    使用arbotix+rviz控制xacro模型报错未定义joint,但xacro中已经创建
    仿真
    移动机器人仿真 arbotix功能包 urdf
    • 27700108502
      StarrySky浩
      使用版本虚拟机ubuntu20.04noetic
      目的:arbotix功能包,键盘驱动差速小车
      launch文件代码
      <launch>
      	<param name="robot_description" textfile ="$(find mbot_description)/urdf/mbot_body.urdf"/>
          <!-- 设置GUI参数,显示关节控制插件 -->
      	<param name="use_gui" value="ture"/>
          <!-- 运行joint_state_publisher节点,发布机器人的关节状态  -->
      	<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher"/>
      	<!-- 运行robot_state_publisher节点,发布tf  -->
      	<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher"/>
      	<!-- 可选:用于控制关节运动的节点 -->
          <node pkg="joint_state_publisher_gui" type="joint_state_publisher_gui" name="joint_state_publisher_gui" />
          <!-- 运行rviz可视化界面 -->
      	<node name="rviz" pkg="rviz" type="rviz" args="-d $(find mbot_description)/config/mbot_urdf.rviz" required="true"/>
      </launch>
      urdf文件(xacro文件转urdf)代码
      <?xml version="1.0"?>
      <robot name="mbot_body" xmlns:xacro="http://www.ros.org/wiki/xacro">
          <!-- 属性参数 -->
          <xacro:property name="M_PI" value="3.14159"/>
          <xacro:property name="body_length" value="0.5"/>
          <xacro:property name="body_width" value="0.3"/>
          <xacro:property name="body_height" value="0.15"/>
          <xacro:property name="motor_radius" value="0.03"/>
          <xacro:property name="motor_length" value="0.04"/>
          <xacro:property name="wheel_radius" value="0.08"/>
          <xacro:property name="wheel_length" value="0.04"/>
          <!-- 常用颜色定义-->
          <material name = "white">
              <color rgba = "1 1 1 1"/>
          </material>
          <material name = "red">
              <color rgba = "1 0 0 1"/>
          </material>
          <material name = "green">
              <color rgba = "0 1 0 1"/>
          </material>
          <material name = "blue">
              <color rgba = "0 0 1 1"/>
          </material>
          <material name = "black">
              <color rgba = "0 0 0 1"/>
          </material>
          <link name="base_link">
                  <visual>
                      <geometry>
                          <box size="${body_length} ${body_width} ${body_height}"/>
                      </geometry>
                      <origin rpy="0 0 0" xyz="0 0 0.0"/>
                      <material name="blue"/>
                  </visual>
          </link>
          <xacro:macro name="base" params="parent code x_loc y_loc z_loc">
              <joint name="base_${code}_wheel_joint" type="fixed">
                  <origin xyz="${x_loc} ${y_loc} ${z_loc}" rpy="${M_PI/2} 0 0" />
                  <parent link="${parent}"/>
                  <child link="base_${code}_wheel_link" />
                  <axis xyz="0 0 1"/>
              </joint>
              <link name="base_${code}_wheel_link">
                  <!-- 声明对象的质量,转动惯量矩阵-->
                  <!-- <inertial>
                      <mass value="0.001" />
                      <origin xyz="0 0 0" />
                      <inertia ixx="0.0001" ixy="0.0" ixz="0.0"
                               iyy="0.0001" iyz="0.0"
                               izz="0.0001" />
                  </inertial> -->
                  <!-- 声明可视化属性,放置在link标签中-->
                  <visual>
                      <origin xyz=" 0 0 0 " rpy="0 0 0" />    <!-- 声明放置位置以及朝向,放置在visual标签中-->
                      <geometry>                              <!-- 声明形状,放置在visual标签中-->
                          <cylinder length="${wheel_length}" radius="${wheel_radius}"/>
                      </geometry>
                      <material name="black"/>
                  </visual>
                  <!-- 声明碰撞属性-->
                  <!-- <collision>
                      <origin xyz="0.0 0.0 0.0" rpy="0 0 0" />
                      <geometry>
                          <box size="0.01 0.01 0.07" />
                      </geometry>
                  </collision> -->
              </link>
          </xacro:macro>
          <xacro:base parent="base_link" code="l" x_loc="0" y_loc="${body_width/2 + wheel_length/2 + motor_length/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:base parent="base_link" code="r" x_loc="0" y_loc="-${body_width/2 + wheel_length/2 + motor_length/2}" z_loc="-${body_height/2 - motor_radius}"/>
              <!-- <joint name="kinect_joint" type="continuous"> -->
          <joint name="kinect_joint" type="fixed">
              <origin rpy="0 0 0" xyz="${body_length/2-0.02} 0 ${0.035+body_height/2}"/>
              <parent link="base_link"/>
              <child link="kinect_link"/>
              <!--设置关节旋转参考的坐标轴-->
              <!-- <axis xyz="0 0 1"/> -->
          </joint>
          <link name="kinect_link">
              <visual>
                  <origin rpy="0 0 1.5708" xyz="0 0 0"/>
                  <geometry>
                      <mesh filename="package://mbot_description/meshes/kinect.dae"/>
                  </geometry>
              </visual>
          </link>
              <!-- 定义电机的宏 1-左前轮 2-右前轮 3-右后轮 4-左后轮-->
          <xacro:macro name="motor" params="parent number x_loc y_loc z_loc">
              <joint name="motor_${number}_joint" type="fixed">
                  <child link="motor_${number}_link" />
              </joint>
              <link name="motor_${number}_link">
                  <!-- <inertial>
                               izz="0.0001" />
                  </inertial> -->
                  <visual>
                      <origin xyz="0 0 0 " rpy="0 0 0" />    <!-- 声明放置位置以及朝向,放置在visual标签中-->
                          <cylinder length="${motor_length}" radius="${motor_radius}"/>
                      </geometry>
                      <material name="white"/>
                  </visual>
                  <!-- 声明碰撞属性-->
                  <!-- <collision>
                      <geometry>
                      </geometry>
                  </collision> -->
              </link>
          </xacro:macro>
          <!-- 定义车轮的宏 1-左前轮 2-右前轮 3-右后轮 4-左后轮-->
          <xacro:macro name="wheel" params="parent number x_loc y_loc z_loc">
              <joint name="wheel_${number}_joint" type="fixed">
                  <child link="wheel_${number}_link" />
              </joint>
              <link name="wheel_${number}_link">
                  <!-- <inertial>
                               izz="0.0001" />
                  </inertial> -->
                  <visual>
                      </geometry>
                  </visual>
                  <!-- 声明碰撞属性-->
                  <!-- <collision>
                      <geometry>
                      </geometry>
                  </collision> -->
              </link>
          </xacro:macro>
          <xacro:wheel parent="base_link" number="1" x_loc="${body_length/2 - wheel_radius}" y_loc="${body_width/2 + wheel_length/2 + motor_length/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:wheel parent="base_link" number="2" x_loc="${body_length/2 - wheel_radius}" y_loc="-${body_width/2 + wheel_length/2 + motor_length/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:wheel parent="base_link" number="3" x_loc="-${body_length/2 - wheel_radius}" y_loc="-${body_width/2 + wheel_length/2 + motor_length/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:wheel parent="base_link" number="4" x_loc="-${body_length/2 - wheel_radius}" y_loc="${body_width/2 + wheel_length/2 + motor_length/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:motor parent="base_link" number="1" x_loc="${body_length/2 - wheel_radius}" y_loc="${body_width/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:motor parent="base_link" number="2" x_loc="${body_length/2 - wheel_radius}" y_loc="-${body_width/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:motor parent="base_link" number="3" x_loc="-${body_length/2 - wheel_radius}" y_loc="-${body_width/2}" z_loc="-${body_height/2 - motor_radius}"/>
          <xacro:motor parent="base_link" number="4" x_loc="-${body_length/2 - wheel_radius}" y_loc="${body_width/2}" z_loc="-${body_height/2 - motor_radius}"/>
      </robot>
      • 27700108502 2770010850 将这个主题转为问答主题,在
