<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[一键安装报错404]]></title><description><![CDATA[<p dir="auto">ubuntu 2004 安装 foxy<br />
使用中科大、清华和华为镜像源都报错404，最后安装失败</p>
<pre><code class="language-bash">
Fetched 22.4 MB in 14s (1,568 kB/s)
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-rclcpp-components/ros-foxy-rclcpp-components_2.4.3-1focal.20230527.082118_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-action-tutorials-py/ros-foxy-action-tutorials-py_0.9.4-1focal.20230527.070748_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-diagnostic-msgs/ros-foxy-diagnostic-msgs_2.0.5-1focal.20230527.054733_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-launch-ros/ros-foxy-launch-ros_0.11.7-1focal.20230527.070924_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-rcl-lifecycle/ros-foxy-rcl-lifecycle_1.1.14-1focal.20230527.065734_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-tlsf/ros-foxy-tlsf_0.5.0-1focal.20230527.045656_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Failed to fetch https://repo.huaweicloud.com/ros2/ubuntu/pool/main/r/ros-foxy-rviz-common/ros-foxy-rviz-common_8.2.8-1focal.20230606.040648_arm64.deb  404  Not Found [IP: 39.134.69.17 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Run CMD Task:[sudo apt install   ros-foxy-desktop -y]
[-][3.81s] CMD Result:code:100
Run CMD Task:[sudo apt search python3-colcon-common-extensions ]
[-][1.12s] CMD Result:success
[-][24.97s] CMD Result:success
Run CMD Task:[sudo apt search python3-argcomplete ]
[-][1.30s] CMD Result:success
[-][1.33s] CMD Result:success
Run CMD Task:[ls /opt/ros/foxy/setup.bash]
[-][0.00s] CMD Result:code:2
安装失败了,请打开鱼香社区：https://fishros.org.cn/forum 在一键安装专区反馈问题...
检测到已存在的配置文件: /tmp/fish_install.yaml
是否替换该文件？[y/N]: N
取消替换，保留原配置文件
欢迎加入机器人学习交流QQ群：438144612(入群口令：一键安装)
鱼香小铺正式开业，最低499可入手一台能建图会导航的移动机器人，淘宝搜店：鱼香ROS 或打开链接查看：https://item.taobao.com/item.htm?id=696573635888
如在使用过程中遇到问题，请打开：https://fishros.org.cn/forum 进行反馈
日志上传失败，若还需反馈请手动发帖!
nvidia@nvidia-desktop:~$
</code></pre>
]]></description><link>https://fishros.org.cn/forum/topic/4595/一键安装报错404</link><generator>RSS for Node</generator><lastBuildDate>Thu, 27 Aug 2026 01:52:46 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4595.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Oct 2025 08:13:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 一键安装报错404 on Thu, 23 Oct 2025 08:01:57 GMT]]></title><description><![CDATA[<p dir="auto">我是<br />
添加密钥：</p>
<pre><code class="language-bash">sudo apt install curl gnupg2 -y
curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo apt-key add -
</code></pre>
<p dir="auto">设置软件源：</p>
<pre><code class="language-bash">sudo sh -c 'echo "deb [arch=$(dpkg --print-architecture)] http://packages.ros.org/ros2/ubuntu $(lsb_release -cs) main" &gt; /etc/apt/sources.list.d/ros2-latest.list'
</code></pre>
<p dir="auto">安装：</p>
<pre><code class="language-bash">sudo apt update
</code></pre>
]]></description><link>https://fishros.org.cn/forum/post/19168</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19168</guid><dc:creator><![CDATA[N0026]]></dc:creator><pubDate>Thu, 23 Oct 2025 08:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to 一键安装报错404 on Thu, 23 Oct 2025 07:59:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/13054">@NAIGIA</a><br />
已经安装好了，虽然没用上，不过还是谢谢。</p>
]]></description><link>https://fishros.org.cn/forum/post/19167</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19167</guid><dc:creator><![CDATA[N0026]]></dc:creator><pubDate>Thu, 23 Oct 2025 07:59:32 GMT</pubDate></item><item><title><![CDATA[Reply to 一键安装报错404 on Wed, 22 Oct 2025 09:16:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/22188">@N0026</a> 试试这样添加密钥，然后再安装</p>
<p dir="auto">1.sudo apt update &amp;&amp; sudo apt install curl gnupg2 lsb-release</p>
<p dir="auto">2.sudo curl -sSL <a href="https://raw.githubusercontent.com/ros/rosdistro/master/ros.key" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/ros/rosdistro/master/ros.key</a> -o /usr/share/keyrings/ros-archive-keyring.gpg</p>
<p dir="auto">3.echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] <a href="http://packages.ros.org/ros2/ubuntu" target="_blank" rel="noopener noreferrer nofollow ugc">http://packages.ros.org/ros2/ubuntu</a> $(source /etc/os-release &amp;&amp; echo $UBUNTU_CODENAME) main" | sudo tee /etc/apt/sources.list.d/ros2.list &gt; /dev/null</p>
]]></description><link>https://fishros.org.cn/forum/post/19162</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19162</guid><dc:creator><![CDATA[NAIGIA]]></dc:creator><pubDate>Wed, 22 Oct 2025 09:16:07 GMT</pubDate></item></channel></rss>
