<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[启动问题]]></title><description><![CDATA[<p dir="auto">dusiyang@dusiyang-VMware-Virtual-Platform:~/chapt9/fishbot_ws$ source install/setup.bash<br />
dusiyang@dusiyang-VMware-Virtual-Platform:~/chapt9/fishbot_ws$ colcon build<br />
Starting &gt;&gt;&gt; micro_ros_msgs<br />
Starting &gt;&gt;&gt; fishbot_bringup<br />
Finished &lt;&lt;&lt; fishbot_bringup [0.37s]<br />
Starting &gt;&gt;&gt; fishbot_description<br />
Finished &lt;&lt;&lt; fishbot_description [0.18s]<br />
Starting &gt;&gt;&gt; fishbot_navigation2<br />
Finished &lt;&lt;&lt; fishbot_navigation2 [0.18s]<br />
Starting &gt;&gt;&gt; ros_serial2wifi<br />
Finished &lt;&lt;&lt; micro_ros_msgs [1.58s]<br />
Starting &gt;&gt;&gt; ydlidar<br />
Finished &lt;&lt;&lt; ydlidar [0.35s]<br />
Starting &gt;&gt;&gt; micro_ros_agent<br />
Finished &lt;&lt;&lt; micro_ros_agent [0.24s]<br />
Finished &lt;&lt;&lt; ros_serial2wifi [2.18s]</p>
<p dir="auto">Summary: 7 packages finished [3.13s]<br />
dusiyang@dusiyang-VMware-Virtual-Platform:~/chapt9/fishbot_ws$ ros2 launch fishbot_bringup <a href="http://bringup.launch.py" target="_blank" rel="noopener noreferrer nofollow ugc">bringup.launch.py</a><br />
[INFO] [launch]: All log files can be found below /home/dusiyang/.ros/log/2025-10-27-22-34-29-643497-dusiyang-VMware-Virtual-Platform-24285<br />
[INFO] [launch]: Default logging verbosity is set to INFO<br />
[INFO] [joint_state_publisher-1]: process started with pid [24289]<br />
[INFO] [robot_state_publisher-2]: process started with pid [24290]<br />
[INFO] [odom2tf-3]: process started with pid [24291]<br />
[INFO] [micro_ros_agent-4]: process started with pid [24292]<br />
[INFO] [tcp_server-5]: process started with pid [24293]<br />
[micro_ros_agent-4] [1761575669.866394] info     | UDPv4AgentLinux.cpp | init                     | running...             | port: 8888<br />
[micro_ros_agent-4] [1761575669.867697] info     | Root.cpp           | set_verbose_level        | logger setup           | verbose_level: 4<br />
[robot_state_publisher-2] [INFO] [1761575669.960179969] [robot_state_publisher]: Robot initialized<br />
[tcp_server-5] [INFO] [1761575670.399769875] [tcp_socket_server_node]: TCP端口:8889，已映射到串口设备:/tmp/tty_laser<br />
[tcp_server-5] [INFO] [1761575670.400160128] [tcp_socket_server_node]: 等待接受连接..<br />
[joint_state_publisher-1] [INFO] [1761575670.512671349] [joint_state_publisher]: Waiting for robot_description to be published on the robot_description topic...<br />
[INFO] [ydlidar_node-6]: process started with pid [24471]<br />
[ydlidar_node-6] [INFO] [1761575675.365816701] [ydlidar_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1<br />
[ydlidar_node-6]<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] SDK initializing<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] SDK has been initialized<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] SDK Version: 1.2.9<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Connect elapsed time 0 ms<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Lidar successfully connected [/tmp/tty_laser:115200]<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Lidar running correctly! The health status good<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Current Lidar Model Code 12<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Check status, Elapsed time 1 ms<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Lidar init success, Elapsed time [1]ms<br />
[ydlidar_node-6] [2025-10-27 22:34:35][info] Start to getting intensity flag<br />
[ydlidar_node-6] [2025-10-27 22:34:38][info] [YDLIDAR] End to getting intensity flag<br />
[ydlidar_node-6] [2025-10-27 22:34:38][info] [YDLIDAR] Create thread 0xDA7F46C0<br />
[ydlidar_node-6] [2025-10-27 22:34:38][info] Successed to start scan mode, Elapsed time 3561 ms<br />
[ydlidar_node-6] [2025-10-27 22:34:39][error] Timeout count: 1<br />
[ydlidar_node-6] [2025-10-27 22:34:40][error] Timeout count: 2<br />
[ydlidar_node-6] [2025-10-27 22:34:41][error] Timeout count: 3<br />
[ydlidar_node-6] [2025-10-27 22:34:44][error] Timeout count: 1<br />
[ydlidar_node-6] [2025-10-27 22:34:45][error] Timeout count: 2<br />
[ydlidar_node-6] [2025-10-27 22:34:46][error] Timeout count: 3<br />
[ydlidar_node-6] [2025-10-27 22:34:48][error] Timeout count: 1<br />
[ydlidar_node-6] [2025-10-27 22:34:49][error] Failed to turn on the Lidar, because the lidar is [Device Failed].<br />
[ydlidar_node-6] [INFO] [1761575689.141872002] [ydlidar_node]: [YDLIDAR INFO] Now YDLIDAR is stopping .......<br />
[INFO] [ydlidar_node-6]: process has finished cleanly [pid 24471]<br />
[ydlidar_node-6]</p>
]]></description><link>https://fishros.org.cn/forum/topic/4609/启动问题</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 18:14:56 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4609.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Oct 2025 14:55:03 GMT</pubDate><ttl>60</ttl></channel></rss>
