    colcon build报错
    报错 学习
    881
      rrrooosss
      ros2@ros2:~/222$ colcon build
      Starting >>> python_pkg
      /home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:270: UserWarning: Unknown distribution option: 'tests_require'
      warnings.warn(msg)
      --- stderr: python_pkg
      warnings.warn(msg)
      File "/home/ros2/222/src/python_pkg/setup.py", line 5, in <module>
      setup(
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup
      return run_commands(dist)
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands
      dist.run_commands()
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 983, in run_commands
      self.run_command(cmd)
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
      super().run_command(command)
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_command
      cmd_obj.run()
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
      self.find_sources()
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
      mm.run()
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 548, in run
      self.prune_file_list()
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
      super().prune_file_list()
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 272, in get_fullname
      File "/home/ros2/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 290, in _distribution_fullname
      Failed <<< python_pkg [1.15s, exited with code 1]
      Summary: 0 packages finished [1.35s]
      1 package failed: python_pkg
      1 package had stderr output: python_pkg
      按照官方给出的ros2学习文档,执行def main():
      print('Hi from python_pkg.')
      if name == 'main':
      这个报错。
      什么原因,怎么处理?
        您遇到的错误主要与 setuptools 和 setup.py 文件中的配置有关。错误信息表明有几个关键问题:
        1. Unknown distribution option: 'tests_require':
          这个警告表示 setuptools 不识别 tests_require 选项。这通常不是致命错误,但表明您的 setup.py 可能使用了某些不再支持或不被当前 setuptools 版本识别的参数。尽管 tests_require 在一些旧的 setuptools 版本中是有效的,但在新的版本中可能已被移除或替换。
        2. TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero':
          这个错误是关键的,它表明在调用 canonicalize_version 函数时提供了一个不被期望的关键字参数 strip_trailing_zero。这通常是因为 setuptools 版本与您的 setup.py 脚本或依赖的其他库不兼容。
        解决步骤:
        1. 更新或降级 setuptools:
          尝试更新或降级 setuptools 到一个与您的 ROS 2 环境和 setup.py 脚本更兼容的版本。您可以使用以下命令来更新或指定特定版本的 setuptools:
          pip install --upgrade setuptools  # 更新到最新版本
          # 或者指定一个版本
          pip install setuptools==<version>
          如果不确定哪个版本兼容,可以尝试几个不同的版本。
        2. 检查 setup.py:
          查看 setup.py 文件,确保所有参数都是当前 setuptools 版本支持的。特别是检查 setup() 函数调用中是否使用了任何过时的或不被支持的参数,如 tests_require。如果使用了 tests_require,您可以考虑移除它,或者使用其他方式来指定测试依赖。
        3. 清理和重建:
          在更改 setuptools 版本或 setup.py 后,确保清理之前的构建文件。您可以在工作空间目录下运行:
          colcon build --packages-select python_pkg --merge-install
          或者先清理:
          colcon clean
        4. 检查 ROS 2 和 Python 版本兼容性:
          确保您使用的 ROS 2 版本与您的 Python 版本兼容。有时候,新版本的 Python 可能不被某些 ROS 2 发行版支持。
        通过上述步骤,您应该能够解决构建过程中遇到的问题。如果问题仍然存在,可能需要更详细地检查 setup.py 的内容或寻求特定于您使用的 ROS 2 发行版和 Python 版本的社区支持。
        3 1 条回复 最后回复 回复 引用 0
          rrrooosss @小伊
          @小伊 在 colcon build报错 中说:
          解决步骤:
            # 或者指定一个版本
          2. 检查 setup.py:
          3. 清理和重建:
            或者先清理:
            colcon clean
          我的setup.py文件下的内容是:
          from setuptools import find_packages, setup
          package_name = 'python_pkg'
          setup(
          name=package_name,
          version='0.0.0',
          packages=find_packages(exclude=['test']),
          data_files=[
          zip_safe=True,
          maintainer='ros2',
          maintainer_email='3513232534@QQ.com',
          license='Apache-2.0',
          tests_require=['pytest'],
          entry_points={
          'console_scripts': [
          'python_node = python_pkg.python_node:main'
          )应该怎么修改
            根据您提供的错误信息以及 setup.py 文件的内容,问题主要集中在 tests_require 选项上,以及可能的 setuptools 版本兼容性问题。以下是一些建议的修改步骤:
            1. 移除 tests_require 选项:
              由于 tests_require 在新版本的 setuptools 中可能不再被支持,您可以考虑移除这个选项。如果您需要指定测试依赖,可以通过其他方式管理,例如在项目的 requirements.txt 文件中列出测试依赖,或者在测试脚本中直接处理。
              修改后的 setup.py 文件如下:
              setup(
                  name=package_name,
                  version='0.0.0',
                  data_files=[
                      ('share/ament_index/resource_index/packages', ['resource/' + package_name]),
                  zip_safe=True,
                  maintainer='ros2',
                  entry_points={
            2. 更新或指定 setuptools 版本:
              由于您遇到了与 setuptools 版本相关的错误,尝试更新到最新版本的 setuptools,或者指定一个与您的 ROS 2 环境和 setup.py 脚本更兼容的版本。您可以使用以下命令来更新或指定特定版本的 setuptools:
              # 或者指定一个版本
              如果不确定哪个版本兼容,可以尝试几个不同的版本,直到找到一个不会引发错误的版本。
            3. 清理和重建项目:
              在更改 setup.py 或 setuptools 版本后,确保清理之前的构建文件。您可以在工作空间目录下运行以下命令:
              colcon clean
              或者,如果您只想构建特定的包,可以使用:
              确保您使用的 ROS 2 版本与您的 Python 版本兼容。如果您使用的是较新的 Python 版本,而 ROS 2 发行版不支持该版本,您可能需要考虑使用旧版本的 Python 或升级到支持新版本的 ROS 2 发行版。
            通过以上步骤,您应该能够解决构建过程中遇到的问题。如果问题仍然存在,请检查 setup.py 的其他内容或寻求特定于您使用的 ROS 2 发行版和 Python 版本的社区支持。
              rrrooosss @小伊
                修改后的 setup.py 文件如下:
                setup(
                    name=package_name,
                    version='0.0.0',
                    data_files=[
                    zip_safe=True,
                    maintainer='ros2',
                    entry_points={
                # 或者指定一个版本
              3. 清理和重建项目:
                colcon clean
                修改后的 setup.py 文件如下:
                setup(
                    name=package_name,
                    version='0.0.0',
                    data_files=[
                    zip_safe=True,
                    maintainer='ros2',
                    entry_points={
                # 或者指定一个版本
              3. 清理和重建项目:
                colcon clean
                修改后的 setup.py 文件如下:
                setup(
                    name=package_name,
                    version='0.0.0',
                    data_files=[
                    zip_safe=True,
                    maintainer='ros2',
                    entry_points={
                # 或者指定一个版本
              3. 清理和重建项目:
                colcon clean
              现在编译成功,但是install下却没有相应包
                如果 colcon build 成功完成,但安装目录下(通常是 install 文件夹)没有找到相应的包,可能是由以下几个原因导致的:
                1. 包没有被正确安装:
                  • 确保 colcon build 没有任何错误或警告,特别是与安装相关的。
                  • 检查 setup.py 中的 packages 参数是否正确地包含了所有需要安装的包。
                2. 安装目录问题:
                  • 默认情况下,colcon 会将包安装到工作空间中的 install 目录。确认你是否在正确的工作空间目录下运行了 colcon build。
                  • 使用 colcon list 可以查看当前工作空间中有哪些包,确保你的包列在其中。
                3. 环境变量问题:
                  • 确保你的 PYTHONPATH 环境变量包含了安装目录。这通常不需要手动设置,因为 colcon 会管理这些环境变量,但如果你在其他地方运行 Python 脚本,可能需要手动设置。
                  • 使用 source install/setup.bash(或对应的 shell 脚本,如 setup.zsh)来设置环境变量,这样可以让系统知道去哪里找安装的 Python 包。
                4. 包的可见性问题:
                  • 如果你的包是一个 ROS 2 包,确保它的元数据(如 package.xml 和 setup.py)正确无误,并且遵循了 ROS 2 的包结构。
                  • 检查 setup.py 中的 data_files 是否正确指定了资源文件的位置,这对于 ROS 2 包来说很重要。
                5. 权限问题:
                  • 确保你有足够的权限写入安装目录。在某些系统上,你可能需要使用 sudo 来运行 colcon build,但这通常不推荐,因为它可能引入其他权限问题。
                6. 清理和重建:
                  • 有时候,清理旧的构建文件并重新构建可以解决问题。使用 colcon clean 后再运行 colcon build。
                7. 检查输出:
                  • 仔细检查 colcon build 的输出,看看是否有任何关于安装步骤的警告或错误。
                8. 依赖问题:
                  • 确保所有依赖都已正确安装,并且与你的 ROS 2 版本和 Python 版本兼容。
                如果以上步骤都无法解决问题,你可以尝试以下更具体的调试步骤:
                • 在 setup.py 中添加打印语句,以查看哪些文件被包括在包中。
                • 检查 install 目录下的内容,看看是否有与你的包名相对应的文件夹。
                • 在 Python 脚本中尝试导入你的包,看看是否有任何导入错误。
                • 查看 ROS 2 社区或相关论坛,看看是否有其他人遇到并解决了类似的问题。
