    换源出错
    换源 一键安装 一键安装
    • 17713923201
      不用去猜
      欢迎使用一键更换系统源,本工具由作者小鱼提供
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      RUN Choose Task:[请输入括号内的数字]
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      File "/tmp/fishinstall/install.py", line 90, in <module>
      File "/tmp/fishinstall/install.py", line 83, in main
      File "/tmp/fishinstall/tools/base.py", line 1233, in run_tool_file
      File "/tmp/fishinstall/tools/tool_config_system_source.py", line 162, in run
      self.change_sys_source()
      File "/tmp/fishinstall/tools/tool_config_system_source.py", line 121, in change_sys_source
      PrintUtils.print_delay('检测到当前系统架构为[{}:{}],正在为你更换对应源..'.format(arch,osversion.get_codename()))
      File "/tmp/fishinstall/tools/base.py", line 684, in get_codename
      self.detect_os()
      File "/tmp/fishinstall/tools/base.py", line 644, in detect_os
      tools.base.OsNotDetected: Could not detect OS, tried ['zorin', 'windows', 'nixos', 'clearlinux', 'ubuntu', 'slackware', 'rocky', 'rhel', 'qnx', 'pop', 'osx', 'sailfishos', 'tizen', 'oracle', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'opensuse', 'openembedded', 'neon', 'mx', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora', 'elementary', 'elementary', 'debian', 'cygwin', 'euleros', 'centos', 'manjaro', 'buildroot', 'arch', 'amazon', 'alpine', 'almalinux']
      • 17713923201
        不用去猜
        是在树莓派官方系统上尝试的
          小鱼 技术大佬 @1771392320
          @1771392320 暂不支持这个系统
