    一键安装cartographer报错,编译失败
    cartographer建图 cartographer
    • 20672844072
      2067284407
      RUN Choose Task:[请输入括号内的数字]
      ---众多工具,等君来用---
      [6]:一键安装:nodejs
      [7]:一键安装:VsCode开发工具
      [8]:一键安装:Docker
      [10]:一键安装:微信(可以在Linux上使用的微信)
      [77]:测试模式:运行自定义工具测试
      [0]:quit
      请输入[]内的数字以选择:9
      请输入[]内的数字以选择:9
      --2023-04-30 16:16:15-- http://fishros.com/install/install1s/tools/tool_install_cartographer.py
      Length: 3063 (3.0K) [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_install_cartographer.py’
      /tmp/fishinstall/tools/tool_install_cartographer.p 100%[===============================================================================================================>] 2.99K --.-KB/s in 0s
      2023-04-30 16:16:16 (158 MB/s) - ‘/tmp/fishinstall/tools/tool_install_cartographer.py’ saved [3063/3063]
      --2023-04-30 16:16:16-- http://fishros.com/install/install1s/tools/tool_config_rosdep.py
      Length: 857 [application/octet-stream]
      Saving to: ‘/tmp/fishinstall/tools/tool_config_rosdep.py’
      /tmp/fishinstall/tools/tool_config_rosdep.py 100%[===============================================================================================================>] 857 --.-KB/s in 0s
      2023-04-30 16:16:16 (56.1 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosdep.py’ saved [857/857]
      欢迎使用一键安装Cartographer,本工具由作者众筹提供
      欢迎使用一键编译安装Cartographer,该工具将会以当前目录作为工作区,创建src文件夹并进行cartographer的编译安装
      使用一键安装前,若未安装ROS或出现错误,可以使用一键安装ROS
      检测到您的系统版ROS版本为:noetic
      [-]Result:success --upgradable' to see them.e [4,685 B]
      Run CMD Task:[sudo apt install ninja-build stow git -y]
      [-]Result:success e and 6 not upgraded.nger required:
      Run CMD Task:[mkdir -p cartographer_ws/src]
      [-]Result:success
      Run CMD Task:[git clone https://gitee.com/yuzi99url/cartographer_ros.git]
      [-]Result:success
      Run CMD Task:[git clone https://gitee.com/yuzi99url/cartographer.git]
      [-]Result:success
      欢迎使用模板工程,本工具由作者小鱼提供
      Run CMD Task:[sudo apt install python3-pip -y]
      Run CMD Task:[sudo pip3 install -i https://pypi.tuna.tsinghua.edu.cn/simple rosdepc]
      [-]Result:success in /usr/local/lib/python3.8/dist-packages (from rosdep->rosdepc) (67.7.2)
      Run CMD Task:[sudo rosdepc init]
      [-]Result:success hros.org.cn反馈,最后加入QQ交流群 686914208(入群口令:一键安装)
      Run CMD Task:[sudo rosdepc fix-permissions]
      已为您安装好rosdepc,请使用:
      rosdepc update
      进行测试更新,最后欢迎关注微信公众号《鱼香ROS》
      Run CMD Task:[rosdepc update --include-eol-distros]
      Run CMD Task:[rosdepc install --from-paths src --ignore-src --rosdistro=noetic -y]
      [-]Result:code:1 -----------------------------------
      Run CMD Task:[sudo apt-get remove ros-noetic-abseil-cpp -y]
      [-]Result:code:100
      Run CMD Task:[bash src/cartographer/scripts/install_abseil.sh]
      [-]Result:success kgconfig/absl_utility.pcs.access.pccl.pclper.pc_util.pc.h.h.o.oles.cc.oon.cc.ost_util.cc.oo
      Run CMD Task:[sudo mv /usr/bin/protoc /usr/bin/protoc.bk]
      [-]Result:success
      Run CMD Task:[sudo ln -s /usr/local/bin/protoc /usr/bin/protoc]
      [-]Result:success
      Run CMD Task:[bash src/cartographer/scripts/install_proto3.sh]
      [-]Result:success buf/protobuf-config.cmakeen.cmakeehl.h_msvc.hc.htomic.hoogle/protobuf/compiler/js/js_generator.cc.otor.cc.os.cc.o.o.o.o.oo
      Run CMD Task:[catkin_make_isolated --install --use-ninja]
      [-]Result:code:127
      Run CMD Task:[sudo chmod -R 777 cartographer_ws]
      [-]Result:success
      手动尝试编译后发现原因如下:
      CMake Error at cmake/functions.cmake:36 (add_executable):
      Target
      "cartographer.mapping.internal.3d.scan_matching.rotation_delta_cost_functor_3d_test"
      links to target "CUDA::cudart" but the target was not found. Perhaps a
      find_package() call is missing for an IMPORTED target, or an ALIAS target
      is missing?
      CMakeLists.txt:324 (google_test)
      Target
      links to target "CUDA::cusolver" but the target was not found. Perhaps a
      is missing?
      Target
      links to target "CUDA::cusparse" but the target was not found. Perhaps a
      is missing?
      Target
      "cartographer.mapping.internal.3d.scan_matching.interpolated_grid_test"
      links to target "CUDA::cublas" but the target was not found. Perhaps a
      is missing?
      Target
      is missing?
      Target
      is missing?
      Target
      is missing?
      Target "cartographer.io.probability_grid_points_processor_test" links to
      is missing?
      is missing?
      is missing?
      is missing?
      Target
      "cartographer.mapping.internal.3d.scan_matching.real_time_correlative_scan_matcher_3d_test"
      is missing?
      Target
      is missing?
      Target
      is missing?
      Target
      is missing?
      Target "cartographer.sensor.internal.trajectory_collator_test" links to
      is missing?
      is missing?
      is missing?
      is missing?
      Target
      "cartographer.mapping.internal.3d.scan_matching.precomputation_grid_3d_test"
      is missing?
      Target
      is missing?
      Target
      is missing?
      Target
      is missing?
      Target "cartographer.sensor.compressed_point_cloud_test" links to target
      "CUDA::cublas" but the target was not found. Perhaps a find_package() call
      is missing for an IMPORTED target, or an ALIAS target is missing?
      "CUDA::cudart" but the target was not found. Perhaps a find_package() call
      "CUDA::cusolver" but the target was not found. Perhaps a find_package()
      call is missing for an IMPORTED target, or an ALIAS target is missing?
      "CUDA::cusparse" but the target was not found. Perhaps a find_package()
      CMake Error at cmake/functions.cmake:50 (add_executable):
      Target "cartographer_print_configuration" links to target "CUDA::cublas"
      but the target was not found. Perhaps a find_package() call is missing for
      CMakeLists.txt:208 (google_binary)
      Target "cartographer_print_configuration" links to target "CUDA::cudart"
      Target "cartographer_print_configuration" links to target "CUDA::cusolver"
      Target "cartographer_print_configuration" links to target "CUDA::cusparse"
      Target "cartographer.mapping.internal.connected_components_test" links to
      is missing?
      is missing?
      is missing?
      is missing?
      CMake Error at CMakeLists.txt:187 (add_library):
      Target "cartographer" links to target "CUDA::cublas" but the target was not
      found. Perhaps a find_package() call is missing for an IMPORTED target, or
      Target "cartographer" links to target "CUDA::cudart" but the target was not
      Target "cartographer" links to target "CUDA::cusolver" but the target was
      not found. Perhaps a find_package() call is missing for an IMPORTED
      Target "cartographer" links to target "CUDA::cusparse" but the target was
      感觉像是没有找到CUDA或者是google_test,google_binary,安装后同样报错
      求限于小鱼大大帮忙看下解决
