<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[使用一键安装过程中遇到程序崩溃]]></title><description><![CDATA[<pre><code>Traceback (most recent call last):
  File "/tmp/fishinstall/install.py", line 285, in &lt;module&gt;
  File "/tmp/fishinstall/install.py", line 255, in main
    run_tool_file(tools[code]["tool"].replace("/", "."))
  File "/tmp/fishinstall/tools/base.py", line 1636, in run_tool_file
    if tool.run() == False:
  File "/tmp/fishinstall/tools/tool_config_system_source.py", line 363, in run
    self.change_sys_source()
  File "/tmp/fishinstall/tools/tool_config_system_source.py", line 356, in change_sys_source
    if result[0]==0:
UnboundLocalError: cannot access local variable 'result' where it is not associated with a value
</code></pre>
<p dir="auto">本次运行详细日志文件已保存至 /tmp/fishros_install.log</p>
<p dir="auto">rpi@rpi:~ $ cat /tmp/fishros_install.log<br />
Traceback (most recent call last):<br />
File "/tmp/fishinstall/install.py", line 285, in &lt;module&gt;<br />
main()<br />
~~~~^^<br />
File "/tmp/fishinstall/install.py", line 255, in main<br />
run_tool_file(tools[code]["tool"].replace("/", "."))<br />
~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^<br />
File "/tmp/fishinstall/tools/base.py", line 1636, in run_tool_file<br />
if tool.run() == False:<br />
~~~~~~~~^^<br />
File "/tmp/fishinstall/tools/tool_config_system_source.py", line 363, in run<br />
self.change_sys_source()<br />
~~~~~~~~~~~~~~~~~~~~~~^^<br />
File "/tmp/fishinstall/tools/tool_config_system_source.py", line 356, in change_sys_source<br />
if result[0]==0:<br />
^^^^^^<br />
UnboundLocalError: cannot access local variable 'result' where it is not associated with a value</p>
<p dir="auto">Run CMD Task:[dpkg --print-architecture]<br />
[-][0.00s] CMD Result:success</p>
<p dir="auto">Run CMD Task:[mkdir -p /tmp/fishinstall/tools/translation/assets]<br />
<p dir="auto">Run CMD Task:[wget <a href="https://fishros.org.cn/forum/topic/1733">https://fishros.org.cn/forum/topic/1733</a> -O /tmp/t1733 -q --no-check-certificate --timeout 10 &amp;&amp; rm -rf /tmp/t1733]<br />
<h1>已为您切换语言至当前所在国家语言:zh_CN<br />
基础检查通过...</h1>
<h1>======欢迎使用一键安装工具，人生苦短，三省吾身，省时省力省心!=======<br />
======一键安装已开源，请放心使用：<a href="https://github.com/fishros/install" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/fishros/install</a> =======</h1>
<pre><code>                    .-~~~~~~~~~-._       _.-~~~~~~~~~-.
            .'// 可以多看看小鱼的文章  | 关注B站鱼香ROS机器人 \ `.
</code></pre>
<p dir="auto">RUN Choose Task:[请输入括号内的数字]<br />
---众多工具，等君来用---<br />
ROS相关:<br />
[1]:一键安装(推荐):ROS(支持ROS/ROS2,树莓派Jetson)<br />
[3]:一键安装:rosdep(小鱼的rosdepc,又快又好用)<br />
[4]:一键配置:ROS环境(快速更新ROS环境设置,自动生成环境选择)<br />
[9]:一键安装:Cartographer(18 20测试通过,16未测. updateTime 20240125)<br />
[11]:一键安装:ROS Docker版(支持所有版本ROS/ROS2)<br />
[16]:一键安装：系统自带ROS (！！警告！！仅供特殊情况下使用)<br />
AI板块:<br />
[6]:一键安装:NodeJs环境<br />
[14]:一键安装:科学上网代理工具<br />
[18]:一键安装/卸载:OpenCode(AI编程助手)<br />
常用软件:<br />
[2]:一键安装:github桌面版(小鱼常用的github客户端)<br />
[7]:一键安装:VsCode开发工具<br />
[8]:一键安装:Docker<br />
[10]:一键安装:微信(可以在Linux上使用的微信)<br />
[12]:一键安装:PlateformIO MicroROS开发环境(支持Fishbot)<br />
[15]:一键安装：QQ for Linux<br />
配置工具:<br />
[5]:一键配置:系统源(更换系统源,支持全版本Ubuntu系统)<br />
[13]:一键配置:python国内源<br />
[17]:一键配置: Docker代理(支持VPN+代理服务两种模式)<br />
[0]:quit</p>
<p dir="auto">Run CMD Task:[wget <a href="http://mirror.fishros.com/install/tools/tool_config_system_source.py" target="_blank" rel="noopener noreferrer nofollow ugc">http://mirror.fishros.com/install/tools/tool_config_system_source.py</a> -O /tmp/fishinstall/tools/tool_config_system_source.py --no-check-certificate]<br />
[-][0.10s] CMD Result:success</p>
<p dir="auto">Run CMD Task:[wget <a href="http://mirror.fishros.com/install/tools/tool_install_ros.py" target="_blank" rel="noopener noreferrer nofollow ugc">http://mirror.fishros.com/install/tools/tool_install_ros.py</a> -O /tmp/fishinstall/tools/tool_install_ros.py --no-check-certificate]<br />
[-][0.09s] CMD Result:success</p>
<p dir="auto">欢迎使用一键更换系统源,本工具由作者小鱼提供<br />
请选择换源方式,如果不知道选什么请选2<br />
[1]:仅更换系统源<br />
[2]:更换系统源并清理第三方源<br />
[0]:quit<br />
Run CMD Task:[sudo rm -rf /etc/apt/sources.list.d]<br />
<p dir="auto">Run CMD Task:[sudo mkdir -p /etc/apt/sources.list.d]<br />
<p dir="auto">源选择方式说明:</p>
<ol>
<li>自动测速选择最快的源: 系统将自动测试各个源的速度，并选择最快的源</li>
<li>根据测速结果手动选择源: 系统将测试各个源的速度，然后让您从测试结果中选择<br />
请选择源的选择方式<br />
[1]:自动测速选择最快的源<br />
[2]:根据测速结果手动选择源<br />
[0]:quit<br />
[-][0.00s] CMD Result:success</li>
</ol>
<p dir="auto">检测到当前系统:debian 架构:arm64 代号:,正在为你搜索适合的源...<br />
搜索到可用源:[]<br />
接下来将进行自动测速以为您选择最快的源:<br />
没有找到合适的镜像源,臣妾告退!</p>
<p dir="auto">使用的设备是树莓派5(8G)+raspbian</p>
]]></description><link>https://fishros.org.cn/forum/topic/4764/使用一键安装过程中遇到程序崩溃</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 14:01:42 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4764.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Apr 2026 08:42:22 GMT</pubDate><ttl>60</ttl></channel></rss>
