node fishbot_motion_control 在node list里看不到
按书上代码创建node fishbot_motion_control, rclc_node_init_default 返回0,但 node listnode fishbot_motion_control 在node listcode_text allocator = rcl_get_default_allocator(); // 获取默认的内存分配器 // 3.初始化支持 rclc_support_init(&support, 0, NULL, &allocator); // 初始化支持 // 4.初始化节点 auto ret = rclc_node_init_default(&node, "fishbot_motion_control", "", &support); // 初始化节点 Serial.printf("rclc_node_init_default: ret = %d\n", ret);micro_ros_agent 日志, 看着是能正常连接并create_topic、create_publisher:
ros2 run micro_ros_agent micro_ros_agent udp4 --port 8000 [1750427414.761658] info | UDPv4AgentLinux.cpp | init | running... | port: 8000 [1750427414.761905] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4 [1750427424.983911] info | Root.cpp | create_client | create | client_key: 0x79F62086, session_id: 0x81 [1750427424.984123] info | SessionManager.hpp | establish_session | session established | client_key: 0x79F62086, address: 192.168.31.246:16415 [1750427425.044061] info | ProxyClient.cpp | create_participant | participant created | client_key: 0x79F62086, participant_id: 0x000(1) [1750427425.188799] info | ProxyClient.cpp | create_topic | topic created | client_key: 0x79F62086, topic_id: 0x000(2), participant_id: 0x000(1) [1750427425.260997] info | ProxyClient.cpp | create_subscriber | subscriber created | client_key: 0x79F62086, subscriber_id: 0x000(4), participant_id: 0x000(1) [1750427425.364820] info | ProxyClient.cpp | create_datareader | datareader created | client_key: 0x79F62086, datareader_id: 0x000(6), subscriber_id: 0x000(4) [1750427425.399368] info | ProxyClient.cpp | create_topic | topic created | client_key: 0x79F62086, topic_id: 0x001(2), participant_id: 0x000(1) [1750427425.441572] info | ProxyClient.cpp | create_publisher | publisher created | client_key: 0x79F62086, publisher_id: 0x000(3), participant_id: 0x000(1) [1750427425.454749] info | ProxyClient.cpp | create_datawriter | datawriter created | client_key: 0x79F62086, datawriter_id: 0x000(5), publisher_id: 0x000(3)node list 看不到fishbot_motion_control
********:~/studio/fishbot_control/fishbot_agent$ ros2 node list ********:~/studio/fishbot_control/fishbot_agent$ -
已解。
问题是主机和micro-ros两端ros_domain_id没对齐 -
@hury 老哥这个怎么对齐id呀,新手小白问一下
@wzn 用小鱼的配置助手配置ros2 domian id 配置为 0 和你在上位机里面的 docker里面的 ROS_DOMAIN_ID=0同样设置为0
