    安装livox_ros_driver失败
    livoxros rosdriver
      知己
      按github上的命令安装livox_ros_driver时一切正常(已经安装了ROS(melodic)和Livox-SDK)再执行catkin_make时报错
      在96%进度时出现一大堆其他的东西最后显示
      livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/build.make:230: recipe for target 'livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/livox_ros_driver/livox_ros_driver.cpp.o' failed
      make[2]: *** [livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/livox_ros_driver/livox_ros_driver.cpp.o] Error 1
      make[2]: *** 正在等待未完成的任务....
      livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/build.make:206: recipe for target 'livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/livox_ros_driver/lddc.cpp.o' failed
      make[2]: *** [livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/livox_ros_driver/lddc.cpp.o] Error 1
      CMakeFiles/Makefile2:1012: recipe for target 'livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/all' failed
      make[1]: *** [livox_ros_driver/CMakeFiles/livox_ros_driver_node.dir/all] Error 2
      Makefile:140: recipe for target 'all' failed
      make: *** [all] Error 2
      Invoking "make -j16 -l16" failed
