    Ubuntu16.04-kinetic,rosdep install找不到功能包怎么解决
    一键安装 rosdepc kinetic
      问题原因
      kinetic版本在2021年就已经走到生命的尽头了。
      当你用rosdep update的时候可以看到,kinetic版本的被跳过了。
      mzebra@mzebra:~$ rosdepc update
      欢迎使用国内版rosdep之rosdepc
      我是作者小鱼,更多ROS学习资源请关注公众号鱼香ROS
      小鱼rosdepc开始为您服务---------------
      reading in sources list data from /etc/ros/rosdep/sources.list.d
      Skip end-of-life distro "kinetic"
      Skip end-of-life distro "lunar"
      解决方案
      所以我们要在rosdep update的时候加上一个参数,包含eol的发布版本数据即可。
      rosdepc update  --include-eol-distros
      2098365252 1 条回复 最后回复 回复 引用 0
      • 2098365252
        小不忍则卖大萌 @小鱼
        @小鱼 在docker容器里运行这个系统,python2.7的环境下是不是不可以用一键安装rosdep了,一键安装是python3以上吧,我装完之后rosdepc update
        File "/usr/local/bin/rosdepc", line 7, in <module>
        from rosdepc.rosdepc import main
        File "/usr/local/lib/python3.5/dist-packages/rosdepc/init.py", line 1, in <module>
        from .rosdepc import main
        File "/usr/local/lib/python3.5/dist-packages/rosdepc/rosdepc.py", line 3, in <module>
        import rosdep2
        File "/usr/local/lib/python3.5/dist-packages/rosdep2/init.py", line 45, in <module>
        from .lookup import RosdepDefinition, RosdepView, RosdepLookup,
        File "/usr/local/lib/python3.5/dist-packages/rosdep2/lookup.py", line 41, in <module>
        from .rospkg_loader import RosPkgLoader
        File "/usr/local/lib/python3.5/dist-packages/rosdep2/rospkg_loader.py", line 39, in <module>
        import catkin_pkg.package
        File "/usr/local/lib/python3.5/dist-packages/catkin_pkg/package.py", line 44, in <module>
        from catkin_pkg.condition import evaluate_condition
        File "/usr/local/lib/python3.5/dist-packages/catkin_pkg/condition.py", line 17, in <module>
        import pyparsing as pp
        File "/usr/local/lib/python3.5/dist-packages/pyparsing/init.py", line 100
        major: int
        SyntaxError: invalid syntax
        有这个报错,要怎么解决呢
