    rk3576搭配ubuntu20.04安装ros时出现问题,使用了各种方法均无法成功,请问应该如何解决这个问题。急求!!!!!!!!
    ros1一键安装失败 rk3576
    • X
      xiaoxin10192022
      Reading package lists... Done
      Building dependency tree
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      ros-noetic-desktop-full : Depends: ros-noetic-desktop but it is not going to be installed
      Depends: ros-noetic-perception but it is not going to be installed
      Depends: ros-noetic-simulators but it is not going to be installed
      Depends: ros-noetic-urdf-sim-tutorial but it is not going to be installed
      E: Unable to correct problems, you have held broken packages.
      [-][2.51s] CMD Result:code:100
