    skiros2
    移动平台分享
    ubuntu18.04 ros1-melodic python环境
      按照这个教程操作:
      要使用 SkiROS,您必须在计算机上安装 ROS。 您还需要 pip 来安装 python 依赖项。
      将此仓库克隆到你的 catkin 工作区 src 目录中:
      mkdir -p catkin_ws/src && cd catkin_ws/src
      git clone https://github.com/RVMI/skiros2
      Clone the base skill set into the skiros2 directory in your catkin workspace.
      git clone https://github.com/RVMI/skiros2_std_lib
      Optionally, you can clone the skiros2_examples repositories here as well:
      git clone https://github.com/RVMI/skiros2_examples
      使用 rosdep 和 python 依赖项安装每个组件中定义的依赖项:package.xml
      rosdep install --from-paths . --ignore-src --rosdistro=$ROS_DISTRO -y
      Install Python dependencies
      pip install -r requirements.txt --user
      出错了:
      fc@fc:~$ mkdir -p catkin_ws/src && cd catkin_ws/src
      fc@fc:~/catkin_ws/src$ git clone https://github.com/RVMI/skiros2
      Cloning into 'skiros2'...
      remote: Enumerating objects: 1380, done.
      remote: Counting objects: 100% (194/194), done.
      remote: Compressing objects: 100% (51/51), done.
      remote: Total 1380 (delta 160), reused 143 (delta 143), pack-reused 1186 (from 2)
      Receiving objects: 100% (1380/1380), 3.41 MiB | 2.93 MiB/s, done.
      Resolving deltas: 100% (763/763), done.
      fc@fc:~/catkin_ws/src$ # Clone the base skill set into the skiros2 directory in your catkin workspace.
      fc@fc:~/catkin_ws/src$ git clone https://github.com/RVMI/skiros2_std_lib
      Cloning into 'skiros2_std_lib'...
      remote: Enumerating objects: 688, done.
      remote: Counting objects: 100% (295/295), done.
      remote: Compressing objects: 100% (84/84), done.
      remote: Total 688 (delta 258), reused 235 (delta 211), pack-reused 393 (from 1)
      Receiving objects: 100% (688/688), 110.51 KiB | 300.00 KiB/s, done.
      Resolving deltas: 100% (417/417), done.
      fc@fc:~/catkin_ws/src$ # Optionally, you can clone the skiros2_examples repositories here as well:
      fc@fc:~/catkin_ws/src$ git clone https://github.com/RVMI/skiros2_examples
      Cloning into 'skiros2_examples'...
      remote: Enumerating objects: 164, done.
      remote: Counting objects: 100% (164/164), done.
      remote: Compressing objects: 100% (90/90), done.
      remote: Total 164 (delta 92), reused 127 (delta 56), pack-reused 0 (from 0)
      Receiving objects: 100% (164/164), 40.65 KiB | 190.00 KiB/s, done.
      Resolving deltas: 100% (92/92), done.
      fc@fc:~/catkin_ws/src$ rosdep install --from-paths . --ignore-src --rosdistro=$ROS_DISTRO -y
      to system dependencies:
      skiros2: [python-is-python3] defined as "not available" for OS version [bionic]
