    Deepin V23 beta2 一键安装ROS2失败
    一键安装 deepin
    • 1218974981
      zhjr2023
      请输入[]内的数字以选择:1
      --2023-12-11 22:45:06--  http://fishros.com/install/install1s/tools/tool_install_ros.py
      已发出 HTTP 请求,正在等待回应... 200 OK
      长度:19468 (19K) [application/octet-stream]
      /tmp/fishinstall/tools/tool 100%[=========================================>]  19.01K  --.-KB/s  用时 0.04s
      2023-12-11 22:45:06 (464 KB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros.py” [19468/19468])
      --2023-12-11 22:45:06--  http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      长度:2457 (2.4K) [application/octet-stream]
      /tmp/fishinstall/tools/tool 100%[=========================================>]   2.40K  --.-KB/s  用时 0s
      2023-12-11 22:45:06 (246 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_rosenv.py” [2457/2457])
      --2023-12-11 22:45:06--  http://fishros.com/install/install1s/tools/tool_config_system_source.py
      长度:7708 (7.5K) [application/octet-stream]
      /tmp/fishinstall/tools/tool 100%[=========================================>]   7.53K  --.-KB/s  用时 0s
      2023-12-11 22:45:07 (32.0 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_config_system_source.py” [7708/7708])
        File "/tmp/fishinstall/install.py", line 122, in <module>
        File "/tmp/fishinstall/install.py", line 114, in main
        File "/tmp/fishinstall/tools/base.py", line 1298, in run_tool_file
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 390, in run
          self.install_ros()
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 377, in install_ros
          if not self.support_install(): return False
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 279, in support_install
          if (osversion.get_codename() not in ros_dist_dic.keys()) and (osversion.get_codename() not in ros2_dist_dic.keys()):
        File "/tmp/fishinstall/tools/base.py", line 684, in get_codename
          self.detect_os()
        File "/tmp/fishinstall/tools/base.py", line 644, in detect_os
