<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[WARN] [1762163141.374142146] [rosbag2_player]: Ignoring a topic &#x27;&#x2F;livox&#x2F;lidar&#x27;, reason: package &#x27;livox_ros_driver2&#x27; not found, searching: [&#x2F;opt&#x2F;ros&#x2F;humble].]]></title><description><![CDATA[<p dir="auto">[WARN] [1762163141.374142146] [rosbag2_player]: Ignoring a topic '/livox/lidar', reason: package 'livox_ros_driver2' not found, searching: [/opt/ros/humble].</p>
]]></description><link>https://fishros.org.cn/forum/topic/4619/warn-1762163141-374142146-rosbag2_player-ignoring-a-topic-livox-lidar-reason-package-livox_ros_driver2-not-found-searching-opt-ros-humble</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 19:23:56 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4619.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Nov 2025 11:05:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [WARN] [1762163141.374142146] [rosbag2_player]: Ignoring a topic &#x27;&#x2F;livox&#x2F;lidar&#x27;, reason: package &#x27;livox_ros_driver2&#x27; not found, searching: [&#x2F;opt&#x2F;ros&#x2F;humble]. on Thu, 08 Jan 2026 07:22:49 GMT]]></title><description><![CDATA[<p dir="auto">你应该是用了msg_MID360 的launch 文件来采集数据的，这个launch文件采集的数据不是标准的pointcloud2，所以需要你在你的电脑上也构建livox_ros_driver 来读取这个客制化信息。可以试试用rviz_MID360 这个launch 文件来收集数据，那样的话就是ros2标准的信息了</p>
]]></description><link>https://fishros.org.cn/forum/post/19404</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19404</guid><dc:creator><![CDATA[1768464974]]></dc:creator><pubDate>Thu, 08 Jan 2026 07:22:49 GMT</pubDate></item></channel></rss>
