    cartographer建图失败,报警告:
    cartographer建图 galactic ubuntu 20.04
    1.9k
      LYPRC
      系统配置
      vm 安装 Ubuntu 20.04.6 LTS
      Distributor ID:	Ubuntu
      Description:	Ubuntu 20.04.6 LTS
      Release:	20.04
      Codename:	focal
      ros2版本
      小鱼的一键安装
      galactic
      同时还安装了,ros的noetic
      情景回放:
      根据CSDN小鱼的教程,
      Gazebo仿真环境的搭建及运行
      以下是俺自己调整过的文件夹树、配置文件、运行结果
      文件夹树
          ├── lyprc_description
          │   ├── launch
          │   │   ├── display_rviz2.launch.py
          │   │   └── gazebo.launch.py
          │   ├── lyprc01.rviz
          │   ├── lyprc_description
          │   │   └── __init__.py
          │   ├── package.xml
          │   ├── resource
          │   │   └── lyprc_description
          │   ├── setup.cfg
          │   ├── setup.py
          │   ├── test
          │   │   ├── test_copyright.py
          │   │   ├── test_flake8.py
          │   │   └── test_pep257.py
          │   ├── urdf
          │   │   ├── lyprc_base.urdf
          │   │   └── lyprc_gazebo.urdf
          │   └── world
          │       └── myhouse01.world
      gazebo.launch.py文件
      import os
          robot_name_in_model = 'lyprcbot'
          package_name = 'lyprc_description'
          urdf_name = "lyprc_gazebo.urdf"
          world_name = "myhouse01.world"
          ld = LaunchDescription()
          gazebo_world_path = os.path.join(pkg_share, f'world/{world_name}')
          # Start Gazebo server
              cmd=['gazebo', '--verbose','-s', 'libgazebo_ros_init.so', '-s', 'libgazebo_ros_factory.so', gazebo_world_path],
              output='screen')
          # start_gazebo_cmd =  ExecuteProcess(
          #     cmd=['gazebo', '--verbose','-s', 'libgazebo_ros_init.so', '-s', 'libgazebo_ros_factory.so'],
          #     output='screen')
          # Launch the robot
          spawn_entity_cmd = Node(
              package='gazebo_ros',
              executable='spawn_entity.py',
              arguments=['-entity', robot_name_in_model,  '-file', urdf_model_path ], output='screen',
          # Start Robot State publisher
          start_robot_state_publisher_cmd = Node(
              arguments=[urdf_model_path],
          # Launch RViz
          start_rviz_cmd = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen',
              arguments=['-d', "/home/lyprc/LOVE/ROStest/ROSLAM_ws/src/lyprc_description/lyprc01.rviz"],
          ld.add_action(spawn_entity_cmd)
          ld.add_action(start_robot_state_publisher_cmd)
          ld.add_action(start_rviz_cmd)
          return ld
      lyprc_gazebo.urdf文件
      <?xml version="1.0"?>
      <robot name="lyprc">
        <!-- Robot Footprint -->
        <link name="base_footprint"/>
          <child link="base_link"/>
          <origin xyz="0.0 0.0 0.076" rpy="0 0 0"/>
        </joint>
        <!-- base link -->
        <link name="base_link">
        	<visual>
            <geometry>
      		<cylinder length="0.12" radius="0.10"/>
            </geometry>
            <material name="blue">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
            </material>
          </collision>
          <inertial>
            <mass value="0.2"/>
            <inertia ixx="0.0122666" ixy="0" ixz="0" iyy="0.0122666" iyz="0" izz="0.02"/>
          </inertial>
        </link>
        <!-- laser link -->
        <link name="laser_link">
          <visual>
            <geometry>
            </geometry>
            <material name="black">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
            </material>
          </collision>
          <inertial>
          <mass value="0.1"/>
            <inertia ixx="0.000190416666667" ixy="0" ixz="0" iyy="0.0001904" iyz="0" izz="0.00036"/>
          </inertial>
        </link>
        <!-- laser joint -->
            <parent link="base_link" />
            <child link="laser_link" />
            <origin xyz="0 0 0.075" />
        </joint>
        <link name="imu_link">
        	<visual>
            <geometry>
      		    <box size="0.02 0.02 0.02"/>
            </geometry>
          </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
          <inertial>
            <mass value="0.1"/>
            </inertial>
        </link>
        <!-- imu joint -->
            <child link="imu_link" />
            <origin xyz="0 0 0.02" />
        </joint>
        <link name="left_wheel_link">
            <visual>
              <geometry>
                <cylinder length="0.04" radius="0.032"/>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
              <mass value="0.2"/>
              </inertial>
        </link>
            <visual>
              <geometry>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
            <mass value="0.2"/>
          </inertial>
        </link>
            <origin xyz="-0.02 0.10 -0.06" />
            <axis xyz="0 1 0" />
        </joint>
            <origin xyz="-0.02 -0.10 -0.06" />
        </joint>
        <link name="caster_link">
            <visual>
              <geometry>
                  <sphere radius="0.016"/>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
            <mass value="0.02"/>
          </inertial>
        </link>
        <joint name="caster_joint" type="fixed">
            <child link="caster_link" />
            <origin xyz="0.06 0.0 -0.076" />
        </joint>
        <gazebo reference="caster_link">
        </gazebo>
          <mu1 value="0.0"/>
          <mu2 value="0.0"/>
          <kp value="1000000.0" />
          <kd value="10.0" />
          <!-- <fdir1 value="0 0 1"/> -->
        </gazebo>
        <gazebo>
                <ros>
                  <namespace>/</namespace>
                </ros>
                <update_rate>30</update_rate>
                <!-- wheels -->
                <left_joint>left_wheel_joint</left_joint>
                <right_joint>right_wheel_joint</right_joint>
                <!-- kinematics -->
                <!-- limits -->
                <!-- output -->
                <publish_wheel_tf>false</publish_wheel_tf>
            </plugin>
            <plugin name="lyprc_joint_state" filename="libgazebo_ros_joint_state_publisher.so">
              <ros>
                <remapping>~/out:=joint_states</remapping>
              </ros>
              <joint_name>right_wheel_joint</joint_name>
              <joint_name>left_wheel_joint</joint_name>
            </plugin>
            </gazebo>
            </gazebo>
          <gazebo reference="imu_link">
            <sensor name="imu_sensor" type="imu">
            <plugin filename="libgazebo_ros_imu_sensor.so" name="imu_plugin">
                <ros>
                  <remapping>~/out:=imu</remapping>
                </ros>
                <initial_orientation_as_reference>false</initial_orientation_as_reference>
              </plugin>
              <always_on>true</always_on>
              <update_rate>100</update_rate>
              <visualize>true</visualize>
              <imu>
                <angular_velocity>
                  <x>
                    <noise type="gaussian">
                      <mean>0.0</mean>
                      <stddev>2e-4</stddev>
                      <bias_mean>0.0000075</bias_mean>
                      <bias_stddev>0.0000008</bias_stddev>
                    </noise>
                  </x>
                  <y>
                      <mean>0.0</mean>
                    </noise>
                  </y>
                  <z>
                      <mean>0.0</mean>
                    </noise>
                  </z>
                </angular_velocity>
                <linear_acceleration>
                  <x>
                      <mean>0.0</mean>
                      <stddev>1.7e-2</stddev>
                      <bias_mean>0.1</bias_mean>
                      <bias_stddev>0.001</bias_stddev>
                    </noise>
                  </x>
                  <y>
                      <mean>0.0</mean>
                    </noise>
                  </y>
                  <z>
                      <mean>0.0</mean>
                    </noise>
                  </z>
                </linear_acceleration>
              </imu>
            </sensor>
          </gazebo>
            <sensor name="laser_sensor" type="ray">
            <update_rate>5</update_rate>
            <pose>0 0 0.075 0 0 0</pose>
            <ray>
                <scan>
                  <horizontal>
                    <samples>360</samples>
                    <resolution>1.000000</resolution>
                  </horizontal>
                </scan>
                <range>
                  <min>0.120000</min>
                  <max>3.5</max>
                  <resolution>0.015000</resolution>
                </range>
                <noise>
                  <type>gaussian</type>
                  <mean>0.0</mean>
                  <stddev>0.01</stddev>
                </noise>
            </ray>
              <ros>
                <!-- <namespace>/tb3</namespace> -->
              </ros>
            </plugin>
            </sensor>
          </gazebo>
      </robot>
      gazebo仿真运行效果
      运行指令
      ros:galactic(1) noetic(2) ?
      lyprc@lyprc-vm-ubuntu2004:~/LOVE/ROStest/ROSLAM_ws$ colcon build
      Starting >>> absl
      Starting >>> lyprc_cartographer
      Starting >>> lyprc_description
      Finished <<< lyprc_cartographer [0.58s]
      Finished <<< absl [0.78s]
      Finished <<< lyprc_description [1.62s]
      Summary: 3 packages finished [2.61s]
      lyprc@lyprc-vm-ubuntu2004:~/LOVE/ROStest/ROSLAM_ws$ source install/setup.bash
      lyprc@lyprc-vm-ubuntu2004:~/LOVE/ROStest/ROSLAM_ws$ ros2 launch lyprc_description gazebo.launch.py
      [INFO] [launch]: All log files can be found below /home/lyprc/.ros/log/2024-04-03-15-01-11-164272-lyprc-vm-ubuntu2004-2655
      [INFO] [gazebo-1]: process started with pid [2657]
      [INFO] [spawn_entity.py-2]: process started with pid [2659]
      [INFO] [robot_state_publisher-3]: process started with pid [2661]
      [INFO] [rviz2-4]: process started with pid [2663]
      [robot_state_publisher-3] [WARN] [1712127671.602336654] [robot_state_publisher]: No robot_description parameter, but command-line argument available.  Assuming argument is name of URDF file.  This backwards compatibility fallback will be removed in the future.
      [robot_state_publisher-3] Link base_link had 5 children
      [robot_state_publisher-3] Link caster_link had 0 children
      [robot_state_publisher-3] Link imu_link had 0 children
      [robot_state_publisher-3] Link laser_link had 0 children
      [robot_state_publisher-3] Link left_wheel_link had 0 children
      [robot_state_publisher-3] Link right_wheel_link had 0 children
      [robot_state_publisher-3] [INFO] [1712127671.673373107] [robot_state_publisher]: got segment base_footprint
      [robot_state_publisher-3] [INFO] [1712127671.673469172] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-3] [INFO] [1712127671.673530713] [robot_state_publisher]: got segment caster_link
      [robot_state_publisher-3] [INFO] [1712127671.673591054] [robot_state_publisher]: got segment imu_link
      [robot_state_publisher-3] [INFO] [1712127671.673651094] [robot_state_publisher]: got segment laser_link
      [robot_state_publisher-3] [INFO] [1712127671.673711435] [robot_state_publisher]: got segment left_wheel_link
      [robot_state_publisher-3] [INFO] [1712127671.673771074] [robot_state_publisher]: got segment right_wheel_link
      [spawn_entity.py-2] [INFO] [1712127672.371026930] [spawn_entity]: Spawn Entity started
      [spawn_entity.py-2] [INFO] [1712127672.371484217] [spawn_entity]: Loading entity XML from file /home/lyprc/LOVE/ROStest/ROSLAM_ws/install/lyprc_description/share/lyprc_description/urdf/lyprc_gazebo.urdf
      [spawn_entity.py-2] [INFO] [1712127672.377082939] [spawn_entity]: Waiting for service /spawn_entity, timeout = 5
      [spawn_entity.py-2] [INFO] [1712127672.377476486] [spawn_entity]: Waiting for service /spawn_entity
      [rviz2-4] [INFO] [1712127672.959204836] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-4] [INFO] [1712127672.960361664] [rviz2]: OpenGl version: 3.3 (GLSL 3.3)
      [rviz2-4] [INFO] [1712127673.082845510] [rviz2]: Stereo is NOT SUPPORTED
      [gazebo-1] Gazebo multi-robot simulator, version 11.11.0
      [gazebo-1] Copyright (C) 2012 Open Source Robotics Foundation.
      [gazebo-1] Released under the Apache 2 License.
      [gazebo-1] http://gazebosim.org
      [gazebo-1]
      [gazebo-1]
      [rviz2-4] Warning: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [rviz2-4]          at line 156 in /tmp/binarydeb/ros-galactic-tf2-0.17.5/src/buffer_core.cpp
      。。。。。。。好多([rviz2-4]          at line 156...)
      大哥看这里
      [spawn_entity.py-2] [INFO] [1712127675.267688990] [spawn_entity]: Spawn status: Entity pushed to spawn queue, but spawn service timed outwaiting for entity to appear in simulation under the name [lyprcbot]
      [spawn_entity.py-2] [ERROR] [1712127675.268074590] [spawn_entity]: Spawn service failed. Exiting.
      [ERROR] [spawn_entity.py-2]: process has died [pid 2659, exit code 1, cmd '/opt/ros/galactic/lib/gazebo_ros/spawn_entity.py -entity lyprcbot -file /home/lyprc/LOVE/ROStest/ROSLAM_ws/install/lyprc_description/share/lyprc_description/urdf/lyprc_gazebo.urdf --ros-args'].
      [gazebo-1] [INFO] [1712127675.927765017] [diff_drive]: Wheel pair 1 separation set to [0.200000m]
      [gazebo-1] [INFO] [1712127675.930377570] [diff_drive]: Wheel pair 1 diameter set to [0.065000m]
      [gazebo-1] [INFO] [1712127675.933248258] [diff_drive]: Subscribed to [/cmd_vel]
      [gazebo-1] [INFO] [1712127675.938882877] [diff_drive]: Advertise odometry on [/odom]
      [gazebo-1] [INFO] [1712127675.943610027] [diff_drive]: Publishing odom transforms between [odom] and [base_footprint]
      [gazebo-1] [INFO] [1712127675.977996645] [lyprc_joint_state]: Going to publish joint [right_wheel_joint]
      [gazebo-1] [INFO] [1712127675.978190445] [lyprc_joint_state]: Going to publish joint [left_wheel_joint]
      [gazebo-1] [Msg] Waiting for master.
      [gazebo-1] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
      [gazebo-1] [Msg] Publicized address: 192.168.164.130
      [gazebo-1] context mismatch in svga_surface_destroy
      [rviz2-4] [INFO] [1712127686.796322989] [rviz2]: Message Filter dropping message: frame 'laser_link' at time 255.566 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
      [gazebo-1]
      [gazebo-1] libcurl: (35) OpenSSL SSL_connect: 连接被对方重设 in connection to fuel.ignitionrobotics.org:443
      [gazebo-1]
      [gazebo-1] libcurl: (7) Failed to connect to fuel.gazebosim.org port 443: 拒绝连接
      gazebo效果
      rviz 效果
      tf树图
      订阅图
      gazebo仿真的主要警告
      安装配置运行Cartographer
      安装是采取小鱼的一键安装
      文件夹树
      ├── lyprc_cartographer
      │   ├── CMakeLists.txt
      │   ├── config
      │   │   └── lyprc_2d.lua
      │   ├── include
      │   │   └── lyprc_cartographer
      │   ├── launch
      │   │   └── cartographer.launch.py
      │   ├── package.xml
      │   ├── rviz
      │   └── src
      配置文件
      import os
          # 定位到功能包的地址
          pkg_share = FindPackageShare(package='lyprc_cartographer').find('lyprc_cartographer')
          #=====================运行节点需要的配置=======================================================================
          # 是否使用仿真时间,我们用gazebo,这里设置成true
          use_sim_time = LaunchConfiguration('use_sim_time', default='true')
          # 地图的分辨率
          resolution = LaunchConfiguration('resolution', default='0.05')
          # 地图的发布周期
          publish_period_sec = LaunchConfiguration('publish_period_sec', default='1.0')
          # 配置文件夹路径
          configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
          # 配置文件
          configuration_basename = LaunchConfiguration('configuration_basename', default='lyprc_2d.lua')
          rviz_config_dir = os.path.join(pkg_share, 'config')+"/cartographer.rviz"
          print(f"rviz config in {rviz_config_dir}")
          #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
          cartographer_node = Node(
              package='cartographer_ros',
              executable='cartographer_node',
              name='cartographer_node',
              output='screen',
              arguments=['-configuration_directory', configuration_directory,
                         '-configuration_basename', configuration_basename],
              # remappings = [('scan','/laser')],
          cartographer_occupancy_grid_node = Node(
              executable='occupancy_grid_node',
              name='occupancy_grid_node',
              output='screen',
              arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec],
          rviz_node = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen',
          #===============================================定义启动文件========================================================
          ld.add_action(cartographer_node)
          ld.add_action(cartographer_occupancy_grid_node)
          ld.add_action(rviz_node)
          return ld
      lyprc_2d.lua
      include "map_builder.lua"
      include "trajectory_builder.lua"
      options = {
        map_builder = MAP_BUILDER,
        trajectory_builder = TRAJECTORY_BUILDER,
        map_frame = "map",
        tracking_frame = "base_link",
        -- base_link改为odom,发布map到odom之间的位姿态
        published_frame = "odom",
        odom_frame = "odom",
        -- true改为false,不用提供里程计数据
        provide_odom_frame = false,
        -- false改为true,仅发布2D位资
        publish_frame_projected_to_2d = true,
        -- false改为true,使用里程计数据
        use_odometry = true,
        use_nav_sat = false,
        use_landmarks = false,
        -- 0改为1,使用一个雷达
        num_laser_scans = 1,
        -- 1改为0,不使用多波雷达
        num_multi_echo_laser_scans = 0,
        -- 10改为1,1/1=1等于不分割
        num_subdivisions_per_laser_scan = 1,
        num_point_clouds = 0,
        lookup_transform_timeout_sec = 0.2,
        submap_publish_period_sec = 0.3,
        pose_publish_period_sec = 5e-3,
        trajectory_publish_period_sec = 30e-3,
        rangefinder_sampling_ratio = 1.,
        odometry_sampling_ratio = 1.,
        fixed_frame_pose_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
        landmarks_sampling_ratio = 1.,
      -- false改为true,启动2D SLAM
      MAP_BUILDER.use_trajectory_builder_2d = true
      -- 0改成0.10,比机器人半径小的都忽略
      TRAJECTORY_BUILDER_2D.min_range = 0.10
      -- 30改成3.5,限制在雷达最大扫描范围内,越小一般越精确些
      TRAJECTORY_BUILDER_2D.max_range = 3.5
      -- 5改成3,传感器数据超出有效范围最大值
      TRAJECTORY_BUILDER_2D.missing_data_ray_length = 3.
      -- true改成false,不使用IMU数据,大家可以开启,然后对比下效果
      TRAJECTORY_BUILDER_2D.use_imu_data = false
      -- false改成true,使用实时回环检测来进行前端的扫描匹配
      TRAJECTORY_BUILDER_2D.use_online_correlative_scan_matching = true
      -- 1.0改成0.1,提高对运动的敏感度
      TRAJECTORY_BUILDER_2D.motion_filter.max_angle_radians = math.rad(0.1)
      -- 0.55改成0.65,Fast csm的最低分数,高于此分数才进行优化。
      POSE_GRAPH.constraint_builder.min_score = 0.65
      --0.6改成0.7,全局定位最小分数,低于此分数则认为目前全局定位不准确
      POSE_GRAPH.constraint_builder.global_localization_min_score = 0.7
      -- 设置0可关闭全局SLAM
      -- POSE_GRAPH.optimize_every_n_nodes = 0
      return options
      运行指令及效果
      Starting >>> absl
      Finished <<< lyprc_cartographer [0.78s]
      Finished <<< absl [1.05s]
      Finished <<< lyprc_description [1.54s]
      Summary: 3 packages finished [2.09s]
      lyprc@lyprc-vm-ubuntu2004:~/LOVE/ROStest/ROSLAM_ws$ ros2 launch lyprc_cartographer cartographer.launch.py
      [INFO] [launch]: All log files can be found below /home/lyprc/.ros/log/2024-04-03-15-57-20-722215-lyprc-vm-ubuntu2004-15614
      rviz config in /home/lyprc/LOVE/ROStest/ROSLAM_ws/install/lyprc_cartographer/share/lyprc_cartographer/config/cartographer.rviz
      [INFO] [cartographer_node-1]: process started with pid [15622]
      [INFO] [occupancy_grid_node-2]: process started with pid [15624]
      [INFO] [rviz2-3]: process started with pid [15626]
      [cartographer_node-1] [INFO] [1712131041.004654099] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/home/lyprc/LOVE/ROStest/ROSLAM_ws/install/lyprc_cartographer/share/lyprc_cartographer/config/lyprc_2d.lua' for 'lyprc_2d.lua'.
      [cartographer_node-1] [INFO] [1712131041.005447761] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
      [cartographer_node-1] [INFO] [1712131041.005544856] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
      [cartographer_node-1] [INFO] [1712131041.005660751] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
      [cartographer_node-1] [INFO] [1712131041.005730147] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
      [cartographer_node-1] [INFO] [1712131041.006216924] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
      [cartographer_node-1] [INFO] [1712131041.006685002] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
      [cartographer_node-1] [INFO] [1712131041.007238775] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
      [cartographer_node-1] [INFO] [1712131041.007327371] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
      [cartographer_node-1] [INFO] [1712131041.007480964] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
      [cartographer_node-1] [INFO] [1712131041.007553060] [cartographer_ros]: I0403 15:57:21.000000 15622 configuration_file_resolver.cc:41] Found '/opt/ros/galactic/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
      [cartographer_node-1] [INFO] [1712131041.148905592] [cartographer_ros]: I0403 15:57:21.000000 15622 submap_2d.cc:187] Added submap 1
      [cartographer_node-1] [INFO] [1712131041.149095083] [cartographer_ros]: I0403 15:57:21.000000 15622 map_builder_bridge.cc:132] Added trajectory with ID '0'.
      [cartographer_node-1] Warning: Invalid frame ID "base_link" passed to canTransform argument target_frame - frame does not exist
      [cartographer_node-1]          at line 156 in /tmp/binarydeb/ros-galactic-tf2-0.17.5/src/buffer_core.cpp
      [cartographer_node-1] [INFO] [1712131041.208839523] [cartographer_ros]: I0403 15:57:21.000000 15622 ordered_multi_queue.cc:172] All sensor data for trajectory 0 is available starting at '621355988732800000'.
      [cartographer_node-1] [INFO] [1712131041.209073512] [cartographer_ros]: I0403 15:57:21.000000 15622 local_trajectory_builder_2d.cc:295] Extrapolator not yet initialized.
      [cartographer_node-1] [WARN] [1712131041.211820980] [cartographer_ros]: W0403 15:57:21.000000 15622 pose_extrapolator.cc:168] Queue too short for velocity estimation. Queue duration: 0 ms
      [occupancy_grid_node-2] [WARN] [1712131042.003545074] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      [rviz2-3] [INFO] [1712131042.605491716] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-3] [INFO] [1712131042.605837599] [rviz2]: OpenGl version: 3.3 (GLSL 3.3)
      [rviz2-3] [INFO] [1712131042.720081141] [rviz2]: Stereo is NOT SUPPORTED
      [occupancy_grid_node-2] [WARN] [1712131043.003230614] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      [occupancy_grid_node-2] [WARN] [1712131044.003080849] [occupancy_grid_node]: submap_slices and last_frame_id is empty
      rviz和tf树及订阅关系图
      错误表现 :运行slam后的rviz里的map显示Frame [map] does not exist
      框架[map]不存在
      球球各位好心人麻烦给小弟看看吧,小弟已经被折磨死了
        LYPRC
        cartographer警告:[occupancy_grid_node-2] [WARN] [1712131755.556136200] [occupancy_grid_node]: submap_slices and last_frame_id is empty
          LYPRC
          激光雷达数据和odom数据
          ros2 topic echo /scan
          header:
            stamp:
              sec: 2746
              nanosec: 236000000
            frame_id: laser_link
          angle_min: 0.0
          angle_max: 6.28000020980835
          angle_increment: 0.01749303564429283
          time_increment: 0.0
          scan_time: 0.0
          range_min: 0.11999999731779099
          range_max: 3.5
          ranges:
          - 0.1357576549053192
          - 0.13274267315864563
          - 0.13491924107074738
          - 0.12728963792324066
          - 0.14018651843070984
          - 0.12947429716587067
          - 0.12550762295722961
          - 0.13136516511440277
          - 0.13024954497814178
          - 0.11999999731779099
          - 0.1615028977394104
          - 0.12435409426689148
          - 0.1320551633834839
          - 0.1409989297389984
          - 0.13507522642612457
          - 0.12268535047769547
          - 0.1404579132795334
          - 0.13761071860790253
          - 0.1503773033618927
          - 0.12420032173395157
          - 0.13359826803207397
          - 0.13831619918346405
          - 0.1477203220129013
          - 0.1642967164516449
          - 0.12940004467964172
          - 0.13067279756069183
          - 0.14587172865867615
          - 0.1440461277961731
          - 0.13927079737186432
          - 0.14637331664562225
          - 0.1444903016090393
          - 0.15897628664970398
          - 0.13588352501392365
          - 0.1636868715286255
          - 0.155186265707016
          - 0.14988493919372559
          - 0.15125592052936554
          - 0.1648588478565216
          - 0.17682687938213348
          - 0.18185685575008392
          - 0.16568540036678314
          - 0.159017413854599
          - 0.174812912940979
          - 0.16447405517101288
          - 0.1809515804052353
          - 0.18421538174152374
          - 0.1739244908094406
          - 0.18986830115318298
          - 0.18216152489185333
          - 0.21208709478378296
          - 0.21196608245372772
          - 0.20567473769187927
          - 0.19463729858398438
          - 0.23318085074424744
          - 0.23568953573703766
          - 0.2256600558757782
          - 0.22568027675151825
          - 0.2326006144285202
          - 0.26731249690055847
          - 0.24962016940116882
          - 0.2763374149799347
          - 0.273208349943161
          - 0.2861330211162567
          - 0.3047672212123871
          - 0.30232295393943787
          - 0.30729132890701294
          - 0.31756049394607544
          - 0.34554943442344666
          - 0.34511616826057434
          - 0.37451374530792236
          - 0.37072256207466125
          - 0.4023578464984894
          - 0.4413558840751648
          - 0.43559730052948
          - 0.4920308589935303
          - 0.5098116993904114
          - 0.5451174378395081
          - 0.5837374925613403
          - 0.6548380255699158
          - 0.6910128593444824
          - 0.7842224836349487
          - 0.8446397185325623
          - 0.9695355296134949
          - 1.1217998266220093
          - 1.319140911102295
          - 1.580551266670227
          - 2.0140998363494873
          - 2.7679007053375244
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          - .inf
          intensities:
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          - 0.0
          ros2 topic echo /odom
          header:
            stamp:
              sec: 2868
              nanosec: 167000000
            frame_id: odom
          pose:
            pose:
              position:
                x: 0.0009427214987770558
                y: -0.0003296974495629194
                z: 0.015999687516554978
              orientation:
                x: 3.9623270712921966e-07
                y: 7.119830491485281e-06
                z: -0.008208864600624864
                w: 0.99996630667794
            covariance:
            - 1.0e-05
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1.0e-05
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1000000000000.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1000000000000.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1000000000000.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.001
          twist:
            twist:
              linear:
                x: -6.883061792922824e-07
                y: -1.2410642423866674e-07
                z: 0.0
              angular:
                x: 0.0
                y: 0.0
                z: -6.180685727256352e-06
            covariance:
            - 1.0e-05
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1.0e-05
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1000000000000.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1000000000000.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 1000000000000.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.0
            - 0.001
          Y 1 条回复 最后回复 回复 引用 0
          • 3 319276657 将这个主题转为问答主题,在
          • 3 319276657 将这个主题标记为已解决,在
            yu @319276657
            @319276657 兄弟解决了吗,我现在也报[occupancy_grid_node]: submap_slices and last_frame_id is empty,方便讲一下你是怎么解决的吗?感谢
