使用一键安装rosdepc过程中遇到程序崩溃
Traceback (most recent call last): File "/tmp/fishinstall/install.py", line 134, in <module> main() File "/tmp/fishinstall/install.py", line 123, in main run_tool_file(tools[code]['tool'].replace("/",".")) File "/tmp/fishinstall/tools/base.py", line 1478, in run_tool_file if tool.run()==False: return False File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 94, in run self.install_rosdepc() File "/tmp/fishinstall/tools/tool_config_rosdep.py", line 85, in install_rosdepc PrintUtils.print_warning("安装失败,尝试使用其他方式安装...") AttributeError: type object 'PrintUtils' has no attribute 'print_warning'
444
日志上传失败,若还需反馈请手动发帖!
