<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[根据B站第三章节的3.4.3成功后，将install复制到其它ROS2的板子上，并生效环境变量，查看发布的话题信息报错，本地是可以的]]></title><description><![CDATA[<p dir="auto">File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support<br />
return importlib.import_module(module_name, package=pkg_name)<br />
File "/usr/lib/python3.10/importlib/<strong>init</strong>.py", line 126, in import_module<br />
return _bootstrap._gcd_import(name[level:], package, level)<br />
File "&lt;frozen importlib._bootstrap&gt;", line 1050, in _gcd_import<br />
File "&lt;frozen importlib._bootstrap&gt;", line 1027, in _find_and_load<br />
File "&lt;frozen importlib._bootstrap&gt;", line 1004, in _find_and_load_unlocked<br />
ModuleNotFoundError: No module named 'status_interfaces.status_interfaces_s__rosidl_typesupport_c'</p>
<p dir="auto">During handling of the above exception, another exception occurred:</p>
<p dir="auto">Traceback (most recent call last):<br />
File "/opt/ros/humble/bin/ros2", line 33, in &lt;module&gt;<br />
sys.exit(load_entry_point('ros2cli==0.18.15', 'console_scripts', 'ros2')())<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 91, in main<br />
rc = extension.main(parser=parser, args=args)<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2topic/command/topic.py", line 41, in main<br />
return extension.main(args=args)<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2topic/verb/echo.py", line 235, in main<br />
self.subscribe_and_spin(<br />
File "/opt/ros/humble/lib/python3.10/site-packages/ros2topic/verb/echo.py", line 258, in subscribe_and_spin<br />
node.create_subscription(<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/node.py", line 1373, in create_subscription<br />
check_is_valid_msg_type(msg_type)<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/type_support.py", line 35, in check_is_valid_msg_type<br />
check_for_type_support(msg_type)<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/type_support.py", line 29, in check_for_type_support<br />
msg_or_srv_type.<strong>class</strong>.<strong>import_type_support</strong>()<br />
File "/home/sunrise/install/status_interfaces/local/lib/python3.10/dist-packages/status_interfaces/msg/_system_status.py", line 31, in <strong>import_type_support</strong><br />
module = import_type_support('status_interfaces')<br />
File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support<br />
raise UnsupportedTypeSupport(pkg_name)<br />
rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'status_interfaces'</p>
]]></description><link>https://fishros.org.cn/forum/topic/4670/根据b站第三章节的3-4-3成功后-将install复制到其它ros2的板子上-并生效环境变量-查看发布的话题信息报错-本地是可以的</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 21:00:56 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4670.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Dec 2025 05:15:25 GMT</pubDate><ttl>60</ttl></channel></rss>
