    一键安装cartographer后,编译报错
    一键安装,carto编译失败 未定义的引用
    1.1k
    • 12498830711
      ReLesEason
      probability_grid_range_data_inserter_options_2d.pb.cc:(.text+0x52f):对‘google::protobuf::internal::AssignDescriptors(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, google::protobuf::internal::MigrationSchema const*, google::protobuf::Message const* const*, unsigned int const*, google::protobuf::MessageFactory*, google::protobuf::Metadata*, google::protobuf::EnumDescriptor const**, google::protobuf::ServiceDescriptor const**)’未定义的引用
      libcartographer.a(probability_grid_range_data_inserter_options_2d.pb.cc.o):在函数‘cartographer::mapping::proto::ProbabilityGridRangeDataInserterOptions2D::descriptor()’中:
      probability_grid_range_data_inserter_options_2d.pb.cc:(.text+0x691):对‘google::protobuf::GoogleOnceInitImpl(long*, google::protobuf::Closure*)’未定义的引用
      [223/381] Building CXX object CMakeFil...r/common/configuration_files_test.cc.o
      ninja: build stopped: subcommand failed.
      <== Failed to process package 'cartographer':
      Command '['ninja', '-j8', '-l8']' returned non-zero exit status 1
      Reproduce this error by running:
      ==> cd /home/wbb/cartographer_ws/build_isolated/cartographer && ninja -j8 -l8
      Command failed, exiting.
