未解决 rosdepc update更新出错,HTTP Error 403
shinka@shinka:~$ rosdepc update
欢迎使用国内版rosdep之rosdepc,我是作者小鱼!小鱼制作了11万字的ROS2教程和配套视频,关注公众号《鱼香ROS》即可领取!
小鱼rosdepc正式为您服务
reading in sources list data from /etc/ros/rosdep/sources.list.d
ERROR: unable to process source [https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/osx-homebrew.yaml]:
HTTP Error 403: FORBIDDEN (https://ghproxy.com/https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/osx-homebrew.yaml)
ERROR: unable to process source [https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/base.yaml]:
HTTP Error 403: FORBIDDEN (https://ghproxy.com/https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/base.yaml)
ERROR: unable to process source [https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/python.yaml]:
HTTP Error 403: FORBIDDEN (https://ghproxy.com/https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/python.yaml)
ERROR: unable to process source [https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/ruby.yaml]:
HTTP Error 403: FORBIDDEN (https://ghproxy.com/https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/ruby.yaml)
Query rosdistro index https://mirrors.tuna.tsinghua.edu.cn/rosdistro/index-v4.yaml
Skip end-of-life distro "ardent"
Skip end-of-life distro "bouncy"
Skip end-of-life distro "crystal"
Skip end-of-life distro "dashing"
Skip end-of-life distro "eloquent"
Add distro "foxy"
ERROR: error loading sources list:
The read operation timed out
小鱼恭喜:rosdepc已为您完成更新!! -
@862445328 在 rosdepc update更新出错,HTTP Error 403 中说:
请删除该文件后重试,你是不是手动修改了该文件
问题一定要描述清楚,终端打印一定复制粘贴(你可以在linux系统上打开浏览器进社区)
尽量一句话说完,不要把社区当微信聊天一样用,每一个回复都尽量提供更多的的信息。 -
@小鱼 感谢大佬,没有修改过,删除重试了,还是同样的错误呢。。。
@862445328 贴一下rosdepc init的结果
shinka@shinka:~$ rosdepc init
小鱼rosdepc正式为您服务
--2022-12-07 10:36:22-- https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
正在解析主机 mirrors.tuna.tsinghua.edu.cn (mirrors.tuna.tsinghua.edu.cn)... 101.6.15.130, 2402:f000:1:400::2
正在连接 mirrors.tuna.tsinghua.edu.cn (mirrors.tuna.tsinghua.edu.cn)|101.6.15.130|:443... 已连接。
已发出 HTTP 请求,正在等待回应... 200 OK
长度: 550 [application/octet-stream]
正在保存至: “/etc/ros/rosdep/sources.list.d/20-default.list”/etc/ros/rosdep/sources.list. 100%[==============================================>] 550 --.-KB/s 用时 0s
2022-12-07 10:36:24 (243 MB/s) - 已保存 “/etc/ros/rosdep/sources.list.d/20-default.list” [550/550])
小鱼提示:恭喜你完成初始化,快点使用 rosdepc update 更新吧
之后rosdepc updata仍然报403的错
@862445328 升级最新版
sudo pip3 install rosdepc --upgrade
sudo rosdepc init
rosdepc update -
shinka@shinka:~$ sudo pip3 install rosdepc --upgrade
Requirement already up-to-date: rosdepc in /usr/local/lib/python3.8/dist-packages (1.0.2)
Requirement already satisfied, skipping upgrade: rosdep in /usr/lib/python3/dist-packages (from rosdepc) (0.22.1)
Requirement already satisfied, skipping upgrade: PyYAML>=3.1 in /usr/lib/python3/dist-packages (from rosdep->rosdepc) (5.3.1)
Requirement already satisfied, skipping upgrade: setuptools in /usr/lib/python3/dist-packages (from rosdep->rosdepc) (45.2.0)shinka@shinka:~$ sudo rosdepc init
欢迎关注公众号《鱼香ROS》加入交流群,小鱼rosdepc正式为您服务
--2022-12-07 11:20:17-- https://mirrors.tuna.tsinghua.edu.cn/github-raw/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
/etc/ros/rosdep/sources 100%[============================>] 550 --.-KB/s 用时 0s
2022-12-07 11:20:17 (502 MB/s) - 已保存 “/etc/ros/rosdep/sources.list.d/20-default.list” [550/550])小鱼提示:恭喜你完成初始化,快点使用
rosdepc update
更新吧
因为有一些小伙伴更新使用rosdep update,老是搞错,小鱼就直接帮你进行更新了!请稍等!reading in sources list data from /etc/ros/rosdep/sources.list.d
Warning: running 'rosdep update' as root is not recommended.
You should run 'sudo rosdep fix-permissions' and invoke 'rosdep update' again without sudo.
The read operation timed out小鱼恭喜:rosdepc已为您完成更新!!
大佬,结果仍然是报403,再继续 rosdepc update也是一连串的403,这是我网络的问题吗
