    求助pointcloud_to_laserscan转换后rviz无法显示问题
    ros2-foxy ros2 rviz2 laserscan出错
    2.5k
    • 3429184983
      C-002
      使用的速腾16线激光雷达,需使用pointcloud_to_laserscan转换为/scan用作cartographer 2D建图测试,但在运行相关节点并订阅/scan消息后,/scan消息有输出,rviz2中按topic添加/LaserScan无可视化输出,请问如何解决?谢谢
      其中转换launch文件pointcloud_to_laserscan.launch.py如下:
          return LaunchDescription([
              Node(
                  package='pointcloud_to_laserscan', executable='pointcloud_to_laserscan_node',
                  remappings=[('cloud_in', 'rslidar_points'),
                              ('scan', 'scan')],
                  parameters=[{
                      'target_frame': 'cloud',
                      'transform_tolerance': 0.01,
                      'min_height': 0.0,
                      'max_height': 1.0,
                      'angle_min': -3.1415926,  # -M_PI/2
                      'angle_max': 3.1415926,  # M_PI/2
                      'angle_increment': 0.0087,  # M_PI/360.0
                      'scan_time': 0.1,
                      'range_min': 0.2,
                      'range_max': 100.0,
                      'use_inf': True,
                      'inf_epsilon': 1.0
                  name='pointcloud_to_laserscan'
      point2scan节点信息如下:
      $ ros2 node info /pointcloud_to_laserscan
        Subscribers:
          /parameter_events: rcl_interfaces/msg/ParameterEvent
        Publishers:
          /rosout: rcl_interfaces/msg/Log
          /scan: sensor_msgs/msg/LaserScan
        Service Servers:
          /pointcloud_to_laserscan/describe_parameters: rcl_interfaces/srv/DescribeParameters
          /pointcloud_to_laserscan/get_parameter_types: rcl_interfaces/srv/GetParameterTypes
          /pointcloud_to_laserscan/get_parameters: rcl_interfaces/srv/GetParameters
          /pointcloud_to_laserscan/list_parameters: rcl_interfaces/srv/ListParameters
          /pointcloud_to_laserscan/set_parameters: rcl_interfaces/srv/SetParameters
          /pointcloud_to_laserscan/set_parameters_atomically: rcl_interfaces/srv/SetParametersAtomically
        Service Clients:
        Action Servers:
        Action Clients:
      雷达节点信息如下:
      $ ros2 node info /rslidar_sdk/rslidar_points_destination_0
        Subscribers:
        Publishers:
          /rslidar_points: sensor_msgs/msg/PointCloud2
        Service Servers:
          /rslidar_sdk/rslidar_points_destination_0/describe_parameters: rcl_interfaces/srv/DescribeParameters
          /rslidar_sdk/rslidar_points_destination_0/get_parameter_types: rcl_interfaces/srv/GetParameterTypes
          /rslidar_sdk/rslidar_points_destination_0/get_parameters: rcl_interfaces/srv/GetParameters
          /rslidar_sdk/rslidar_points_destination_0/list_parameters: rcl_interfaces/srv/ListParameters
          /rslidar_sdk/rslidar_points_destination_0/set_parameters: rcl_interfaces/srv/SetParameters
          /rslidar_sdk/rslidar_points_destination_0/set_parameters_atomically: rcl_interfaces/srv/SetParametersAtomically
        Service Clients:
        Action Servers:
        Action Clients:
      rviz界面如下:
      请提出任何修改意见,谢谢!
      • 3429184983 342918498 将这个主题转为问答主题,在
      • 3429184983
        C-002
        我找到了问题所在,是QoS的问题,特此记录。
        详细信息参考LaserScan showing [0] points from [0] messages GitHub issue/pull request detail
        1 条回复 最后回复 回复 引用 1
        • 3429184983 342918498 将这个主题标记为已解决,在
        • 6547998396
          空山新雨后
          麻烦问一下这个会影响后续用来建图吗,我现在也是pointcloud转laserscan之后,在rviz里调整策略为best effort后可以看到单线激光数据,但是发现用来跑cartographer好像有点问题,不知道是不是和这个有关
          3429184983 1 条回复 最后回复 回复 引用 0
          • 3429184983
            C-002 @654799839
            @654799839 我使用的过程中没有影响后续的cartographer建图和定位,可以在启动cartographer后用rqt_graph看下.
