一键安装换源时遇到问题:没有Release文件
使用一键安装ROS时,换源的时候遇到没有Release文件的报错
你的系统当前apt存在问题,请先使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial Release” 没有 Release 文件。\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial-updates Release” 没有 Release 文件。\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial-backports Release” 没有 Release 文件。\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial-security Release” 没有 Release 文件。\n'] -
@1687028512 提供一下全部日志,需要看一下你的系统架构
此回复已被删除! -
@小鱼 系统架构是amd64 全部日志如下
欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献.. RUN Choose Task:[请输入括号内的数字] 请选择换源方式,如果不知道选什么请选2 [0]:quit [1]:仅更换系统源 [2]:更换系统源并清理第三方源 请输入[]内的数字以选择:2 Run CMD Task:[sudo apt update] [|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[-]Result:code:100 Run CMD Task:[sudo rm -rf /etc/apt/sources.list] [-]Result:success 删除一个资源文件 Run CMD Task:[dpkg --print-architecture] [-]Result:success 检测到当前系统架构为[amd64],正在为你更换对应源.. 替换完成,尝试第一次更新.... Run CMD Task:[sudo apt update] [|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[-]Result:code:100 更新失败,开始更换导入方式并三次尝试... Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9] [-]Result:success -keyserver Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys DCC9EFBF77E11517] [-]Result:success -keyserver Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 54404762BBB6E853] [-]Result:success -keyserver Run CMD Task:[sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 112695A0E562B32A] [-]Result:success -keyserver Run CMD Task:[apt-get install debian-keyring debian-archive-keyring] [-]Result:code:100 它的软件包引用了。 Run CMD Task:[apt-key update] []gpg: 密钥 437D05B5:“Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.c[|]gpg: 密钥 FBB75451:“Ubuntu CD Image Automatic Signing Key <cdimage@ubuntu.co[-]gpg: 密钥 C0B21F32:“Ubuntu Archive Automatic Signing Key (2012) <ftpmaster@u[/]gpg: 密钥 EFE21092:“Ubuntu CD Image Automatic Signing Key (2012) <cdimage@ub[-]Result:success Run CMD Task:[sudo apt update] [|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[-]Result:code:100 如果出现问题NO_PUBKEY XXXXXXXX,请手动运行添加指令:apt-key adv --keyserver keyserver.ubuntu.com --recv-keys XXXXXXXX 如:error: NO_PUBKEY 0E98404D386FA1D9 运行指令:sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9 镜像修复完成..... Run CMD Task:[sudo apt update] [|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[|] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[/] server certificate verification failed. CAfile: /etc/ssl/certs/ca-certifica[-]Result:code:100 你的系统当前apt存在问题,请先使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial Release” 没有 Release 文件。\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial-updates Release” 没有 Release 文件。\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial-backports Release” 没有 Release 文件。\n', 'E: 仓库 “https://mirrors.ustc.edu.cn/ubuntu xenial-security Release” 没有 Release 文件。\n'] Run CMD Task:[dpkg --print-architecture] [-]Result:success 0 3 / 3 -
@1687028512 在 一键安装换源时遇到问题:没有Release文件 中说:
看到了一直都有这个错误,百度一下解决方法,参考尝试
touch /etc/apt/apt.conf.d/99verify-peer.conf && echo >>/etc/apt/apt.conf.d/99verify-peer.conf "Acquire { https::Verify-Peer false }" -
@小鱼 运行这个命令没能解决,我也百度了一下一些方案也没有解决。今天重新装了一遍用小鱼又装了一遍,已经装好了。谢谢小鱼昨天的及时回复!
小 小伊 将这个主题转为问答主题,在
小 小伊 将这个主题标记为已解决,在
