    ros2 humble
    ros2 humble安装 roscore
    1.4k
    • 15822147101
      it was always you
      roscore时报错如下
      File "/usr/bin/roscore", line 37, in <module>
      from roslaunch.nodeprocess import DEFAULT_TIMEOUT_SIGINT, DEFAULT_TIMEOUT_SIGTERM
      File "/usr/lib/python3/dist-packages/roslaunch/init.py", line 62, in <module>
      from .scriptapi import ROSLaunch
      File "/usr/lib/python3/dist-packages/roslaunch/scriptapi.py", line 42, in <module>
      import roslaunch.parent
      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 54, in <module>
      import roslaunch.server
      File "/usr/lib/python3/dist-packages/roslaunch/server.py", line 80, in <module>
      from rosgraph_msgs.msg import Log
      ImportError: cannot import name 'Log' from 'rosgraph_msgs.msg' (/opt/ros/humble/local/lib/python3.10/dist-packages/rosgraph_msgs/msg/init.py)
      • F
        fantiming
        ros2 不用 roscore
        15822147101 1 条回复 最后回复 回复 引用 0
        • 15822147101
          it was always you @fantiming
          @fantiming ok
