ros使用teleop_twist_keyboard teleop_twist_keyboard.py控制小车运动时,Gazebo和Rviz中的模型都没有任何反应
标题:ros使用teleop_twist_keyboard teleop_twist_keyboard.py控制小车运动时,Gazebo和Rviz中的模型都没有任何反应
背景:
创建了一个四轮差速小车模型,需要让它在Gazebo和Rviz中动起来问题描述:
ros使用teleop_twist_keyboard teleop_twist_keyboard.py控制小车运动时,Gazebo和Rviz中的模型都没有任何反应具体细节和上下文:
底盘配置xacro文件如下:
<robot name="my_car_move" xmlns:xacro="http://wiki.ros.org/xacro"><xacro:macro name="joint_trans" params="joint_name"> <!-- Transmission is important to link the joints and the controller --> <transmission name="${joint_name}_trans"> <type>transmission_interface/SimpleTransmission</type> <joint name="${joint_name}"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> </joint> <actuator name="${joint_name}_motor"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> <mechanicalReduction>1</mechanicalReduction> </actuator> </transmission> </xacro:macro> <xacro:joint_trans joint_name="left_up2base" /> <xacro:joint_trans joint_name="left_down2base" /> <xacro:joint_trans joint_name="right_up2base" /> <xacro:joint_trans joint_name="right_down2base" /> <!-- differential drive --> <gazebo> <plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so"> <rosDebugLevel>Debug</rosDebugLevel> <robotNamespace>/</robotNamespace> <publishTf>1</publishTf> <publishOdomTF>true</publishOdomTF> <publishWheelTF>true</publishWheelTF> <publishWheelJointState>true</publishWheelJointState> <alwaysOn>true</alwaysOn> <updateRate>100.0</updateRate> <legacyMode>true</legacyMode> <leftJoint>left_up2base,left_down2base</leftJoint> <rightJoint>right_up2base,right_down2base</rightJoint> <wheelSeparation>${base_radius * 2}</wheelSeparation> <wheelDiameter>${wheel_radius * 2}</wheelDiameter> <broadcastTF>1</broadcastTF> <torque>55.7</torque> <wheelTorque>30</wheelTorque> <wheelAcceleration>1.8</wheelAcceleration> <commandTopic>cmd_vel</commandTopic> <odometryFrame>odom</odometryFrame> <odometryTopic>odom</odometryTopic> <odometrySource>1</odometrySource> <robotBaseFrame>base_footprint</robotBaseFrame> </plugin> </gazebo></robot>
control.yaml文件如下:
该文件是控制器配置,一个机器人模型可能有多个控制器,比如: 底盘、机械臂、夹持器(机械手)....
因此,根 name 是 controller
controllers: {
单控制器设置
base_controller: {
#类型: 差速控制器
type: diff_controller,
#参考坐标
base_frame_id: base_footprint,
#两个轮子之间的间距
base_width: 0.2,
#控制频率
ticks_meter: 2000,
#PID控制参数,使机器人车轮快速达到预期速度
Kp: 12,
Ki: 0,
Kd: 12,
Ko: 50,
#加速限制
accel_limit: 1.0
}尝试过的解决方法:
修改过很多次配置文件,主要在gazebo标签部分 -
在你遇到的问题中,有几个潜在的原因可能导致使用
teleop_twist_keyboard时 Gazebo 和 Rviz 中的模型没有反应。这里我会逐步分析并给出一些可能的解决方案。1. 确保所有配置文件的正确性
首先,检查你的配置文件,特别是 URDF/XACRO 文件和控制器配置文件(如
control.yaml)。从你提供的xacro文件来看,你正确地设置了差分驱动插件(libgazebo_ros_diff_drive.so),但在control.yaml文件中存在一些潜在的问题:- 控制器类型:你使用的是
diff_controller,但在 ROS 中,标准的差分驱动控制器类型通常是diff_drive_controller。确保你的控制器节点正确加载了正确的控制器类型。 - 配置文件与控制器名称匹配:在
control.yaml中定义的控制器名称是base_controller,但在你的xacro文件中没有直接提及这个名称。你需要确保在你的 ROS 启动文件中(如robot_description.launch或controller_spawner.launch)正确加载了这个控制器。
2. 控制器启动
确保你已经正确启动了控制器管理器并加载了
base_controller。这通常通过roslaunch或rosrun命令结合.launch文件完成。例如:roslaunch your_package_name controller_spawner.launch确保
controller_spawner.launch文件中包含了类似以下的内容:<launch> <arg name="manager" default="controller_manager" /> <node name="$(arg manager)" pkg="controller_manager" type="spawner" respawn="false" output="screen" args="base_controller" /> </launch>3. 检查 ROS 话题
使用
rostopic list查看是否有cmd_vel话题发布,并且确保teleop_twist_keyboard正在发布到这个话题。使用rostopic echo /cmd_vel来检查是否有速度命令被发送。4. 检查 Gazebo 日志
检查 Gazebo 的终端输出或日志文件,看是否有关于控制器的错误或警告信息。特别是关于差分驱动插件的错误或配置问题。
5. 确保坐标系一致
确保所有坐标系(如
base_footprint,odom等)在你的模型中已正确定义并一致。错误的坐标系配置会导致数据传递错误或无法传递。6. Rviz 配置
在 Rviz 中,确保你添加了
RobotModel显示和适当的 TF 框架。这有助于你检查坐标变换是否正确。7. 重新加载 URDF/XACRO
有时,在做了重大更改后,重新启动 ROS 节点和 Gazebo 并重新加载 URDF/XACRO 文件可以解决问题。
按照这些步骤检查和修改你的配置,通常可以解决大部分关于 ROS、Gazebo 和 Rviz 中模型无反应的问题。如果问题仍然存在,请详细检查 ROS 的日志输出以获取更多线索。
- 控制器类型:你使用的是
