    安装完ros1测试出现这个
    问题记录 ros1 noetic
    1.8k
    • 32280385233
      32280385233 1 条回复 最后回复 回复 引用 0
      • 32280385233
        ??? @3228038523
        @3228038523 ...
        logging to /home/z666/.ros/log/4c3a67f0-6f44-11ee-830a-4dacb8a79ed8/roslaunch-666-7452.log
        Press Ctrl-C to interrupt
        RLException: Unable to contact my own server at [http://666:44251/].
        This usually means that the network is not configured properly.
        A common cause is that the machine cannot connect to itself. Please check
        for errors by running:
        ping 666
        For more tips, please see
        http://wiki.ros.org/ROS/NetworkSetup
        The traceback for the exception was written to the log file
          小鱼 技术大佬 @3228038523
          @3228038523
          @3228038523 在 安装完ros1测试出现这个 中说:
          ping 666
          检查 .bashrc 配置
          32280385233 2 条回复 最后回复 回复 引用 0
          • 32280385233
            ??? @小鱼
            • 32280385233
              ??? @小鱼
              @小鱼 在 安装完ros1测试出现这个 中说:
              检查 .bashrc 配置
              请问怎么检查啊
              13047078441 1 条回复 最后回复 回复 引用 0
              • 13047078441
                Z @3228038523
                @3228038523 gedit .bashrc
