    Ubuntu 20.04.6安装ros--erro:无法修正错误,因为您要求某些软件包保持现状,就是它们破坏了软件包间的依赖关系。
    ros安装 失败
    1.9k
    • 27196344932
      2719634493
      我明明是按照提示进行安装然而报错
      [前面一切正常]
      【为了节省字数这块也略】
      RUN Choose Task:[请输入括号内的数字]
      [1]:noetic(ROS1)
      [2]:foxy(ROS2)
      [3]:galactic(ROS2)
      [4]:rolling(ROS2)
      [0]:quit
      请输入[]内的数字以选择:1
      请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
      [1]:noetic(ROS1)桌面版
      [2]:noetic(ROS1)基础版(小)
      [0]:quit
      请输入[]内的数字以选择:1
      [\]apt-cacher - Caching proxy server for Debian/Ubuntu/Devuan software repositor[-]apticron-systemd - Simple tool to mail about pending package updates - system[\]aptitude-common - architecture independent files for the aptitude package man[-]aptitude-doc-en - English manual for aptitude, a terminal-based package manag[/]aptitude-doc-es - Spanish manual for aptitude, a terminal-based package manag[\]aptitude-doc-fi - Finnish manual for aptitude, a terminal-based package manag[|]aptitude-doc-fr - French manual for aptitude, a terminal-based package manage[-]aptitude-doc-it - Italian manual for aptitude, a terminal-based package manag[/]aptitude-doc-ja - Japanese manual for aptitude, a terminal-based package mana[|]aptitude-doc-ru - Russian manual for aptitude, a terminal-based package manag[|]gbrainy - brain teaser game and trainer to have fun and to keep your brain tr[/]libcwidget-dev - high-level terminal interface library for C++ (development f[-]Result:success                           end for Debian
      [|]升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 2 个软件包未被[-]Result:success
      Run CMD Task:[sudo apt install   ros-noetic-desktop-full -y]
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      下列信息可能会对解决问题有所帮助:
      下列软件包有未满足的依赖关系:
      [\]                           依赖: ros-noetic-urdf-sim-tutorial 但是它将不会被[-]Result:code:100
      确认了解情况,请输入回车继续安装
      【为了节省字数这块也略】
      是否接受该解决方案?[Y/n/q/?] n
      下列动作将解决这些依赖关系:
             安装 下列软件包:
      1)       flang-7 [20190329-5 (focal)]
      2)       libflang-dev [20190329-5 (focal)]
      3)       libflang0d-7 [20190329-5 (focal)]
      4)       libllvm7 [1:7.0.1-12 (focal)]
      5)       libomp-7-dev [1:7.0.1-12 (focal)]
      6)       libomp5-7 [1:7.0.1-12 (focal)]
             保持 下列软件包于其当前版本:
      【为了节省字数这块也略】
      [\]python3-rosdep2 - rosdep package manager abstraction tool for Robot OS (Pytho[-]Result:success                           anager abstraction tool for ROS
      [-]Result:code:2
      [-]Result:code:2
      • 27196344932
        2719634493
        因为我找了很多种方法,一直没能把这个问题解决,再后来通过咨询我一位学姐,我发现了问题的所在。
        原来是我在装虚拟机Ubuntu的时候,镜像文件和Ubuntu所在的地址不一样。【我把他俩放在了两个盘,这样是不对的,后来我卸载重装,结果就能正常运行了】
        27196344932 1 条回复 最后回复 回复 引用 0
        • 27196344932 2719634493 将这个主题转为问答主题,在
        • 27196344932 2719634493 将这个主题标记为已解决,在
        • 27196344932
          2719634493 @2719634493
          @2719634493 希望我的经历能对大家有点帮助
