    话题订阅代码无法上传到控制板上
    fishbot 资料
    1.4k
    • 3610884843
      C
      • 2.5话题订阅控制LED
        代码编译成功后上传控制板报错,请问哪位大佬知道该如何解决```
        code_text
      Uploading .pio/build/featheresp32/firmware.bin
      esptool.py v4.2.1
      Serial port /dev/ttyUSB0
      Connecting......
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool.py", line 34, in <module>
          esptool._main()
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 1004, in _main
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 646, in main
          esp = esp or get_default_connected_device(
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 895, in get_default_connected_device
          _esp.connect(before, connect_attempts)
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 631, in connect
          last_error = self._connect_attempt(
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 572, in _connect_attempt
          self.sync()
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 435, in sync
          val, _ = self.command(
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 375, in command
          p = self.read()
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 307, in read
          return next(self._slip_reader)
        File "/home/rjh/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 1402, in slip_reader
          read_bytes = port.read(1 if waiting == 0 else waiting)
        File "/home/rjh/.platformio/penv/lib/python3.10/site-packages/serial/serialposix.py", line 595, in read
          raise SerialException(
      serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
      *** [upload] Error 1
      ==================================================== [FAILED] Took 3.47 seconds ====================================================
       *  终端进程“platformio 'run', '--target', 'upload'”已终止,退出代码: 1。
      19046881381 8727875198 2 条回复 最后回复 回复 引用 0
      • 19046881381
        1904688138 @361088484
        @361088484
        应该是串口没连上
        • 8727875198
          肖申克的救鼠 @361088484
          @361088484
          启动agent的时候占用了ttyUSB0
          docker stop 结束进程就可以upload了
