    安装出错,无法安装,执行第一步自动跳出。
    手眼标定
    安装失败、ros、测试 ros、安装失败、一键安装、
    • 19775388121
      ai
        File "/tmp/fishinstall/install.py", line 123, in <module>
        File "/tmp/fishinstall/install.py", line 115, in main
        File "/tmp/fishinstall/tools/base.py", line 1297, in run_tool_file
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 393, in run
          self.install_ros()
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 380, in install_ros
          if not self.support_install(): return False
        File "/tmp/fishinstall/tools/tool_install_ros.py", line 282, in support_install
          if (osversion.get_codename() not in ros_dist_dic.keys()) and (osversion.get_codename() not in ros2_dist_dic.keys()):
        File "/tmp/fishinstall/tools/base.py", line 682, in get_codename
          self.detect_os()
        File "/tmp/fishinstall/tools/base.py", line 642, in detect_os
      tools.base.OsNotDetected: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine
      系统笔记本linux18.04,编译IMU包的时候报出TF错误,本来安装ros是成功的,我就重新一键安装,此时便出现上面的错误了,已经尝试将ubuntu更改成debian等,网上试了一堆还是不行,但是小乌龟测试均没有问题,就是roslaunch会出错。现在没法解决,之前也出现过,现在回想应该是rosdep update之后就出现这个问题,有解决方法吗?
