    需求:读取bag文件数据,并将数据输出至终端
    小乌龟 ros2 fox rosbag2
    • 27140483962
      彩彩唬唬
      我建立了reader和writer,reader文件写完了#include "rclcpp/rclcpp.hpp"
      #include "geometry_msgs/msg/twist.hpp"
      #include "rosbag2_cpp/writer.hpp"
      class SimpleBagRecorder : public rclcpp::Node
      public:
      SimpleBagRecorder() : Node("simple_bag_recorder_node_cpp")
      RCLCPP_INFO(this->get_logger(), "消息录制对象创建");
          // 1.创建录制对象
          writer_ = std::make_unique<rosbag2_cpp::Writer>();
          rosbag2_cpp::StorageOptions storage_options;
          storage_options.uri = "my_bag"; // 设置文件路径
          writer_->open(storage_options,{});
          // 3.写数据(创建速度订阅方,回调函数中执行写出操作)
          // writer_->write()
          sub_ = this->create_subscription<geometry_msgs::msg::Twist>(
              "turtle1/cmd_vel", 10,
              std::bind(&SimpleBagRecorder::do_write_msg, this, std::placeholders::_1));
      private:
      std::unique_ptr<rosbag2_cpp::Writer> writer_;
      rclcpp::Subscription<rosbag2_storage::SerializedBagMessage>::SharedPtr sub_;
      void do_write_msg(std::shared_ptr<rosbag2_storage::SerializedBagMessage> msg)
          RCLCPP_INFO(this->get_logger(), "数据写出...");
          writer_->write(msg);
          // std::shared_ptr<rclcpp::SerializedMessage> message, // 被写出的消息
          // const std::string & topic_name,                     // 话题名称
          // const std::string & type_name,                      // 消息类型
          // const rclcpp::Time & time);                         // 时间戳
      int main(int argc, char const *argv[])
      rclcpp::init(argc, argv);
      rclcpp::spin(std::make_shared<SimpleBagRecorder>());
      rclcpp::shutdown();
      return 0;
      wirter文件一直在报错
      #include "rosbag2_cpp/reader.hpp"
      #include "rosbag2_cpp/converter.hpp"
      class SimpleBagPlayer : public rclcpp::Node
      public:
      SimpleBagPlayer() : Node("simple_bag_play_node_cpp")
      RCLCPP_INFO(this->get_logger(), "消息回放对象创建");
          // 1.创建回放对象
          reader_ = std::make_unique<rosbag2_cpp::Reader>();
          // 2.设置被读取的文件
          reader_->open(storage_options,{});
          converter_ = std::make_unique<rosbag2_cpp::Converter>("rosbag2_cpp");
          // 3.读消息
          while (reader_->has_next())
              auto msg = reader_->read_next();
              auto twist_msg = converter_->deserialize<geometry_msgs::msg::Twist>(msg);
              RCLCPP_INFO(this->get_logger(), "线速度:%.2f, 角速度:%.2f", twist.linear.x, twist.angular.z);
        RCLCPP_INFO(this->get_logger(), "线速度:%.2f, 角速度:%.2f", twist_msg.linear.x, twist_msg.angular.z);
          // 4.关闭文件
          reader_->close();
      private:
      std::unique_ptr<rosbag2_cpp::Reader> reader_;
      std::unique_ptr<rosbag2_cpp::Converter> converter_;
      std::make_shared<SimpleBagPlayer>();
      rclcpp::shutdown();
      return 0;
      因为我跟的教程是humble版本,但我用的是foxy,一直都没改好
