<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[执行示例ros2 run demo_nodes_cpp talker错误]]></title><description><![CDATA[<p dir="auto">(lerobot) root@tydic-OMEN-MAX-Gaming-Laptop-16-ah0xxx:~# ros2 run demo_nodes_cpp talker<br />
Traceback (most recent call last):<br />
File "/opt/ros/humble/bin/ros2", line 33, in &lt;module&gt;<br />
sys.exit(load_entry_point('ros2cli==0.18.15', 'console_scripts', 'ros2')())<br />
File "/opt/ros/humble/bin/ros2", line 25, in importlib_load_entry_point<br />
return next(matches).load()<br />
File "/usr/lib/python3.10/importlib/metadata/<strong>init</strong>.py", line 171, in load<br />
module = import_module(match.group('module'))<br />
File "/usr/lib/python3.10/importlib/<strong>init</strong>.py", line 126, in import_module<br />
return _bootstrap._gcd_import(name[level:], package, level)<br />
File "&lt;frozen importlib._bootstrap&gt;", line 1050, in _gcd_import<br />
File "&lt;frozen importlib._bootstrap&gt;", line 1027, in _find_and_load<br />
File "&lt;frozen importlib._bootstrap&gt;", line 1006, in _find_and_load_unlocked<br />
File "&lt;frozen importlib._bootstrap&gt;", line 688, in _load_unlocked<br />
File "&lt;frozen importlib._bootstrap_external&gt;", line 883, in exec_module<br />
File "&lt;frozen importlib._bootstrap&gt;", line 241, in _call_with_frames_removed<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 22, in &lt;module&gt;<br />
from rclpy.executors import ExternalShutdownException<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/<strong>init</strong>.py", line 49, in &lt;module&gt;<br />
from rclpy.signals import install_signal_handlers<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/signals.py", line 15, in &lt;module&gt;<br />
from rclpy.exceptions import InvalidHandle<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/exceptions.py", line 15, in &lt;module&gt;<br />
from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/impl/implementation_singleton.py", line 32, in &lt;module&gt;<br />
rclpy_implementation = import_c_library('._rclpy_pybind11', package)<br />
File "/opt/ros/humble/lib/python3.10/site-packages/rpyutils/import_c_library.py", line 39, in import_c_library<br />
return importlib.import_module(name, package=package)<br />
ImportError: /opt/ros/humble/lib/librcl_logging_spdlog.so: undefined symbol: <em>ZN6spdlog7details7log_msgC1ENS_10source_locEN3fmt2v817basic_string_viewIcEENS_5level10level_enumES6</em><br />
The C extension '/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/_rclpy_pybind11.cpython-310-x86_64-linux-gnu.so' failed to be imported while being present on the system. Please refer to '<a href="https://docs.ros.org/en/%7Bdistro%7D/Guides/Installation-Troubleshooting.html#import-failing-even-with-library-present-on-the-system" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.ros.org/en/{distro}/Guides/Installation-Troubleshooting.html#import-failing-even-with-library-present-on-the-system</a>' for possible solutions</p>
]]></description><link>https://fishros.org.cn/forum/topic/4660/执行示例ros2-run-demo_nodes_cpp-talker错误</link><generator>RSS for Node</generator><lastBuildDate>Thu, 27 Aug 2026 03:17:27 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4660.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Dec 2025 08:05:42 GMT</pubDate><ttl>60</ttl></channel></rss>
