    在给机器人部件添加质量和惯性时出错
    仿真 机器人仿真 xacro
    921
    • 8
      862524030 年度VIP
      在跟着b站鱼香ros 的ros2仿真教程学习的过程中,给机器人部件添加质量和关系报错。
      common_inertia.xacro代码:
      <?xml version="1.0"?>
      <robot xmlns:xacro="http://www.wiki.ros.org/xacro">
          <xacro:macro name="box_inertia" params="m w h d">
              <inertial>
                  <mass value="${m}"/>
                  <inertia ixx="${m/12}*(h*h+d*d)" ixy="0.0" ixz="0.0" iyy="${m/12}*(w*W+d*d)" iyz="0.0" izz="${(m/12)*(w*w+h*h)}" />
              </inertial>
          </xacro:macro>
          <xacro:macro name="cylinder_inertia" params="m r h">
              <inertial>
                  <inertia ixx="${m/12}*(3*r*r+h*h)" ixy="0.0" ixz="0.0" iyy="${m/12}*(3*r*r+h*h)" iyz="0.0" izz="${(m/2)*(r*r)}" />
              </inertial>
          </xacro:macro>
          <xacro:macro name="sphere_inertia" params="m r">
              <inertial>
                  <inertia ixx="${2/5}*m*(r*r)" ixy="0.0" ixz="0.0" iyy="${2/5}*m*(r*r)" iyz="0.0" izz="${2/5}*m*(r*r)" />
              </inertial>
          </xacro:macro>
      </robot>
      base.urdf.xacro代码:
      <robot xmlns:xacro="http://www.wiki.ros.org/xacro" >
          <xacro:include filename="$(find fishbot_description)urdf/fishbot/common_inertia.xacro"/>
          <xacro:macro name="base_xacro" params="length radius">
              <link name="base_footprint"/>
              <link name="base_link">
                  <visual>
                      <origin xyz="0.0 0.0 0.0" rpy="0.0 0.0 0.0"/>
                      <geometry>
                          <cylinder radius="${radius}" length="${length}"/>
                      </geometry>
                      <material name="white">
                          <color rgba="1.0 1.0 1.0 0.5"/>
                      </material>
                  </visual>
                  <collision>
                      <geometry>
                      </geometry>
                      </material>
                  </collision>
                  <xacro:cylinder_inertia m="1.0" r="${radius}" h="${length}"/>
              </link>
                  <child link="base_link"/>
                  <axis xyz="0.0 0.0 0.0"/>
                  <origin xyz="0.0 0.0 ${length/2.0+0.032-0.001}" rpy="0 0 0" />
              </joint>
          </xacro:macro>
      </robot>
      报错是:
      [INFO] [launch]: All log files can be found below /home/zmy/.ros/log/2025-01-14-18-00-57-621013-zmyTB-41493
      [ERROR] [launch]: Caught exception in launch (see debug for traceback): executed command failed. Command: xacro /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/fishbot.urdf.xacro
      Captured stderr output: error: No such file or directory: /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_descriptionurdf/fishbot/common_inertia.xacro [Errno 2] No such file or directory: '/home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_descriptionurdf/fishbot/common_inertia.xacro'
      when processing file: /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/base.urdf.xacro
      included from: /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/fishbot.urdf.xacro
        从错误信息来看,主要问题出现在 XACRO 文件包含路径上。错误提示指出无法找到 common_inertia.xacro 文件,因为给定的路径不正确。具体来说,路径中缺少了一个斜杠(/),导致文件路径解析错误。
        错误路径:
        正确的路径应该包含 fishbot_description/urdf/ 中间的斜杠:
        /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/common_inertia.xacro
        解决步骤
        1. 检查并修正文件包含路径:
          在 base.urdf.xacro 文件中,确保 <xacro:include> 标签中的 filename 属性指向正确的路径。修改如下:
          <xacro:include filename="$(find fishbot_description)/urdf/fishbot/common_inertia.xacro"/>
          注意这里使用了完整的路径,并且确保了路径中的每个部分都用斜杠正确分隔。
        2. 验证文件位置:
          确保 common_inertia.xacro 文件确实位于 install/fishbot_description/share/fishbot_description/urdf/fishbot/ 目录下。
        3. 重新编译并运行:
          在 ROS2 工作空间中重新编译:
          然后尝试再次运行你的仿真。
        4. 检查其他可能的错误:
          如果问题依旧存在,检查 fishbot.urdf.xacro 文件是否也正确引用了其他必要的文件,并且所有路径都是正确的。
        通过上述步骤,你应该能够解决由于文件路径错误导致的编译问题。如果还有其他问题,可能需要检查 XACRO 宏的使用是否正确,或者 ROS2 环境设置是否有问题。
        8 1 条回复 最后回复 回复 引用 0
        • 8
          862524030 年度VIP @小伊
          @小伊
          The link right_wheel_link is has unrealistic inertia, so the equivalent inertia box will not be shown.
          这个报错怎么解决
            在机器人仿真或物理建模中,如果你遇到了“The link right_wheel_link is has unrealistic inertia, so the equivalent inertia box will not be shown.”这样的错误,这通常意味着你为某个连接(link)设置的惯性参数(比如质量、质心位置或转动惯量)不合理或不符合物理实际。解决这个问题的步骤通常包括以下几个:
            1. 检查质量设置:
              • 确保为right_wheel_link设置的质量是合理的。例如,一个车轮的质量应该与其物理尺寸和材料相符。
            2. 检查质心位置:
              • 质心的位置应该在物理上合理。例如,车轮的质心通常位于其几何中心附近。如果质心设置得太远,可能会导致不现实的惯性值。
            3. 检查转动惯量:
              • 转动惯量(也称为惯性矩)是关于物体绕某轴旋转时抵抗改变其角速度的能力的物理量。确保为right_wheel_link设置的转动惯量与其质量和尺寸相匹配。通常,这可以通过计算或查阅相关物理手册得到。
            4. 使用物理定律和公式:
              • 可以使用平行轴定理或其他相关物理定律来计算和验证惯性参数。这有助于确保所有值都是准确和一致的。
            5. 检查模型的其他部分:
              • 有时候,问题可能不是直接由right_wheel_link的惯性参数引起的,而是由其他相关的链接或连接件(如关节)的不当设置导致的。检查所有相关的物理属性,确保它们都是正确的。
            6. 参考文档和社区资源:
              • 如果你使用的是特定的仿真软件(如Gazebo、V-REP、Webots等),查阅该软件的文档,了解如何正确设置惯性参数。此外,社区论坛和问答网站也可能提供有用的信息和解决方案。
            7. 调试和测试:
              • 在做出更改后,重新运行仿真以检查是否解决了问题。有时,可能需要多次迭代才能找到正确的参数设置。
            通过上述步骤,你应该能够识别和解决right_wheel_link的惯性参数设置不合理的问题。如果问题仍然存在,可能需要更深入地检查模型的其他方面或寻求专业帮助。
            • 8
              862524030 年度VIP @小伊
              Rviz中为什么不显示机器人部件了
                在Rviz中机器人部件不显示的问题可能由多种原因导致,以下是一些可能的原因及其相应的解决方案:
                1. 模型文件错误:
                  • 确保模型文件(通常是.urdf或.sdf格式)没有语法错误或遗漏的组件。
                  • 使用文本编辑器打开模型文件,仔细检查文件内容。
                2. 文件路径问题:
                  • 在Rviz中,需要指定模型文件的加载路径。确保这些路径是正确的,并且文件确实存在于指定的路径下。
                  • 检查机器人描述文件(如.urdf文件)的加载路径,确保路径正确且文件无误。
                3. 视图配置问题:
                  • 在Rviz中,配置显示模型的视图是关键。确保添加了正确的显示项,并且设置了正确的颜色和大小。
                  • 检查视图中的相机位置和朝向,确保模型在相机视野内。
                4. 坐标系设置问题:
                  • 在某些情况下,机器人模型显示为白色或完全不显示,可能是坐标系设置不正确。
                  • 确保在Rviz配置中使用了正确的base_link或其他实际使用的坐标系,而不是默认的base_footprint。
                5. 依赖项问题:
                  • 某些模型可能依赖于特定的插件或库。确保这些依赖项已正确安装,并且在模型文件中正确引用。
                6. 环境或工具问题:
                  • 有时,简单地更新工作环境或重启Rviz可以解决问题。
                  • 尝试更新ROS版本,或者重启计算机和仿真工具。
                7. 多机器人仿真问题:
                  • 在进行多机器人仿真时,如果未使用tf_prefix区分不同的机器人,可能会导致模型不显示。
                  • 确保为每个机器人设置了唯一的tf_prefix,并在RobotModel中的Robot_description参数中正确引用。
                8. 日志文件:
                  • Rviz会生成日志文件,记录运行过程中的错误和警告信息。
                  • 查看这些日志文件,可能有助于找到导致模型不显示的原因。日志文件通常位于ROS工作空间的log目录下。
                9. 社区帮助:
                  • 如果尝试了以上方法仍然无法解决问题,可以向ROS社区寻求帮助。
                  • 在提问时,提供详细的错误信息和相关代码,以便他人更好地理解问题并提供帮助。
                综上所述,解决Rviz中机器人部件不显示的问题需要仔细检查模型文件、加载路径、视图配置、坐标系设置、依赖项、环境或工具问题以及多机器人仿真设置等多个方面。通过逐步排查和解决问题,通常可以找到导致模型不显示的原因并解决它。
                • 8
                  862524030 年度VIP @小伊
                  @小伊
                  在将机器人urdf模型导入gazebo的时候,报错:
                  usage: ros2 run [-h] [--prefix PREFIX] package_name executable_name ...
                  ros2 run: error: the following arguments are required: executable_name, argv
                  这是为什么
                    当你遇到这个错误时,说明你在使用 ros2 run 命令时没有提供足够的参数。ros2 run 命令用于在 ROS 2 环境中运行一个指定的可执行文件。这个命令的基本格式是:
                    ros2 run [package_name] [executable_name] [arguments...]
                    其中:
                    • [package_name] 是包含可执行文件的 ROS 2 包的名字。
                    • [executable_name] 是你想要运行的可执行文件的名称。
                    • [arguments...] 是传递给可执行文件的任何额外参数(可选)。
                    针对你的错误信息:
                    这里明确指出了缺少 executable_name 和可能的其他参数(argv 在这里可能是一个误导,因为通常我们不需要显式指定 argv,而是直接传递实际参数)。
                    解决步骤:
                    1. 确认包名和可执行文件名:
                      确保你知道你要运行的 ROS 2 包的名称和该包中的可执行文件的名称。
                    2. 使用正确的命令格式:
                      根据上面的格式,确保你的命令包含了包名和可执行文件名。例如,如果你想要运行一个名为 my_robot_simulation 包中的 my_node 可执行文件,你应该使用:
                      ros2 run my_robot_simulation my_node
                    3. 检查是否有额外参数:
                      如果你的可执行文件需要额外的参数,确保在命令中正确添加它们。
                    4. 查看文档或帮助:
                      如果你不确定包名或可执行文件名,可以查看你的 ROS 2 工作空间的 install 目录下的内容,或者使用 ros2 pkg list 和 ros2 pkg executables <package_name> 命令来获取相关信息。
                    5. 检查 ROS 2 环境:
                      确保你的 ROS 2 环境已经正确设置,包括 source 了你的工作空间的 setup.bash 文件(或相应的 shell 脚本)。
                    如果以上步骤正确无误,但问题仍然存在,可能需要检查你的 ROS 2 安装或工作空间是否有其他问题。
                    • 8
                      862524030 年度VIP @小伊
                      @小伊 ```
                      import launch
                      import launch_ros
                      # 获取默认路径
                      robot_name_in_model = "fishbot"
                      urdf_tutorial_path = get_package_share_directory('fishbot_description')
                      default_model_path = urdf_tutorial_path + '/urdf/fishbot/fishbot.urdf.xacro'
                      default_world_path = urdf_tutorial_path + '/world/simple_room.world'
                      # 为launch声明参数
                      action_declare_arg_mode_path = launch.actions.DeclareLaunchArgument(
                          name='model',default_value=str(default_model_path),description='URDF的绝对路径'
                      # 获取文件内容生成的新的参数
                      robot_description = launch_ros.parameter_descriptions.ParameterValue(launch.substitutions.Command(
                          ['xacro',launch.substitutions.LaunchConfiguration('model')]),value_type=str)
                      robot_state_publisher_node = launch_ros.actions.Node(
                          parameters=[{'robot_description':robot_description}]
                      launch_gazebo = launch.actions.IncludeLaunchDescription(
                          PythonLaunchDescriptionSource([get_package_share_directory('gazebo_ros'),'/launch','/gazebo.launch.py']),
                          launch_arguments=[('world',default_world_path),('verbose','true')]
                      #请求Gazebo加载机器人
                      spawn_entity_node = launch_ros.actions.Node(
                          package='gazebo_ros',
                          executable='spawn_entity.py',
                          arguments=['-topic','/robot_description','-entity',robot_name_in_model, ]
                      return launch.LaunchDescription(
                              action_declare_arg_mode_path,
                              robot_state_publisher_node,
                              launch_gazebo,
                              spawn_entity_node
                      报错如下
                      zmy@zmyTB:~/chapt6/chapt6_ws$ ros2 run gazebo_sim.launch.py
                        您遇到的错误提示表明您尝试使用 ros2 run 命令来运行一个 Python 脚本(gazebo_sim.launch.py),但 ros2 run 命令通常用于运行单个可执行文件,而不是 Python 脚本。对于 ROS 2 的 launch 文件,您应该使用 ros2 launch 命令来启动它们。
                        假设您的 launch 文件名为 gazebo_sim.launch.py 并且位于您的 ROS 2 工作空间的某个包中,您需要确保该文件位于该包的 launch 目录下。然后,您可以使用以下命令来运行它:
                        ros2 launch <your_package_name> gazebo_sim.launch.py
                        其中 <your_package_name> 是包含 gazebo_sim.launch.py 文件的 ROS 2 包的名称。
                        步骤概述
                        1. 确保文件位置正确:
                          • gazebo_sim.launch.py 应该位于您的 ROS 2 包的 launch 文件夹内。
                        2. 使用正确的命令运行 launch 文件:
                          • 在终端中使用 ros2 launch <package_name> <launch_file_name>.launch.py 命令。
                        3. 检查包名:
                          • 替换 <your_package_name> 为实际的包名。
                        示例
                        假设您的包名为 my_robot_sim,并且 gazebo_sim.launch.py 位于 my_robot_sim/launch 目录中,那么您应该使用以下命令:
                        ros2 launch my_robot_sim gazebo_sim.launch.py
                        这将启动您的 launch 文件,该文件应该已经正确配置了所有必要的节点和参数来运行 Gazebo 和相关的 ROS 2 节点。
                        额外检查
                        • 确保您的 ROS 2 环境已正确设置(例如,使用 source install/setup.bash)。
                        • 确保所有依赖项都已正确安装。
                        • 检查 gazebo_sim.launch.py 脚本中的路径和参数是否正确无误。
                        通过上述步骤,您应该能够成功运行您的 launch 文件。如果仍然遇到问题,请检查 ROS 2 的日志输出以获取更多错误信息。
                        • 8
                          862524030 年度VIP @小伊
                          @小伊
                          ros2 launch fishbot_description gazebo_sim.launch.py
                          [INFO] [launch]: All log files can be found below /home/zmy/.ros/log/2025-01-15-11-11-07-078324-zmyTB-45845
                          [ERROR] [launch]: Caught exception in launch (see debug for traceback): file not found: [Errno 2] No such file or directory: 'xacro/home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/fishbot.urdf.xacro'
                          这是什么错误
                            这个错误信息表明在尝试使用 ROS 2 的 launch 工具来启动 gazebo_sim.launch.py 文件时,系统找不到指定的 URDF 文件(fishbot.urdf.xacro)。错误的具体内容是:
                            错误提示中的路径 'xacro/home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/fishbot.urdf.xacro' 看起来是不正确的,因为它以 xacro/ 开头,这通常意味着路径的指定有误。正确的路径应该直接从用户的主目录开始,例如 /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/fishbot.urdf.xacro。
                            这里有几个可能的解决步骤:
                            1. 检查文件路径:
                              • 确认 fishbot.urdf.xacro 文件是否确实存在于 /home/zmy/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/urdf/fishbot/ 目录下。
                              • 如果文件不在该位置,你可能需要重新编译你的 ROS 2 工作空间,确保所有文件都被正确安装。
                            2. 检查 launch 文件:
                              • 打开 gazebo_sim.launch.py 文件,检查其中引用 fishbot.urdf.xacro 文件的路径。
                              • 确保路径是正确的,并且没有多余的 xacro/ 前缀。
                            3. 重新编译工作空间:
                              • 在你的 ROS 2 工作空间目录下(通常是包含 src 和 install 等目录的顶层目录),运行以下命令来重新编译你的工作空间:
                              • 编译完成后,再次尝试启动。
                            4. 检查环境变量:
                              • 确保你的 ROS_PACKAGE_PATH 环境变量包含了你的工作空间路径。你可以通过运行 echo $ROS_PACKAGE_PATH 来检查。
                            5. 使用绝对路径:
                              • 在 launch 文件中,尝试使用文件的绝对路径而不是相对路径,这有时可以避免路径解析的问题。
                            通过上述步骤,你应该能够定位并解决问题。如果问题仍然存在,可能需要更详细地检查 launch 文件中的其他配置或依赖关系。
