重要提示
社区使用指南—如何添加标签修改密码
未解决 在编译navigation2及其依赖的时候,产生- The generic dependency on 'nav2_bringup' is redundant with: exec_depend错误,一直无法解决
@2425004936 在 在编译navigation2及其依赖的时候,产生- The generic dependency on 'nav2_bringup' is redundant with: exec_depend错误,一直无法解决 中说:
exec_depend
检查下对应的 packages.xml ,另外给出上下文
尽量一句话说完,不要把社区当微信聊天一样用,每一个回复都尽量提供更多的的信息。 -
@小鱼 好的,谢谢你
@小鱼 解决了nav2_bringup错误。确实是packages.xml写错了。目前编译nav2包及其依赖项时一直提示"1 package failed: nav2_mppi_controller
"系统是ubuntu22.04,humble版本。我源码下载的是humble版本。如下是错误信息:
--- stderr: nav2_mppi_controller
/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp: In member function ‘virtual void NoiseGeneratorTest_NoiseGeneratorLifecycle_Test::TestBody()’:
/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:45:32: error: ‘rclcpp_lifecycle’ was not declared in this scope
45 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:45:20: error: parse error in template argument list
45 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:45:64: error: no matching function for call to ‘make_shared<<expression error> >(const char [5])’
45 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");In file included from /usr/include/c++/11/memory:77,
from /opt/ros/humble/src/gtest_vendor/include/gtest/gtest.h:57,
from /home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:18:
/usr/include/c++/11/bits/shared_ptr.h:875:5: note: candidate: ‘template<class _Tp, class ... _Args> std::shared_ptr<_Tp> std::make_shared(_Args&& ...)’
875 | make_shared(_Args&&... __args)/usr/include/c++/11/bits/shared_ptr.h:875:5: note: template argument deduction/substitution failed:
/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:45:64: error: template argument 1 is invalid
45 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:47:3: error: ‘ParametersHandler’ was not declared in this scope
47 | ParametersHandler handler(node);/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:49:55: error: ‘handler’ was not declared in this scope
49 | generator.initialize(settings, false, "test_name", &handler);/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp: In member function ‘virtual void NoiseGeneratorTest_NoiseGeneratorMain_Test::TestBody()’:
/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:57:32: error: ‘rclcpp_lifecycle’ was not declared in this scope
57 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:57:20: error: parse error in template argument list
57 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:57:64: error: no matching function for call to ‘make_shared<<expression error> >(const char [5])’
57 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");In file included from /usr/include/c++/11/memory:77,
/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:57:64: error: template argument 1 is invalid
57 | auto node = std::make_shared<rclcpp_lifecycle::LifecycleNode>("node");/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:59:3: error: ‘ParametersHandler’ was not declared in this scope
59 | ParametersHandler handler(node);/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:59:3: error: ‘ParametersHandler’ was not declared in this scope
59 | ParametersHandler handler(node);/home/lhx/lhx_ws/src/navigation2/nav2_mppi_controller/test/noise_generator_test.cpp:81:55: error: ‘handler’ was not declared in this scope
81 | generator.initialize(settings, false, "test_name", &handler);gmake[2]: *** [test/CMakeFiles/noise_generator_test.dir/build.make:76:test/CMakeFiles/noise_generator_test.dir/noise_generator_test.cpp.o] 错误 1
gmake[1]: *** [CMakeFiles/Makefile2:334:test/CMakeFiles/noise_generator_test.dir/all] 错误 2
gmake: *** [Makefile:146:all] 错误 2Failed <<< nav2_mppi_controller [13.6s, exited with code 2]
@2425004936 又一个出现这个问题的。
@1367426346 我来check下
这样操作
git clone https://github.com/ros-planning/navigation2.git -b humble
git reset 1.1.9回退下版本后测试
此回复已被删除! -
@小鱼 在 在编译navigation2及其依赖的时候,产生- The generic dependency on 'nav2_bringup' is redundant with: exec_depend错误,一直无法解决 中说:
git reset 1.1.9
试了一下,回退版本还是无法编译成功。错误提示还是和上面一样
@2425004936 你好,你怎么改的package.xml文件啊
