    ubuntu18.04一键安装ros+docker有问题
    ·· 一键安装 apt更新失败
    5
    7
    2.7k
    • 15648413631
      雪球
      ubuntu@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
      --2023-03-11 08:38:09-- http://fishros.com/install
      --2023-03-11 08:38:10-- http://fishros.com/install/
      Length: 582 [application/octet-stream]
      Saving to: ‘fishros’
      fishros 100%[========================================================>] 582 --.-KB/s in 0s
      2023-03-11 08:38:10 (47.9 MB/s) - ‘fishros’ saved [582/582]
      Reading package lists... Done
      Building dependency tree
      python3-yaml is already the newest version (3.12-1build2).
      python3-distro is already the newest version (1.0.1-2).
      0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
      --2023-03-11 08:38:11-- http://fishros.com/install/install1s/tools/base.py
      Length: 42195 (41K) [application/octet-stream]
      /tmp/fishinstall/tools/base.py 100%[========================================================>] 41.21K --.-KB/s in 0.05s
      2023-03-11 08:38:11 (864 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [42195/42195]
      [-]Result:success
      基础检查通过...
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:11
      --2023-03-11 08:38:21-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
      Length: 11540 (11K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’
      /tmp/fishinstall/tools/tool_inst 100%[========================================================>] 11.27K --.-KB/s in 0.001s
      2023-03-11 08:38:21 (10.4 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’ saved [11540/11540]
      --2023-03-11 08:38:21-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
      Length: 1366 (1.3K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_vscode.py’
      /tmp/fishinstall/tools/tool_inst 100%[========================================================>] 1.33K --.-KB/s in 0s
      2023-03-11 08:38:21 (101 MB/s) - ‘/tmp/fishinstall/tools/tool_install_vscode.py’ saved [1366/1366]
      --2023-03-11 08:38:21-- http://fishros.com/install/install1s/tools/tool_install_docker.py
      Length: 2882 (2.8K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_docker.py’
      /tmp/fishinstall/tools/tool_inst 100%[========================================================>] 2.81K --.-KB/s in 0s
      2023-03-11 08:38:21 (279 MB/s) - ‘/tmp/fishinstall/tools/tool_install_docker.py’ saved [2882/2882]
      欢迎使用一键安装ROS-Docker版,支持所有版本ROS,本工具由作者小鱼提供
      ================================1.版本选择======================================
      [1]:noetic
      [2]:humble
      [3]:foxy
      [4]:galactic
      [5]:melodic
      [6]:rolling
      [7]:kinetic
      [8]:eloquent
      [9]:dashing
      [10]:crystal
      [11]:bouncy
      [12]:ardent
      [13]:lunar
      [14]:indigo
      [0]:quit
      请输入[]内的数字以选择:5
      你选择了melodic(ROS1),该版本目前状态:长期支持
      ================================2.安装Docker======================================
      Run CMD Task:[docker version]
      [-]Result:code:127
      欢迎使用一键安装Docker,支持amd64和arm64架构系统,本工具由作者alyssa提供
      开始根据系统架构,为你下载对应版本的docker~
      [-]Result:code:100 ified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
      apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', "W: GPG error: https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu bionic InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8\n", "E: The repository 'https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu bionic InRelease' is not signed.\n"]
      =================3.下载镜像(该步骤因网络原因会慢一些,若失败请重试)==================
      Run CMD Task:[sudo docker pull fishros2/ros:melodic-desktop-full ]
      sudo: docker: command not found
      ================================4.生成容器======================================
      请为你的melodic容器取个名字吧!
      • 15648413631
        雪球
        最后由 1564841363 编辑
        sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7EA0A9C3F273FCD8 我已经运行了这个命令
        小鱼小 8 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @1564841363
          @1564841363 运行完之后还报错吗
          15648413631 1 条回复 最后回复 回复 引用 0
          • 15648413631
            雪球 @小鱼
            @小鱼 在 ubuntu18.04一键安装ros+docker有问题 中说:
            我之后运行了几次可以了,麻烦了
            • 11405596301
              借楼,我在一键安装ros+docker也出现了类似的问题,终端打印如下:
              mhd@mhd-Lenovo-ideapad-320C-15IKB:~$ wget http://fishros.com/install -O fishros && . fishros
              --2023-04-11 17:39:58-- http://fishros.com/install
              --2023-04-11 17:39:58-- http://fishros.com/install/
              再次使用存在的到 fishros.com:80 的连接。
              已发出 HTTP 请求,正在等待回应... 200 OK
              正在保存至: “fishros”
              2023-04-11 17:39:58 (24.9 MB/s) - 已保存 “fishros” [582/582])
              [sudo] mhd 的密码:
              正在读取软件包列表... 完成
              正在分析软件包的依赖关系树
              正在读取状态信息... 完成
              下列软件包是自动安装的并且现在不需要了:
              fonts-liberation2 fonts-opensymbol gir1.2-gst-plugins-base-1.0
              gir1.2-gstreamer-1.0 gir1.2-gudev-1.0 gir1.2-udisks-2.0
              grilo-plugins-0.3-base gstreamer1.0-gtk3 libboost-date-time1.65.1
              libboost-filesystem1.65.1 libboost-iostreams1.65.1 libboost-locale1.65.1
              libcdr-0.1-1 libclucene-contribs1v5 libclucene-core1v5 libcmis-0.5-5v5
              libcolamd2 libdazzle-1.0-0 libe-book-0.1-1 libedataserverui-1.2-2 libeot0
              libepubgen-0.1-1 libetonyek-0.1-1 libevent-2.1-6 libexiv2-14
              libfreerdp-client2-2 libfreerdp2-2 libgc1c2 libgee-0.8-2 libgexiv2-2
              libgom-1.0-0 libgpgmepp6 libgpod-common libgpod4 liblangtag-common
              liblangtag1 liblirc-client0 liblua5.3-0 libmediaart-2.0-0 libmspub-0.1-1
              libodfgen-0.1-1 libqqwing2v5 libraw16 librevenge-0.0-0 libsgutils2-2
              libssh-4 libsuitesparseconfig5 libvncclient1 libwinpr2-2 libxapian30
              libxmlsec1 libxmlsec1-nss lp-solve media-player-info python3-mako
              python3-markupsafe syslinux syslinux-common syslinux-legacy
              usb-creator-common
              升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 146 个软件包未被升级。
              --2023-04-11 17:40:04-- http://fishros.com/install/install1s/tools/base.py
              长度: 42195 (41K) [application/octet-stream]
              /tmp/fishinstall/to 100%[===================>] 41.21K --.-KB/s 用时 0.06s
              2023-04-11 17:40:05 (645 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42195/42195])
              [-]Result:success
              基础检查通过...
              ---众多工具,等君来用---
              [6]:一键安装:nodejs
              [7]:一键安装:VsCode开发工具
              [8]:一键安装:Docker
              [77]:测试模式:运行自定义工具测试
              [0]:quit
              请输入[]内的数字以选择:11
              --2023-04-11 17:40:12-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
              长度: 11540 (11K) [application/octet-stream]
              正在保存至: “/tmp/fishinstall/tools/tool_install_ros_with_docker.py”
              /tmp/fishinstall/to 100%[===================>] 11.27K --.-KB/s 用时 0.001s
              2023-04-11 17:40:12 (17.3 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros_with_docker.py” [11540/11540])
              --2023-04-11 17:40:12-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
              长度: 1366 (1.3K) [application/octet-stream]
              正在保存至: “/tmp/fishinstall/tools/tool_install_vscode.py”
              /tmp/fishinstall/to 100%[===================>] 1.33K --.-KB/s 用时 0s
              2023-04-11 17:40:12 (50.2 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_vscode.py” [1366/1366])
              --2023-04-11 17:40:12-- http://fishros.com/install/install1s/tools/tool_install_docker.py
              长度: 2882 (2.8K) [application/octet-stream]
              正在保存至: “/tmp/fishinstall/tools/tool_install_docker.py”
              /tmp/fishinstall/to 100%[===================>] 2.81K --.-KB/s 用时 0s
              2023-04-11 17:40:12 (147 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_docker.py” [2882/2882])
              [1]:noetic
              [2]:humble
              [3]:foxy
              [4]:galactic
              [5]:melodic
              [6]:rolling
              [7]:kinetic
              [8]:eloquent
              [9]:dashing
              [10]:crystal
              [11]:bouncy
              [12]:ardent
              [13]:lunar
              [14]:indigo
              [0]:quit
              请输入[]内的数字以选择:5
              [-]Result:code:127
              [/]获取:7 http://cn.archive.ubuntu.com/ubuntu bionic-backports InRelease [83.3 k[-]Result:code:100 /code stable InRelease
              apt更新失败,后续程序可能会继续尝试...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 仓库 “http://ppa.launchpad.net/tualatrix/ppa/ubuntu bionic Release” 没有 Release 文件。\n']
              sudo: docker:找不到命令
              sudo: docker:找不到命令
              sudo: docker:找不到命令
              请为你的melodic容器取个名字吧!
              请问怎么解决?
              • 16140306171
                狗狗熊
                请问下载镜像时很满(几乎下不动)是什么原因?
                • 8
                  𝓼(´∀`*)𝓽 @1564841363
                  @1564841363 为什么我运行了这个命令
                  Executing: /tmp/apt-key-gpghome.vECC4Aaess/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 7EA0A9C3F273FCD8
                  gpg: key 8D81803C0EBFCD88: 1 duplicate signature removed
                  gpg: 密钥 8D81803C0EBFCD88:“Docker Release (CE deb) docker@docker.com”未改变
                  gpg: 合计被处理的数量:1
                  gpg: 未改变:1
