    Ubuntu22安装Docker Noetic无法正常使用realsense-viewer
    docker ros realsense
    2.5k
    • 15000457121
      MnPt爱学习
      无法正常连接设备,lsusb也识别不出,
      10/01 08:33:19,432 ERROR [140331219756928] (librealsense-exception.h:52) Cannot identify '/dev/video1 Last Error: No such file or directory
      10/01 08:33:19,432 INFO [140331219756928] (backend-v4l2.cpp:905) Not a USB video device: Cannot identify '/dev/video1 Last Error: No such file or directory
      10/01 08:33:19,432 ERROR [140331219756928] (librealsense-exception.h:52) Cannot identify '/dev/video2 Last Error: No such file or directory
      10/01 08:33:19,432 INFO [140331219756928] (backend-v4l2.cpp:905) Not a USB video device: Cannot identify '/dev/video2 Last Error: No such file or directory
      10/01 08:33:19,432 ERROR [140331219756928] (librealsense-exception.h:52) Cannot identify '/dev/video3 Last Error: No such file or directory
      10/01 08:33:19,432 INFO [140331219756928] (backend-v4l2.cpp:905) Not a USB video device: Cannot identify '/dev/video3 Last Error: No such file or directory
      10/01 08:33:19,432 ERROR [140331219756928] (librealsense-exception.h:52) Cannot identify '/dev/video4 Last Error: No such file or directory
      10/01 08:33:19,432 INFO [140331219756928] (backend-v4l2.cpp:905) Not a USB video device: Cannot identify '/dev/video4 Last Error: No such file or directory
      10/01 08:33:19,432 ERROR [140331219756928] (librealsense-exception.h:52) Cannot identify '/dev/video5 Last Error: No such file or directory
      10/01 08:33:19,432 INFO [140331219756928] (backend-v4l2.cpp:905) Not a USB video device: Cannot identify '/dev/video5 Last Error: No such file or directory
      有没有办法能更改usb挂载权限
      • 12999190831
        川口那小子
        我的ubuntu22安装docker noetic使用rqt会报
        could not connect to display unix:1
        你的有这个问题吗
        15000457121 H 2 条回复 最后回复 回复 引用 0
        • 15000457121
          MnPt爱学习 @1299919083
          @1299919083 我的没有出现这个问题
          12999190831 1 条回复 最后回复 回复 引用 0
          • 12999190831
            川口那小子 @1500045712
            @1500045712 行吧,谢谢
            • H
              hnyzsuhua @1299919083
              @1299919083 哥们,你解决了吗?我也报这个问题了
              • 12999190831
                川口那小子 @hnyzsuhua
                @hnyzsuhua NVIDIA Setting 里的 PRIME Profiles 改成 (Performance Mode)
