    wsl安装ros2失败:依赖问题?
    ros2 humble安装 wsl2
    2.4k
    • P
      promisessr
      ~$ sudo apt-get install ros-humble-desktop
      Reading package lists... Done
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      libasound2t64 : Breaks: libasound2 (< 1.2.11-1ubuntu0.1)
      libboost-mpi-python1.74.0 : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      libcurl4-openssl-dev : Depends: libcurl4 (= 7.81.0-1ubuntu1.20)
      libdrm-dev : Depends: libdrm2 (= 2.4.113-2~ubuntu0.22.04.1) but 2.4.122-1~ubuntu0.24.04.1 is to be installed
      Depends: libdrm-intel1 (= 2.4.113-2~ubuntu0.22.04.1) but 2.4.122-1~ubuntu0.24.04.1 is to be installed
      Depends: libdrm-radeon1 (= 2.4.113-2~ubuntu0.22.04.1) but 2.4.122-1~ubuntu0.24.04.1 is to be installed
      Depends: libdrm-nouveau2 (= 2.4.113-2~ubuntu0.22.04.1) but 2.4.122-1~ubuntu0.24.04.1 is to be installed
      Depends: libdrm-amdgpu1 (= 2.4.113-2~ubuntu0.22.04.1) but 2.4.122-1~ubuntu0.24.04.1 is to be installed
      libegl-dev : Depends: libegl1 (= 1.4.0-1) but 1.7.0-1build1 is to be installed
      libexif-dev : Depends: libexif12 (= 0.6.24-1build1) but 0.6.24-1build2 is to be installed
      Recommends: libexif-doc (= 0.6.24-1build1) but it is not going to be installed
      libgbm-dev : Depends: libgbm1 (= 23.2.1-1ubuntu3.1~22.04.3) but 25.0.7-0ubuntu0.24.04.1 is to be installed
      libgdal-dev : Depends: libnetcdf-dev but it is not installable
      libgl-dev : Depends: libgl1 (= 1.4.0-1) but 1.7.0-1build1 is to be installed
      Depends: libglx-dev but it is not going to be installed
      libgles-dev : Depends: libgles1 (= 1.4.0-1) but it is not going to be installed
      Depends: libgles2 (= 1.4.0-1) but 1.7.0-1build1 is to be installed
      libglvnd-dev : Depends: libglvnd0 (= 1.4.0-1) but 1.7.0-1build1 is to be installed
      Depends: libglx-dev (>= 1.3.0-1) but it is not going to be installed
      libgphoto2-6t64 : Breaks: libgphoto2-6 (< 2.5.31-2.1build2)
      Recommends: libgphoto2-l10n (= 2.5.31-2.1build2) but 2.5.27-1build2 is to be installed
      libhdf4-alt-dev : Depends: libnetcdf-dev but it is not installable
      libhdf5-dev : Depends: libssl-dev but it is not installable
      libhdf5-openmpi-dev : Depends: libssl-dev but it is not installable
      libheif-dev : Depends: libheif1 (= 1.12.0-2build1) but 1.17.6-1ubuntu4.1 is to be installed
      Depends: libaom-dev but it is not going to be installed
      Depends: libde265-dev (>= 1.0.7) but it is not going to be installed
      Depends: libx265-dev but it is not going to be installed
      libibus-1.0-dev : Depends: gir1.2-ibus-1.0 (= 1.5.26-4) but 1.5.29-2 is to be installed
      Depends: libglib2.0-dev but it is not going to be installed
      Depends: libibus-1.0-5 (= 1.5.26-4) but 1.5.29-2 is to be installed
      libibverbs-dev : Depends: libibverbs1 (= 39.0-1) but 50.0-2ubuntu0.2 is to be installed
      Depends: libnl-3-dev but it is not going to be installed
      Depends: libnl-route-3-dev but it is not going to be installed
      libltdl-dev : Depends: libltdl7 (= 2.4.6-15build2) but 2.4.7-7build1 is to be installed
      Recommends: libtool but it is not going to be installed
      liblzma-dev : Depends: liblzma5 (= 5.2.5-2ubuntu1) but 5.6.1+really5.4.5-1ubuntu0.2 is to be installed
      libmysqlclient-dev : Depends: libssl-dev but it is not installable
      libnetcdf-cxx-legacy-dev : Depends: libnetcdf-dev but it is not installable
      libopengl0 : Depends: libglvnd0 (= 1.4.0-1) but 1.7.0-1build1 is to be installed
      libopenjp2-7-dev : Depends: libopenjp2-7 (= 2.4.0-6ubuntu0.3) but 2.5.0-2ubuntu0.3 is to be installed
      libpcre2-dev : Depends: libpcre2-8-0 (= 10.39-3ubuntu0.1) but 10.42-4ubuntu2.1 is to be installed
      libpng-dev : Depends: libpng16-16 (= 1.6.37-3build5)
      Recommends: libpng-tools but it is not installable
      libpq-dev : Depends: libssl-dev but it is not installable
      libpulse-dev : Depends: libpulse0 (= 1:15.99.1+dfsg1-1ubuntu2.2) but 1:16.1+dfsg1-2ubuntu10.1 is to be installed
      Depends: libpulse-mainloop-glib0 (= 1:15.99.1+dfsg1-1ubuntu2.2) but 1:16.1+dfsg1-2ubuntu10.1 is to be installed
      libqt5designer5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      libqt5gui5-gles (>= 5.14.1) but it is not installable
      libqt5designercomponents5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      libqt5help5 : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
      libqt5gui5-gles (>= 5.0.2) but it is not installable
      libqt5printsupport5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      libqt5quickshapes5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      Depends: libqt5quick5 (>= 5.14.1) but it is not installable or
      libqt5quick5-gles (>= 5.14.1) but it is not installable
      libqt5quicktest5 : Depends: libqt5gui5 (>= 5.12.2) but it is not installable or
      libqt5gui5-gles (>= 5.12.2) but it is not installable
      Depends: libqt5quick5 (>= 5.0.2) but it is not installable or
      libqt5quick5-gles (>= 5.0.2) but it is not installable
      libqt5quickwidgets5 : Depends: libqt5gui5 (>= 5.10.0) but it is not installable or
      libqt5gui5-gles (>= 5.10.0) but it is not installable
      Depends: libqt5quick5 (>= 5.15.1) but it is not installable or
      libqt5quick5-gles (>= 5.15.1) but it is not installable
      libqt5svg5 : Depends: libqt5gui5 (>= 5.15.3+dfsg~) but it is not installable or
      libqt5gui5-gles (>= 5.15.3+dfsg~) but it is not installable
      libqt5webkit5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      Depends: libqt5quick5 (>= 5.15.3+dfsg~) but it is not installable or
      libqt5quick5-gles (>= 5.15.3+dfsg~) but it is not installable
      libqt5widgets5 : Depends: libqt5gui5 (>= 5.15.1) but it is not installable or
      libqt5gui5-gles (>= 5.15.1) but it is not installable
      libshiboken2-py3-5.15 : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      libsm-dev : Depends: libsm6 (= 2:1.2.3-1build2) but 2:1.2.3-1build3 is to be installed
      Depends: libice-dev (>= 1:1.0.0-1) but it is not going to be installed
      libudev-dev : Depends: libudev1 (= 249.11-0ubuntu3.16) but 255.4-1ubuntu8.10 is to be installed
      libvtk9-dev : Depends: libnetcdf-dev but it is not installable
      libvtk9-qt-dev : Depends: libqt5opengl5-dev but it is not installable
      libvtk9.1-qt : Depends: libqt5gui5 (>= 5.11.0~rc1) but it is not installable or
      libqt5gui5-gles (>= 5.11.0~rc1) but it is not installable
      libvulkan-dev : Depends: libvulkan1 (= 1.3.204.1-2) but 1.3.275.0-1build1 is to be installed
      libwayland-dev : Depends: libwayland-client0 (= 1.20.0-1ubuntu0.1) but 1.22.0-2.1build1 is to be installed
      Depends: libwayland-server0 (= 1.20.0-1ubuntu0.1) but 1.22.0-2.1build1 is to be installed
      Depends: libwayland-cursor0 (= 1.20.0-1ubuntu0.1) but 1.22.0-2.1build1 is to be installed
      Depends: libwayland-egl1 (= 1.20.0-1ubuntu0.1) but 1.22.0-2.1build1 is to be installed
      libwebp-dev : Depends: libwebp7 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be installed
      Depends: libwebpmux3 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be installed
      Depends: libwebpdemux2 (= 1.2.2-2ubuntu0.22.04.2) but 1.3.2-0.4build3 is to be installed
      libx11-dev : Depends: libx11-6 (= 2:1.7.5-1ubuntu0.3) but 2:1.8.7-1build1 is to be installed
      Depends: libxcb1-dev but it is not going to be installed
      libxaw7-dev : Depends: libxaw7 (= 2:1.0.14-1) but 2:1.0.14-1build2 is to be installed
      Depends: libxmu-dev but it is not going to be installed
      Depends: libxpm-dev but it is not going to be installed
      libxft-dev : Depends: libfontconfig1-dev
      libxkbcommon-dev : Depends: libxkbcommon0 (= 1.4.0-1) but 1.6.0-1build1 is to be installed
      libxss-dev : Depends: libxss1 (= 1:1.2.3-1build2) but 1:1.2.3-1build3 is to be installed
      libxt6t64 : Breaks: libxt6 (< 1:1.2.1-1.2build1)
      libzstd-dev : Depends: libzstd1 (= 1.4.8+dfsg-3build1) but 1.5.5+dfsg2-2build1.1 is to be installed
      python3-lxml : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      Recommends: python3-bs4 but it is not going to be installed
      Recommends: python3-html5lib but it is not going to be installed
      python3-matplotlib : Depends: python3-pil.imagetk but it is not going to be installed
      Depends: python3-fonttools but it is not going to be installed
      Depends: python3-kiwisolver but it is not going to be installed
      Recommends: python3-tk but it is not going to be installed
      python3-numpy : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-opencv : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-pil : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      Recommends: python3-olefile but it is not going to be installed
      python3-pykdl : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-pyqt5 : Depends: libqt5gui5 (>= 5.1.0) but it is not installable
      python3-pyqt5.qtsvg : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
      python3-pyqt5.sip : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-pyside2.qtsvg : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      Depends: libqt5gui5 (>= 5.15) but it is not installable or
      libqt5gui5-gles (>= 5.15) but it is not installable
      Depends: python3-pyside2.qtwidgets but it is not going to be installed
      Depends: python3-pyside2.qtgui but it is not going to be installed
      Depends: python3-pyside2.qtcore but it is not going to be installed
      python3-sip : Depends: python3 (< 3.11) but 3.12.3-0ubuntu2 is to be installed
      python3-vtk9 : Depends: python3-mpi4py but it is not going to be installed
      qhelpgenerator-qt5 : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
      qt5-assistant : Depends: libqt5gui5 (>= 5.11.0~rc1) but it is not installable or
      qt5-qmltooling-plugins : Depends: libqt5gui5 (>= 5.9.0~beta) but it is not installable or
      libqt5gui5-gles (>= 5.9.0~beta) but it is not installable
      Depends: libqt5quick5 (>= 5.12.2) but it is not installable or
      libqt5quick5-gles (>= 5.12.2) but it is not installable
      qtbase5-dev : Depends: libqt5gui5 (= 5.15.3+dfsg-2ubuntu0.2) but it is not installable
      Recommends: libqt5opengl5-dev (= 5.15.3+dfsg-2ubuntu0.2) but it is not installable
      qtdeclarative5-dev : Depends: libqt5quick5 (= 5.15.3+dfsg-1) but it is not installable or
      libqt5quick5-gles (>= 5.15) but it is not installable
      Depends: libqt5quickparticles5 (= 5.15.3+dfsg-1) but it is not installable or
      libqt5quickparticles5-gles (>= 5.15) but it is not installable
      qtdeclarative5-dev-tools : Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
      libqt5gui5-gles (>= 5.2.0) but it is not installable
      Depends: libqt5quick5 (>= 5.6.1) but it is not installable or
      libqt5quick5-gles (>= 5.6.1) but it is not installable
      qttools5-dev-tools : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      ros-humble-demo-nodes-cpp-native : Depends: ros-humble-fastrtps but it is not installable
      Depends: ros-humble-rmw-fastrtps-cpp but it is not installable
      ros-humble-rqt-image-view : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
      ros-humble-rviz-assimp-vendor : Depends: libassimp-dev but it is not installable
      ros-humble-rviz-common : Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
      Depends: libqt5gui5 but it is not installable
      Depends: libqt5opengl5 but it is not installable
      ros-humble-rviz-default-plugins : Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
      ros-humble-rviz-rendering : Depends: libqt5gui5 (>= 5.5.0) but it is not installable or
      libqt5gui5-gles (>= 5.5.0) but it is not installable
      ros-humble-turtlesim : Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
      tcl8.6-dev : Depends: libtcl8.6 (= 8.6.12+dfsg-1build1) but 8.6.14+dfsg-1build1 is to be installed
      E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
      • G
        GreatKowal
        我用wsl2安装成功了,但是因为Ubuntu版本不同,我安装了jazzy的ros2.
          2200623940 @promisessr
          @promisessr 我 Ubuntu22.04,用一键安装指令安装humble是没有问题的
