<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[rqt报错，我是小白^...^]]></title><description><![CDATA[<p dir="auto">在下载好ubuntu还有linux之后，小海龟也能键盘控制移动，但是在vscode里".bashrc"集成终端中打开输入ros2没报错，<strong>输入rqt报错说importerror</strong>：。怎么办哪里出错了吗。<br />
<img src="/forum/assets/uploads/files/1767629797579-%E6%8D%95%E8%8E%B7-resized.png" alt="捕获.PNG" class=" img-fluid img-markdown" /></p>
<pre><code>code_text
</code></pre>
<pre><code class="language-Traceback">  File "/opt/ros/humble/bin/rqt", line 33, in &lt;module&gt;
    sys.exit(load_entry_point('rqt-gui==1.1.9', 'console_scripts', 'rqt')())
  File "/opt/ros/humble/lib/python3.10/site-packages/rqt_gui/main.py", line 94, in main
    sys.exit(Main().main())
  File "/opt/ros/humble/lib/python3.10/site-packages/rqt_gui/main.py", line 62, in main
    return super(Main, self).main(
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/qt_gui/main.py", line 418, in main
    from python_qt_binding import QT_BINDING
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/__init__.py", line 56, in &lt;module&gt;
    from python_qt_binding.binding_helper import loadUi  # noqa: F401
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/binding_helper.py", line 277, in &lt;module&gt;
    _select_qt_binding(
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/binding_helper.py", line 118, in _select_qt_binding
    raise ImportError(
ImportError: Could not find Qt binding (looked for: 'pyqt', 'pyside'):
  ImportError for 'pyqt': libQt5Core.so.5: cannot open shared object file: No such file or directory
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/binding_helper.py", line 108, in _select_qt_binding
    QT_BINDING_VERSION = binding_loader(required_modules, optional_modules)
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/binding_helper.py", line 153, in _load_pyqt
    _named_import('PyQt5.%s' % module_name)
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/binding_helper.py", line 133, in _named_import
    module = builtins.__import__(name)
ImportError: libQt5Core.so.5: cannot open shared object file: No such file or directory
  ImportError for 'pyside': libQt5Core.so.5: cannot open shared object file: No such file or directory
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/python_qt_binding/binding_helper.py", line 185, in _load_pyside
    _named_import('PySide2.%s' % module_name)
ImportError: libQt5Core.so.5: cannot open shared object file: No such file or directory**粗体字**</code></pre>
]]></description><link>https://fishros.org.cn/forum/topic/4687/rqt报错-我是小白</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 22:56:04 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4687.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Jan 2026 16:19:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to rqt报错，我是小白^...^ on Mon, 05 Jan 2026 16:41:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/29510">@zsm</a> <img src="/forum/assets/uploads/files/1767631251825-%E6%8D%95%E8%8E%B73.png" alt="捕获3.PNG" class=" img-fluid img-markdown" /> 英文打不能输入q，中文能输入</p>
]]></description><link>https://fishros.org.cn/forum/post/19391</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19391</guid><dc:creator><![CDATA[zsm]]></dc:creator><pubDate>Mon, 05 Jan 2026 16:41:27 GMT</pubDate></item><item><title><![CDATA[Reply to rqt报错，我是小白^...^ on Mon, 05 Jan 2026 16:37:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fishros.org.cn/forum/uid/29510">@zsm</a> 但是为什么Ubuntu系统里终端输入rqt没问题，我这个rqt输入的时候不能先输入“q”</p>
]]></description><link>https://fishros.org.cn/forum/post/19390</link><guid isPermaLink="true">https://fishros.org.cn/forum/post/19390</guid><dc:creator><![CDATA[zsm]]></dc:creator><pubDate>Mon, 05 Jan 2026 16:37:34 GMT</pubDate></item></channel></rss>
