    Ubuntu18.04LTS 安装ROSmelodic失败
    一键安装ros1 报错 ubuntu18.04
    2.9k
    • T
      Tonywang20030408
      tony@tony-Alienware-m15-R6:~$ wget http://fishros.com/install -O fishros && . fishros
      --2023-08-01 21:49:44-- http://fishros.com/install
      --2023-08-01 21:49:44-- http://fishros.com/install/
      再次使用存在的到 fishros.com:80 的连接。
      已发出 HTTP 请求,正在等待回应... 200 OK
      正在保存至: “fishros”
      2023-08-01 21:49:44 (267 MB/s) - 已保存 “fishros” [582/582])
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      下列软件包是自动安装的并且现在不需要了:
      gir1.2-goa-1.0 gir1.2-snapd-1
      升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 4 个软件包未被升级。
      --2023-08-01 21:49:44-- http://fishros.com/install/install1s/tools/base.py
      长度: 42293 (41K) [application/octet-stream]
      /tmp/fishinstall/to 100%[===================>] 41.30K --.-KB/s 用时 0.02s
      2023-08-01 21:49:44 (2.37 MB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [42293/42293])
      WARN:No Yaml Module!
      File "/tmp/fishinstall/install.py", line 91, in <module>
      File "/tmp/fishinstall/install.py", line 30, in main
      from tools.base import CmdTask,FileUtils,PrintUtils,ChooseTask
      File "/tmp/fishinstall/tools/base.py", line 775, in <module>
      osversion = GetOsVersion()
      File "/tmp/fishinstall/tools/base.py", line 105, in GetOsVersion
      import distro
      • T
        Tonywang20030408
        看到了之前这个帖子https://fishros.org.cn/forum/topic/385/ubuntu20-04-%E4%B8%80%E9%94%AE%E5%AE%89%E8%A3%85%E5%A4%B1%E8%B4%A5/2?_=1690897114044
        卸载python3-distro之后无法使用pip3 install 再次安装python3-distro
        问题表现:
        tony@tony-Alienware-m15-R6:~$ sudo pip3 install python3-distro
        WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
        Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
        To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
        WARNING: The directory '/home/tony/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
        ERROR: Could not find a version that satisfies the requirement python3-distro (from versions: none)
        ERROR: No matching distribution found for python3-distro
          小鱼 技术大佬 @Tonywang20030408
          @Tonywang20030408
          sudo apt update
          sudo apt install python3-distro
          • T
            Tonywang20030408
            tony@tony-Alienware-m15-R6:~$ sudo apt update
            [sudo] tony 的密码:
            获取:1 file:/var/nv-tensorrt-repo-cuda10.2-trt7.0.0.11-ga-20191216 InRelease
            忽略:1 file:/var/nv-tensorrt-repo-cuda10.2-trt7.0.0.11-ga-20191216 InRelease
            获取:2 file:/var/nv-tensorrt-repo-cuda10.2-trt7.0.0.11-ga-20191216 Release [574 B]
            命中:4 https://mirrors.ustc.edu.cn/ubuntu bionic InRelease
            命中:5 https://mirrors.ustc.edu.cn/ubuntu bionic-proposed InRelease
            命中:6 https://packages.microsoft.com/repos/edge stable InRelease
            命中:7 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic InRelease
            命中:8 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
            正在读取软件包列表... 完成
            正在分析软件包的依赖关系树
            正在读取状态信息... 完成
            所有软件包均为最新。
            tony@tony-Alienware-m15-R6:~$ sudo apt install python3-distro
            正在读取软件包列表... 完成
            正在分析软件包的依赖关系树
            正在读取状态信息... 完成
            gir1.2-goa-1.0 gir1.2-snapd-1 linux-headers-5.4.0-84-generic
            linux-hwe-5.4-headers-5.4.0-84 linux-image-5.4.0-84-generic
            linux-modules-5.4.0-84-generic linux-modules-extra-5.4.0-84-generic
            升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 0 个软件包未被升级。
            T 1 条回复 最后回复 回复 引用 0
            • T
              Tonywang20030408 @Tonywang20030408
              再次运行一键安装,报错还是一样的
              • T
                Tonywang20030408
                现在电脑里有三个版本的python3:3.6、3.8、3.9
                3.6和3.8是ppa源安装的,3.9是源码安装的
                • T
                  Tonywang20030408
                  已经安装了CUDA10.2、cudnn7.6.5、TensorRT7.0.0.11和paddlepaddle,不知道有没有影响
