    Error in the first step
    一键安装,ros2 一键安装失败
    • M
      m18800429665
      ROS相关:
      [9]:一键安装:Cartographer(内测版易失败)
      常用软件:
      [6]:一键安装:NodeJS环境
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [14]:一键安装:科学上网代理工具
      [15]:一键安装:QQ for Linux
      配置工具:
      [13]:一键配置:python国内源
      请输入[]内的数字以选择:1
      --2023-10-25 23:07:24-- http://fishros.com/install/install1s/tools/tool_install_ros.py
      已发出 HTTP 请求,正在等待回应... 503 Service Unavailable
      2023-10-25 23:07:24 错误 503:Service Unavailable。
      --2023-10-25 23:07:24-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
      已发出 HTTP 请求,正在等待回应... 200 OK
      正在保存至: ‘/tmp/fishinstall/tools/tool_config_rosenv.py’
      /tmp/fishinstall/tools/too 100%[=====================================>] 2.40K --.-KB/s 用时 0s
      2023-10-25 23:07:24 (122 MB/s) - 已保存 ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ [2457/2457])
      --2023-10-25 23:07:24-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
      长度: 7708 (7.5K) [application/octet-stream]
      正在保存至: ‘/tmp/fishinstall/tools/tool_config_system_source.py’
      /tmp/fishinstall/tools/too 100%[=====================================>] 7.53K --.-KB/s 用时 0.06s
      2023-10-25 23:07:25 (120 KB/s) - 已保存 ‘/tmp/fishinstall/tools/tool_config_system_source.py’ [7708/7708])
      File "/tmp/fishinstall/install.py", line 122, in <module>
      File "/tmp/fishinstall/install.py", line 114, in main
      File "/tmp/fishinstall/tools/base.py", line 1295, in run_tool_file
      tool = importlib.import_module(file.replace(".py","")).Tool()
      AttributeError: module 'tools.tool_install_ros' has no attribute 'Tool'
        小鱼 技术大佬 @m18800429665
        @m18800429665 在 Error in the first step 中说:
        检查网络 问题,不行可以手动下载
        git  clone https://github.com/fishros/install
        cd install
        sudo python3 install.py
