    使用一键安装过程中遇到程序崩溃
    一键安装 docker ros2 ubuntu24.04
    • 9
      97777777
        File "/tmp/fishinstall/tools/tool_install_ros_with_docker.py", line 254, in run
          self.install_ros_with_docker()
        File "/tmp/fishinstall/tools/tool_install_ros_with_docker.py", line 243, in install_ros_with_docker
          self.generte_command(container_name,rosname)
        File "/tmp/fishinstall/tools/tool_install_ros_with_docker.py", line 214, in generte_command
          FileUtils.new(bin_path,container_name,self.get_container_scripts(container_name,rosversion,bin_path+container_name))
        File "/tmp/fishinstall/tools/base.py", line 1220, in new
          with open(path+name,"w") as f:
      FileNotFoundError: [Errno 2] No such file or directory: '/home/ubuntu/.fishros/bin/97'
