<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[一键安装出现错误，该如何解决]]></title><description><![CDATA[<p dir="auto">RUN Choose Task:[Please enter the number in brackets]<br />
请选择你要安装的ROS版本名称(请注意ROS1和ROS2区别):<br />
[1]:foxy(ROS2)<br />
[2]:galactic(ROS2)<br />
[3]:noetic(ROS1)<br />
[4]:rolling(ROS2)<br />
[0]:quit<br />
Type the number in [] to choose a function:3<br />
请选择安装的具体版本(如果不知道怎么选,请选1桌面版):<br />
[1]:noetic(ROS1)桌面版<br />
[2]:noetic(ROS1)基础版(小)<br />
[0]:quit<br />
Type the number in [] to choose a function:1<br />
Run CMD Task:[sudo apt search aptitude ]<br />
[-][1.77s] CMD Result:success</p>
<p dir="auto">Run CMD Task:[sudo apt install aptitude -y]<br />
[-][1.54s] CMD Result:code:100</p>
<p dir="auto">Run CMD Task:[sudo apt install   ros-noetic-desktop-full -y]<br />
Reading package lists... Done<br />
Building dependency tree<br />
Reading state information... Done<br />
Some packages could not be installed. This may mean that you have<br />
requested an impossible situation or if you are using the unstable<br />
distribution that some required packages have not yet been created<br />
or been moved out of Incoming.<br />
The following information may help to resolve the situation:</p>
<p dir="auto">The following packages have unmet dependencies:<br />
ros-noetic-desktop-full : Depends: ros-noetic-desktop but it is not going to be installed<br />
Depends: ros-noetic-perception but it is not going to be installed<br />
Depends: ros-noetic-simulators but it is not going to be installed<br />
Depends: ros-noetic-urdf-sim-tutorial but it is not going to be installed<br />
E: Unable to correct problems, you have held broken packages.<br />
<p dir="auto">============================================================<br />
请注意我，检测你在安装过程中出现依赖问题，请在稍后输入n,再选择y,即可解决（若无法解决，清在稍后手动运行命令: sudo aptitude install ros-noetic-desktop-full)<br />
确认了解情况，请输入回车继续安装<br />
Run CMD Task:[sudo aptitude install   ros-noetic-desktop-full]<br />
sudo: aptitude: command not found<br />
Run CMD Task:[sudo aptitude install   ros-noetic-desktop-full -y]<br />
[-][0.00s] CMD Result:code:1</p>
<p dir="auto">Run CMD Task:[sudo apt search python3-catkin-tools ]<br />
[-][1.51s] CMD Result:success</p>
<p dir="auto">Run CMD Task:[sudo apt install python3-catkin-tools -y]<br />
[-][1.44s] CMD Result:code:100</p>
<p dir="auto">Run CMD Task:[sudo apt search python3-rosdep ]<br />
[-][1.56s] CMD Result:success</p>
<p dir="auto">Run CMD Task:[sudo apt install python3-rosdep -y]<br />
<p dir="auto">Run CMD Task:[ls /opt/ros/noetic/setup.bash]<br />
[-][0.00s] CMD Result:code:2</p>
<p dir="auto">安装失败了,请打开鱼香社区：<a href="https://fishros.org.cn/forum">https://fishros.org.cn/forum</a> 在一键安装专区反馈问题...</p>
]]></description><link>https://fishros.org.cn/forum/topic/4656/一键安装出现错误-该如何解决</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 16:02:53 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4656.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Nov 2025 07:35:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 一键安装出现错误，该如何解决 on Wed, 26 Nov 2025 07:44:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/28121">@1243708162</a> 解决了应该 之前前面有个问题 看了社区 导致我换了163的源 然后解决了 出现这个问题 再换回原来的源就好的</p>
<p dir="auto">遇到的问题就 sudo apt install aptitude -y 这个安装不了<br />
希望能帮到同样问题的<br />
当然应该遇不到我这问题</p>
]]></description><link>https://fishros.org.cn/forum/post/19300</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19300</guid><dc:creator><![CDATA[1243708162]]></dc:creator><pubDate>Wed, 26 Nov 2025 07:44:20 GMT</pubDate></item></channel></rss>
