    一键安装ros失败
    一键安装 ros一键安装
    969
    • 19704655431
      W
      安装出现报错
      19704655431 26863335942 2 条回复 最后回复 回复 引用 0
      • 19704655431
        W @1970465543
        @1970465543
        已经解决。
        重试安装时,注意到有个提示,按照提示执行后安装成功。虽然最后启动又有新问题,但都能百度到。小鱼牛逼,还是很方便的。
        19704655431 1 条回复 最后回复 回复 引用 0
        • 8508747438
          北道玄枫岩
          你好,你是遇到下边这种错误吗:
          下列软件包有未满足的依赖关系:
          ros-foxy-desktop : 依赖: ros-foxy-depthimage-to-laserscan 但是它将不会被安装
          依赖: ros-foxy-image-tools 但是它将不会被安装
          依赖: ros-foxy-intra-process-demo 但是它将不会被安装
          依赖: ros-foxy-pcl-conversions 但是它将不会被安装
          依赖: ros-foxy-rqt-common-plugins 但是它将不会被安装
          依赖: ros-foxy-rviz-default-plugins 但是它将不会被安装
          依赖: ros-foxy-rviz2 但是它将不会被安装
          Run CMD Task:[sudo apt install ros-foxy-desktop -y]
          [-]Result:code:100 是它将不会被安装 它将不会被安装 装
          • 26863335942
            💨 @1970465543
            @1970465543 你好,可以详细说说怎么解决的吗?我也遇到了这个问题 谢谢!
            • 17470239651
              Louis
              apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/jammy/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/jammy-updates/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/jammy-backports/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Failed to fetch https://mirrors.ustc.edu.cn/ubuntu-ports/dists/jammy-security/main/binary-amd64/Packages 404 Not Found [IP: 202.141.160.110 443]\n', 'E: Some index files failed to download. They have been ignored, or old ones used instead.\n']
              [|]libcurl3-gnutls - easy-to-use client-side URL transfer library (GnuTLS flavou[-]Result:success ansfer library (OpenSSL flavour)
              [-]Result:success e and 0 not upgraded.
              [-]Result:success
              File "/tmp/fishinstall/install.py", line 122, in <module>
              File "/tmp/fishinstall/install.py", line 114, in main
              File "/tmp/fishinstall/tools/base.py", line 1298, in run_tool_file
              File "/tmp/fishinstall/tools/tool_install_ros.py", line 390, in run
              self.install_ros()
              File "/tmp/fishinstall/tools/tool_install_ros.py", line 380, in install_ros
              self.add_key()
              File "/tmp/fishinstall/tools/tool_install_ros.py", line 172, in add_key
              AptUtils.install_pkg('gnupg2')
              File "/tmp/fishinstall/tools/base.py", line 1237, in install_pkg
              for key in dic.keys():
              AttributeError: 'NoneType' object has no attribute 'keys'
              一直是这样的 22.04 amd64
              • 19704655431
                W @1970465543
                @1970465543 不好意思铁子,已经忘记了,你重新安装,严格按照提示试一试
