码显示x,y,w,h未定义怎么办</p>
]]></description><link>https://fishros.org.cn/forum/post/15755</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15755</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:59:35 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:39:56 GMT]]></title><description><![CDATA[<p dir="auto">在 ROS 2 中创建一个节点来调用 YOLOv5 进行视觉识别，并将识别信息传递给 STM32 涉及多个步骤。以下是一个简化的流程，包括创建 ROS 2 包、编写节点、集成 YOLOv5，以及通过 ROS 2 发布信息。假设你已经配置好了 ROS 2 和 YOLOv5 环境，并且你的 D455 相机已经正确连接到虚拟机。</p>
<h3>步骤 1: 创建 ROS 2 包</h3>
<p dir="auto">首先，创建一个新的 ROS 2 包：</p>
<pre><code class="language-bash">source /opt/ros/foxy/setup.bash  # 或者你使用的 ROS 2 版本
ros2 pkg create --build-type ament_cmake my_yolov5_pkg
cd my_yolov5_pkg
</code></pre>
<h3>步骤 2: 添加依赖</h3>
<p dir="auto">在 <code>package.xml</code> 中添加必要的依赖，例如 <code>python3-pydantic</code>（YOLOv5 依赖）和 <code>rclcpp</code>（ROS 2 C++ 客户端库，如果你使用 Python 则为 <code>rclpy</code>）：</p>
<pre><code class="language-xml">&lt;build_depend&gt;rclcpp&lt;/build_depend&gt;
&lt;exec_depend&gt;rclcpp&lt;/exec_depend&gt;
&lt;build_depend&gt;python3-pydantic&lt;/build_depend&gt;
&lt;exec_depend&gt;python3-std-srvs&lt;/exec_depend&gt;  # 如果需要标准服务
&lt;build_tool_depend&gt;ament_cmake&lt;/build_tool_depend&gt;
&lt;buildtool_depend&gt;python_cmake_module&lt;/buildtool_depend&gt;
</code></pre>
<p dir="auto">注意：YOLOv5 的依赖可能更复杂，这里仅列出了一些基本的。</p>
<h3>步骤 3: 编写 ROS 2 节点</h3>
<p dir="auto">创建一个新的 Python 脚本，例如 <code>yolov5_node.py</code>，并编写以下代码：</p>
<pre><code class="language-python">import rclpy
from rclpy.node import Node
from std_msgs.msg import String
import cv2
import torch
class YOLOv5Node(Node):
    def __init__(self):
        super().__init__('yolov5_node')
        self.publisher_ = self.create_publisher(String, 'detection_result', 10)
        self.timer = self.create_timer(1.0, self.timer_callback)
        # Load YOLOv5 model
        self.device = select_device('')  # 选择设备（CPU 或 GPU）
        self.model = attempt_load('path/to/your/yolov5s.pt', map_location=self.device)  # 加载模型
        self.model.eval()
        # Initialize camera
        self.cap = cv2.VideoCapture(0)  # 使用 D455 相机，这里假设为设备 0
    def timer_callback(self):
        ret, frame = self.cap.read()
        if not ret:
            self.get_logger().warning('Failed to grab frame')
            return
        # Preprocess image
        img = frame[:, :, ::-1].transpose((2, 0, 1))  # BGR to RGB, to 3x416x416
        img = img / 255.0
        img = torch.from_numpy(img).float().unsqueeze(0).to(self.device)
        # Inference
        with torch.no_grad():
            pred = self.model(img, augment=False)[0]
            pred = non_max_suppression(pred, 0.25, 0.45, classes=None, agnostic=False)[0]
            for i, det in enumerate(pred):  # detections per image
                if det is not None and len(det):
                    # 处理检测结果
                    det[:, :4] = scale_coords(img.shape[2:], det[:, :4], frame.shape).round()
                    for *xyxy, conf, cls in det:
                        label = f'{self.model.module.names[int(cls)]} {conf:.2f}'
                        # 在这里可以绘制边界框或进行其他处理
                        # cv2.rectangle(frame, (int(xyxy[0]), int(xyxy[1])), (int(xyxy[2]), int(xyxy[3])), (0, 255, 0), 2)
                        # cv2.putText(frame, label, (int(xyxy[0]), int(xyxy[1]) - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
        # 发布检测结果（这里简单地将结果转换为字符串）
        result_msg = ' '.join([f'{x} {y} {w} {h} {c} {label}' for *xyxy, c, label in pred if det is not None and len(det)])
        self.publisher_.publish(String(data=result_msg))
        # 显示图像（可选）
        # cv2.imshow('frame', frame)
        # if cv2.waitKey(1) &amp; 0xFF == ord('q'):
        #     cv2.destroyAllWindows()
    def __del__(self):
        self.cap.release()
def main(args=None):
    rclpy.init(args=args)
    node = YOLOv5Node()
    rclpy.spin(node)
    node.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
</code></pre>
<h3>步骤 4: 配置 CMakeLists.txt（如果使用 C++）</h3>
<p dir="auto">由于我们使用的是 Python，这个步骤可以跳过。但如果你打算用 C++，你需要在 <code>CMakeLists.txt</code> 中添加 Python 脚本的编译和安装指令。</p>
<h3>步骤 5: 构建和运行节点</h3>
<p dir="auto">确保你的工作空间已经设置，然后构建并运行节点：</p>
<pre><code class="language-bash">cd ~/ros2_ws
colcon build --packages-select my_yolov5_pkg
source install/setup.bash
ros2 run my_yolov5_pkg yolov5_node.py
</code></pre>
<h3>步骤 6: STM32 集成</h3>
<p dir="auto">要在 STM32 上处理 ROS 2 发布的消息，你可以使用 ROS 2 的微控制器客户端库（例如 ROS 2 for Arduino 或直接使用 ROS 2 的 C++ 客户端库，如果 STM32 支持）。这通常涉及串口通信或使用 Wi-Fi/以太网模块。</p>
<p dir="auto">由于 STM32 的集成相对复杂，并且依赖于具体的硬件和固件设置，这里无法提供详细的代码。但基本思路是：</p>
<ol>
<li>在 STM32 上编写代码来订阅 ROS 2 主题（例如，使用 ROS 2 的微控制器客户端库）。</li>
<li>当接收到检测消息时，解析消息并根据需要控制 LED。</li>
</ol>
<p dir="auto">你可能需要查阅 STM32 和 ROS 2 微控制器客户端库的文档，以获取更具体的实现细节。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15754</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15754</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:39:56 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:38:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15742">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
<p dir="auto">步骤 4: 编写 ROS 2 节点<br />
现在，你可以开始编写一个 ROS 2 节点，该节点将调用 YOLOv5 的 Python 代码。你可以创建一个新的 Python 脚本，在这个脚本中导入 YOLOv5 并执行必要的操作。确保你的节点正确地发布和订阅 ROS 2 主题或服务，以便与 ROS 2 生态系统集成。</p>
</blockquote>
<p dir="auto">写一下这一步的完整代码，d455通过yolov5进行视觉识别，ros2获取识别的信息并且传递给stm32，使stm32点灯</p>
]]></description><link>https://fishros.org.cn/forum/post/15753</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15753</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:38:34 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:27:23 GMT]]></title><description><![CDATA[<p dir="auto">在 ROS 2 中编写一个调用 YOLOv5 的 Python 节点涉及几个步骤。首先，你需要确保你的 ROS 2 工作空间已经设置好，并且你已经安装了 YOLOv5。此外，你的虚拟机需要配置好 Python 环境和所有必要的依赖项。</p>
<p dir="auto">以下是一个简化的步骤和代码示例，展示了如何在 ROS 2 中创建一个节点来调用 YOLOv5 的 Python 代码，并发布检测结果。</p>
<p dir="auto">假设你已经有一个 ROS 2 工作空间，现在你需要创建一个新的包：</p>
<pre><code class="language-bash">source /opt/ros/&lt;ros2-distro&gt;/setup.bash
ros2 pkg create --build-type ament_python my_yolov5_pkg
</code></pre>
<p dir="auto">将 <code>&lt;ros2-distro&gt;</code> 替换为你使用的 ROS 2 发行版，如 <code>foxy</code> 或 <code>galactic</code>。</p>
<h3>步骤 2: 安装 YOLOv5</h3>
<p dir="auto">在你的虚拟机中，确保你已经安装了 YOLOv5。你可以通过克隆 YOLOv5 的 GitHub 仓库来完成这一步：</p>
<pre><code class="language-bash">cd ~/ws/src
cd yolov5
</code></pre>
<p dir="auto">在 <code>my_yolov5_pkg/my_yolov5_pkg</code> 目录下创建一个新的 Python 脚本，例如 <code>yolov5_node.py</code>。这个脚本将导入 YOLOv5 并处理图像，同时发布 ROS 2 消息。</p>
<pre><code class="language-python"># my_yolov5_pkg/my_yolov5_pkg/yolov5_node.py
import rclpy
from cv_bridge import CvBridge, CvBridgeError
import cv2
import numpy as np
import torch
import os
# 确保 YOLOv5 的路径正确
os.chdir('/home/your_user/ws/src/yolov5')
import models.experimental as experimental
    def __init__(self):
        self.publisher_ = self.create_publisher(String, 'detections', 10)
        self.bridge = CvBridge()
        self.model = experimental.attempt_load('yolov5s.pt', map_location=select_device(''))
        # 假设你有一个图像话题来订阅图像
        # 这里我们仅作为示例，不实际订阅，而是加载一个静态图像
        img_path = '/path/to/your/image.jpg'  # 替换为你的图像路径
        img0 = cv2.imread(img_path)  # BGR
        img = img0.copy()
        # YOLOv5 推理
        results = self.run_yolov5(img)
        detection_msg = self.create_detection_message(results, img.shape[:2])
        self.publisher_.publish(detection_msg)
        self.get_logger().info('YOLOv5 Node has published detections.')
    def run_yolov5(self, img):
        img = img.transpose((2, 0, 1))[::-1]  # BGR to RGB, to 3x416x416
        img = np.ascontiguousarray(img)
        img = torch.from_numpy(img).to(self.device).float()
        img /= 255.0  # 0-1
        if img.ndimension() == 3:
            img = img.unsqueeze(0)
        # 推理
        pred = pred.cpu().numpy()
        # 处理检测结果
        for *xyxy, conf, cls in pred:
            plot_one_box(xyxy, img0, label=label, color=colors[int(cls)], line_thickness=2)
        return pred
    def create_detection_message(self, detections, img_shape):
        # 这里简单地将检测结果转换为字符串，实际应用中可能需要更复杂的数据结构
        detections_str = f"Detections on {img_shape[0]}x{img_shape[1]} image:\n"
        for *xyxy, conf, cls in detections:
            detections_str += f"Class: {self.model.module.names[int(cls)]}, Confidence: {conf:.2f}, Box: {xyxy}\n"
        return String(data=detections_str)
    yolov5_node = YOLOv5Node()
    rclpy.spin(yolov5_node)
    yolov5_node.destroy_node()
    rclpy.shutdown()
</code></pre>
<p dir="auto"><strong>注意</strong>：</p>
<ol>
<li>上面的代码仅作为示例，未包含所有必要的错误处理和优化。</li>
<li><code>plot_one_box</code> 函数未在代码中定义，你需要从 YOLOv5 的 <code>utils/general.py</code> 中导入或自行实现绘图功能（这里我们仅为了展示检测结果字符串）。</li>
<li>实际应用中，你可能需要从 ROS 2 话题中订阅图像，而不是加载静态图像。</li>
<li>发布检测结果时，你可能希望使用更复杂的消息类型，如 <code>sensor_msgs/Image</code> 或自定义消息类型，以包含边界框坐标、类别和置信度等信息。</li>
</ol>
<h3>步骤 4: 构建并运行节点</h3>
<p dir="auto">确保你的 <code>setup.py</code> 文件中包含了必要的依赖项，并构建你的包：</p>
</code></pre>
<p dir="auto">然后，你可以运行你的节点：</p>
<pre><code class="language-bash">source install/setup.bash
</code></pre>
<p dir="auto">这将启动你的 ROS 2 节点，该节点将使用 YOLOv5 处理图像并发布检测结果。请根据你的实际需求调整代码和依赖项。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15752</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15752</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:27:23 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:25:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15742">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
</blockquote>
<p dir="auto">这一步的完整代码写一下</p>
]]></description><link>https://fishros.org.cn/forum/post/15751</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15751</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:20:06 GMT]]></title><description><![CDATA[<p dir="auto">在虚拟机上为ROS 2建立功能包（pkg）并集成YOLOv5时，确实需要在<code>setup.py</code>文件中处理YOLOv5的依赖项。以下是将YOLOv5依赖项集成到ROS 2功能包中的详细步骤：</p>
<h3>一、准备YOLOv5依赖项</h3>
<ol>
<li>
<p dir="auto"><strong>下载YOLOv5代码</strong>：</p>
<ul>
<li>从YOLOv5的官方GitHub仓库下载代码。通常，这可以通过克隆仓库来完成，例如：<code>git clone https://github.com/ultralytics/yolov5.git</code>。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>查看YOLOv5的依赖项</strong>：</p>
<ul>
<li>在YOLOv5的代码仓库中，会有一个<code>requirements.txt</code>文件，该文件列出了运行YOLOv5所需的所有Python依赖项。</li>
</ul>
</li>
</ol>
<h3>二、在ROS 2功能包中处理依赖项</h3>
<ol>
<li>
<p dir="auto"><strong>创建ROS 2功能包</strong>：</p>
<ul>
<li>如果还没有创建ROS 2功能包，需要先按照ROS 2的文档创建一个新的功能包。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>编辑<code>setup.py</code>文件</strong>：</p>
<ul>
<li>打开ROS 2功能包中的<code>setup.py</code>文件。</li>
<li>在<code>install_requires</code>列表中，可以添加YOLOv5的直接依赖项。但是，由于YOLOv5可能有多个依赖项，且这些依赖项之间可能存在版本冲突，因此更推荐的方法是使用一个单独的<code>requirements.txt</code>文件。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>使用单独的<code>requirements.txt</code>文件</strong>：</p>
<ul>
<li>在ROS 2工作空间的根目录下（例如，与<code>src</code>目录平级的位置），创建一个名为<code>requirements.txt</code>的文件。</li>
<li>将YOLOv5的<code>requirements.txt</code>文件中的所有依赖项复制到这个新文件中。注意保持依赖项列表的格式不变。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>在工作空间中安装依赖项</strong>：</p>
<ul>
<li>使用<code>pip</code>安装工作空间中的依赖项。在ROS 2工作空间的根目录下，运行以下命令：<code>pip install -r requirements.txt</code>。确保使用的是与ROS 2环境兼容的Python解释器。</li>
</ul>
</li>
</ol>
<h3>三、编译和运行ROS 2功能包</h3>
<ol>
<li>
<p dir="auto"><strong>编译ROS 2功能包</strong>：</p>
<ul>
<li>返回到ROS 2工作空间的根目录，并运行<code>colcon build</code>命令来编译功能包。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>设置环境变量</strong>：</p>
<ul>
<li>编译完成后，运行<code>source install/setup.bash</code>命令来设置环境变量，以便ROS 2能够找到新编译的包。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>运行ROS 2节点</strong>：</p>
<ul>
<li>现在，可以尝试运行ROS 2功能包中的节点，并验证YOLOv5是否已正确集成。</li>
</ul>
</li>
</ol>
<h3>四、注意事项</h3>
<ul>
<li>确保虚拟机上的Python版本与ROS 2和YOLOv5兼容。</li>
<li>如果在虚拟机上遇到权限问题，请确保以适当的用户身份运行命令，或者使用<code>sudo</code>（但通常不建议在Python环境设置中使用<code>sudo</code>）。</li>
<li>如果在编译或运行时遇到依赖项相关的错误，请检查<code>requirements.txt</code>文件是否正确，并确保所有依赖项都已正确安装。</li>
</ul>
<p dir="auto">通过上述步骤，您应该能够在虚拟机上为ROS 2成功建立并集成YOLOv5的功能包。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15750</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15750</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:19:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15742">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
<p dir="auto">在 <a href="http://setup.py" target="_blank" rel="noopener noreferrer nofollow ugc">setup.py</a> 文件中，你需要添加 YOLOv5 的依赖。由于 YOLOv5 是一个 Python 项目，你可能需要确保所有必要的 Python 依赖项都被正确安装。YOLOv5 通常有一个 requirements.txt 文件列出了它的依赖项。你可以将这些依赖项添加到你的 ROS 2 包的 <a href="http://setup.py" target="_blank" rel="noopener noreferrer nofollow ugc">setup.py</a> 中，或者通过创建一个单独的 requirements.txt 文件并在工作空间中安装它们</p>
</blockquote>
<p dir="auto">这一步可以再详细一点吗</p>
]]></description><link>https://fishros.org.cn/forum/post/15749</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15749</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:19:18 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:10:42 GMT]]></title><description><![CDATA[<p dir="auto">您遇到的问题是在尝试从 GitHub 克隆仓库时出现了 TLS 连接错误。这个错误通常与 Git 使用的网络库（如 GnuTLS）处理 TLS/SSL 连接的方式有关。在尝试禁用 HTTP/2 后，问题似乎没有解决，反而出现了新的错误。这里有几个步骤可以帮助您解决这个问题：</p>
<ol>
<li>
<p dir="auto"><strong>检查网络连接</strong>：<br />
确保您的虚拟机可以正常访问互联网，特别是能够访问 GitHub。您可以尝试在浏览器中访问 GitHub 或使用 <code>ping</code> 和 <code>curl</code> 命令测试网络连接。</p>
</li>
<li>
<p dir="auto"><strong>更新 Git 和 GnuTLS</strong>：<br />
有时候，软件的老旧版本可能包含已知的 bug 或不兼容问题。尝试更新您的 Git 和 GnuTLS 到最新版本，看看是否能解决问题。</p>
</li>
<li>
<p dir="auto"><strong>配置 Git 使用不同的 SSL 后端</strong>：<br />
Git 默认可能使用 GnuTLS。如果您的系统还安装了 OpenSSL，您可以尝试配置 Git 使用 OpenSSL 而不是 GnuTLS。这可以通过设置环境变量来实现：</p>
<pre><code class="language-bash">export GIT_SSL_BACKEND=openssl
</code></pre>
<p dir="auto">然后再尝试执行 Git 命令。</p>
</li>
<li>
<p dir="auto"><strong>检查代理和防火墙设置</strong>：<br />
如果您在使用代理服务器或防火墙后面，确保 Git 配置正确以通过这些安全设备。您可能需要配置 Git 的代理设置：</p>
<pre><code class="language-bash">git config --global http.proxy 'proxy-url:port'
git config --global https.proxy 'proxy-url:port'
</code></pre>
<p dir="auto">替换 <code>'proxy-url:port'</code> 为您的代理服务器地址和端口。</p>
</li>
<li>
<p dir="auto"><strong>重新尝试禁用 HTTP/2</strong>：<br />
虽然您已经尝试过，但有时候重新执行命令或清除 Git 配置缓存可能有助于解决问题。确保您的 Git 配置中正确设置了 HTTP 版本：</p>
<pre><code class="language-bash">git config --global http.version HTTP/1.1
</code></pre>
</li>
<li>
<p dir="auto"><strong>查看详细的错误信息</strong>：<br />
使用 Git 的详细输出选项来获取更多关于错误的信息：</p>
<pre><code class="language-bash">GIT_CURL_VERBOSE=1 git clone https://github.com/ultralytics/yolov5.git
</code></pre>
<p dir="auto">这将显示 Git 在尝试克隆仓库时与服务器通信的详细日志，可能有助于诊断问题。</p>
</li>
<li>
<p dir="auto"><strong>检查系统时间和日期</strong>：<br />
确保您的虚拟机系统时间和日期是准确的。不正确的系统时间可能会导致 SSL/TLS 证书验证失败。</p>
</li>
</ol>
<p dir="auto">如果上述步骤都不能解决问题，您可能需要考虑联系您的网络管理员或查看是否有其他用户报告了类似的问题，特别是在使用相同的操作系统和 Git 版本时。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15748</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15748</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:10:42 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:10:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15744">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
<p dir="auto">禁用 HTTP/2：<br />
有时 Git 的 HTTP/2 支持可能会导致问题。你可以尝试禁用 HTTP/2 来查看是否能解决问题：</p>
<p dir="auto">git config --global http.version HTTP/1.1</p>
</blockquote>
<p dir="auto">进行了这一步之后报错fatal: 无法访问 '<a href="https://github.com/ultralytics/yolov5.git/" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ultralytics/yolov5.git/</a>'：GnuTLS recv error (-110): The TLS connection was non-properly terminated.</p>
]]></description><link>https://fishros.org.cn/forum/post/15747</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15747</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:10:08 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:07:33 GMT]]></title><description><![CDATA[<p dir="auto">当你在虚拟机上尝试克隆一个 Git 仓库时遇到错误，特别是与 TLS 连接终止相关的错误（如 <code>GnuTLS recv error (-110): The TLS connection was non-properly terminated</code>），这通常表明在网络层或安全协议层存在问题。尽管错误提示中提到了 Git 的 HTTP/2 支持可能导致问题，但根据你遇到的错误，更可能是与 SSL/TLS 配置或网络连接有关的问题。下面是一些解决步骤：</p>
<ol>
<li>
确保你的虚拟机可以访问外部网络，特别是 GitHub。你可以尝试 ping GitHub 的服务器或使用 curl 命令测试 HTTPS 连接：</p>
<pre><code class="language-bash">ping github.com
curl -I https://github.com
</code></pre>
</li>
<li>
<p dir="auto"><strong>更新和配置 SSL/TLS</strong>：</p>
<ul>
<li>确保你的系统和所有相关软件（包括 Git 和任何网络库，如 GnuTLS 或 OpenSSL）都是最新的。</li>
<li>检查 GnuTLS 或 OpenSSL 的配置，确保它们正确安装并配置为支持当前的加密标准。</li>
</ul>
</li>
<li>
<p dir="auto"><strong>禁用 SSL 证书验证</strong>（不推荐，除非作为临时测试手段）：<br />
作为临时测试，你可以尝试克隆仓库时禁用 SSL 证书验证来看是否能绕过问题。注意，这会降低安全性，因此仅作为测试手段：</p>
<pre><code class="language-bash">git clone https://github.com/ultralytics/yolov5.git --config http.sslVerify=false
</code></pre>
<p dir="auto">如果这解决了问题，那么问题可能与 SSL 证书或验证有关。</p>
</li>
<li>
<p dir="auto"><strong>使用 SSH 而不是 HTTPS</strong>：<br />
如果 HTTPS 连接持续出现问题，你可以考虑设置 SSH 密钥并使用 SSH URL 克隆仓库。首先，你需要在 GitHub 上添加你的 SSH 密钥，然后使用 SSH URL 克隆：</p>
<pre><code class="language-bash">git clone git@github.com:ultralytics/yolov5.git
</code></pre>
</li>
<li>
<p dir="auto"><strong>检查防火墙和代理设置</strong>：<br />
如果你的虚拟机配置了防火墙或代理服务器，确保它们不会阻止或干扰 Git 操作。</p>
</li>
<li>
<p dir="auto"><strong>重新配置 Git 的 HTTP 设置</strong>：<br />
尽管你已经尝试设置了 HTTP 版本为 1.1，但确认这一设置是否生效，或尝试重置其他可能影响的 Git 配置：</p>
<pre><code class="language-bash">git config --global --unset http.proxy
git config --global --unset https.proxy
</code></pre>
</li>
<li>
<p dir="auto"><strong>查看 Git 和 GnuTLS 的日志或错误输出</strong>：<br />
增加 Git 或 GnuTLS 的日志级别可能会提供更多关于错误原因的信息。</p>
</li>
</ol>
<p dir="auto">如果上述步骤都不能解决问题，可能需要更深入地检查网络配置或与系统管理员联系以获取帮助。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15746</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15746</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:07:33 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:06:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/1">@小伊</a> 在 <a href="/forum/post/15744">虚拟机上ros2 建立pkg失败</a> 中说：</p>
<blockquote>
</blockquote>
<p dir="auto">(my_torch) ros2<a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/20355">@ros2</a>:~/ros2_ws/src/yolov5_ros2$ git clone <a href="https://github.com/ultralytics/yolov5.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ultralytics/yolov5.git</a><br />
正克隆到 'yolov5'...<br />
]]></description><link>https://fishros.org.cn/forum/post/15745</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15745</guid><dc:creator><![CDATA[3513232534]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to 虚拟机上ros2 建立pkg失败 on Sat, 18 Jan 2025 15:04:17 GMT]]></title><description><![CDATA[<p dir="auto">在虚拟机上通过 <code>git clone</code> 克隆大型仓库（如 YOLOv5）时遇到错误通常与网络连接问题或 Git 配置有关。错误信息表明在克隆过程中，连接被意外中断，这可能是由于网络不稳定、超时设置过短或 Git 的 HTTP/2 支持问题。以下是一些解决步骤，你可以尝试这些步骤来解决克隆失败的问题：</p>
<ol>
<li>
<p dir="auto"><strong>增加 Git 的 HTTP 缓冲区大小</strong>：<br />
Git 默认使用较小的缓冲区来处理 HTTP/HTTPS 请求，这可能导致在克隆大型仓库时出现问题。你可以通过增加缓冲区大小来解决这个问题。运行以下命令来增加 Git 的 HTTP 缓冲区大小：</p>
<pre><code class="language-bash">git config --global http.postBuffer 524288000  # 设置为500MB
</code></pre>
</li>
<li>
<p dir="auto"><strong>禁用 HTTP/2</strong>：<br />
</code></pre>
</li>
<li>
确保你的虚拟机有稳定的网络连接。尝试访问其他网站或服务以验证网络连接。</p>
</li>
<li>
如果你有 GitHub 账户，并且已经设置了 SSH 密钥，可以尝试使用 SSH URL 来克隆仓库。首先，确保你的 SSH 密钥已经添加到 GitHub 账户中，并使用以下命令克隆仓库：</p>
</code></pre>
<p dir="auto">注意，使用 SSH 需要你先配置 SSH 密钥对，并确保你的虚拟机可以通过 SSH 连接到 GitHub。</p>
</li>
<li>
<p dir="auto"><strong>增加重试次数</strong>：<br />
有时简单地重试几次克隆操作就可以成功。网络问题可能是暂时的。</p>
</li>
<li>
<p dir="auto"><strong>检查磁盘空间</strong>：<br />
确保你的虚拟机有足够的磁盘空间来克隆仓库。</p>
</li>
<li>
<p dir="auto"><strong>使用代理（如果适用）</strong>：<br />
如果你的网络需要通过代理访问外部资源，确保 Git 配置了正确的代理设置。</p>
</li>
</ol>
<p dir="auto">尝试上述步骤之一或多个，看看是否能解决你的问题。如果问题仍然存在，可能需要进一步检查网络配置或与你的网络管理员联系以获取帮助。</p>
<hr />
]]></description><link>https://fishros.org.cn/forum/post/15744</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/15744</guid><dc:creator><![CDATA[小伊]]></dc:creator><pubDate>Sat, 18 Jan 2025 15:04:17 GMT</pubDate></item></channel></rss>
