<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[已力竭，无法解决]]></title><description><![CDATA[<h2>在microros写自定义接口的教程中，删掉.pio/libdeps/featheresp32/micro_ros_platformio/libmicroros后重新编译，无法编译<br />
rocessing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)</h2>
<p dir="auto">Verbose mode can be enabled via <code>-v, --verbose</code> option<br />
CONFIGURATION: <a href="https://docs.platformio.org/page/boards/espressif32/featheresp32.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.platformio.org/page/boards/espressif32/featheresp32.html</a><br />
PLATFORM: Espressif 32 (7.0.1) &gt; Adafruit ESP32 Feather<br />
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash<br />
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)<br />
PACKAGES:</p>
<ul>
<li>framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b</li>
<li>tool-esptoolpy @ 2.41100.0 (4.11.0)</li>
<li>toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5<br />
LDF: Library Dependency Finder -&gt; <a href="https://bit.ly/configure-pio-ldf" target="_blank" rel="noopener noreferrer nofollow ugc">https://bit.ly/configure-pio-ldf</a><br />
LDF Modes: Finder ~ chain, Compatibility ~ soft<br />
Installing importlib-resources with pip at PlatformIO environment<br />
/home/wlz/.platformio/penv/bin/python -m pip install importlib-resources<br />
Requirement already satisfied: importlib-resources in /home/wlz/.platformio/penv/lib/python3.10/site-packages (7.1.0)<br />
Installing pyyaml with pip at PlatformIO environment<br />
/home/wlz/.platformio/penv/bin/python -m pip install pyyaml<br />
Requirement already satisfied: pyyaml in /home/wlz/.platformio/penv/lib/python3.10/site-packages (6.0.3)<br />
Installing markupsafe==2.0.1 with pip at PlatformIO environment<br />
/home/wlz/.platformio/penv/bin/python -m pip install markupsafe==2.0.1<br />
Requirement already satisfied: markupsafe==2.0.1 in /home/wlz/.platformio/penv/lib/python3.10/site-packages (2.0.1)<br />
Configuring featheresp32 with transport serial<br />
Downloading micro-ROS dev dependencies<br />
ament_cmake clone failed:<br />
正克隆到 '/home/wlz/project/PIO/example14_custom_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/dev/src/ament_cmake'...<br />
fatal: 无法访问 '<a href="http://github.fishros.org/https://github.com/ament/ament_cmake/" target="_blank" rel="noopener noreferrer nofollow ugc">http://github.fishros.org/https://github.com/ament/ament_cmake/</a>'：Failed to connect to <a href="http://github.fishros.org" target="_blank" rel="noopener noreferrer nofollow ugc">github.fishros.org</a> port 80 after 3610 ms: 没有到主机的路由</li>
</ul>
<p dir="auto">===================================== [FAILED] Took 4.84 seconds =====================================</p>
]]></description><link>https://fishros.org.cn/forum/topic/4804/已力竭-无法解决</link><generator>RSS for Node</generator><lastBuildDate>Wed, 26 Aug 2026 14:31:29 GMT</lastBuildDate><atom:link href="https://fishros.org.cn/forum/topic/4804.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jul 2026 10:25:08 GMT</pubDate><ttl>60</ttl></channel></rss>
