    运行roscore命令报错
    求助贴 ros noetic
    1.3k
    • 7341086607
      啦啦啦嘿嘿嘿
      运行roscore命令报错如下:
      File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/init.py", line 347, in main
      p.start()
      File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/parent.py", line 316, in start
      self.runner.launch()
      File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/launch.py", line 676, in launch
      self._setup()
      File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/launch.py", line 651, in _setup
      launched = self._launch_master()
      File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/launch.py", line 413, in _launch_master
      validate_master_launch(m, self.is_core, self.is_rostest)
      File "/opt/ros/noetic/lib/python3/dist-packages/roslaunch/launch.py", line 83, in validate_master_launch
      if not rosgraph.network.is_local_address(m.get_host()):
      File "/opt/ros/noetic/lib/python3/dist-packages/rosgraph/network.py", line 170, in is_local_address
      local_addresses = ['localhost'] + get_local_addresses()
      File "/opt/ros/noetic/lib/python3/dist-packages/rosgraph/network.py", line 212, in get_local_addresses
      import netifaces
      ModuleNotFoundError: No module named 'netifaces'
      然后我又使用pip install netifaces,系统提示Requirement already satisfied: netifaces in /usr/lib/python3/dist-packages (0.10.4)
      请问接下来怎么办?
      • 7341086607
        啦啦啦嘿嘿嘿
        问题已解决,通过重新安装netifaces即可
        pip uninstall netifaces
