    树莓派Ubuntu mate 22.04一键安装,换源后更新失败
    一键安装 换源后更新失败
    • 25452524842
      叮叮#
      小鱼:检测当前系统ubuntu22.04:jammy 支持一键安装ROS
      RUN Choose Task:[请输入括号内的数字]
      [1]:更换系统源再继续安装
      [2]:不更换继续安装
      [0]:quit
      请输入[]内的数字以选择:1
      欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
      请选择换源方式,如果不知道选什么请选2
      [1]:仅更换系统源
      [2]:更换系统源并清理第三方源
      [0]:quit
      请输入[]内的数字以选择:2
      [-]Result:success
      删除一个资源文件
      [-]Result:success
      [-]Result:success
      [-]Result:success
      检测到当前系统架构为[arm64:jammy],正在为你更换对应源..
      替换完成,尝试第一次更新....
      [-]Result:success st --upgradable' to see them.ee
      搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
      ['Hit:1 https://mirrors.ustc.edu.cn/ubuntu-ports jammy InRelease', 'Hit:2 https://mirrors.ustc.edu.cn/ubuntu-ports jammy-updates InRelease', 'Hit:3 https://mirrors.ustc.edu.cn/ubuntu-ports jammy-backports InRelease', 'Hit:4 https://mirrors.ustc.edu.cn/ubuntu-ports jammy-security InRelease', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "439 packages can be upgraded. Run 'apt list --upgradable' to see them."]
      镜像修复完成.....
      [-]Result:success guageage - source codeer toolsyfishmentation)slyt source code3 moree-system-lib-on-osx"
      [-]Result:success e and 439 not upgraded.
      [-]Result:success eplacement (dummy transitional package)
      [-]Result:success
      Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo gpg --no-default-keyring --keyring gnupg-ring:/etc/apt/trusted.gpg.d/ros.gpg --import]
      [-]Result:success
      Run CMD Task:[sudo chmod 644 /etc/apt/trusted.gpg.d/ros.gpg]
      [-]Result:success
      [-]Result:success
      根据您的系统,为您推荐安装源为['http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/']
      [-]Result:success st --upgradable' to see them. Packages [1,230 kB]
      [-]Result:success e development metapackageKerberos
      根据您的系统,为您推荐安装源为['https://repo.huaweicloud.com/ros2/ubuntu/']
      [-]Result:success
      [-]Result:success st --upgradable' to see them.es [1,230 kB]
      根据您的系统,为您推荐安装源为['http://packages.ros.org/ros2/ubuntu/']
      [-]Result:success
      [-]Result:success st --upgradable' to see them.,230 kB]
      根据您的系统,为您推荐安装源为['https://packages.ros.org/ros2/ubuntu/']
      [-]Result:success
      [-]Result:code:2
      [-]Result:code:2
