    ros2 创建仿真环境的地图文件打不开
    仿真
    仿真 gazebo
    1.3k
    • 17548456371
      1754845637
      colcon build
      --- stderr: fishbot_description
      /usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
      warnings.warn(
      error: can't copy 'world/fishbot.world': doesn't exist or not a regular file
      Failed <<< fishbot_description [0.98s, exited with code 1]
      Summary: 0 packages finished [1.17s]
      1 package failed: fishbot_description
      1 package had stderr output: fishbot_description
      编译的时候显示world文件不存在,没办法复制,我想手动启动地图gazebo的file里面也没有open的选项,该怎么解决
      distinctyzD 1 条回复 最后回复 回复 引用 0
      • distinctyzD
        yzq15962508857 @1754845637
        @1754845637 你好,请问你解决了吗,我也遇到了相同的问题,可以请教一下吗
        • distinctyzD
          yzq15962508857 @distinctyz
          @distinctyz 没事了,已解决
