    关于 ROS2 cartographer建图的问题
    cartographer建图 ros2 建图
    • 1577630951
      /yiw
      看了小鱼的《动手学ROS2》10.5 配置Fishbot进行建图文档,根据里面的步骤新建了文档,编译都能正常完成,也source了,但是运行launch文件的话会出现file 'cartographer.launch.py' was not found in the share directory of package 'fishbot_cartographer' which is at '/home/wu/cmdvel/install/fishbot_cartographer/share/fishbot_cartographer' 是找不到这个文件吗,
      1 如何解决
      2 如果是要读取真实激光fram_id =laser的数据要如何设置,不是gazebo
