    无法修正错误,因为您要求某些软件包保持现状,就是它们破坏了软件包间的依赖关系
    一键安装,ros2 失败
    • 8508747438
      北道玄枫岩
      ubuntu20.04安装foxy的ros2失败,尝试了几次了,都是一样的错误,下边是失败的提示:
      Run CMD Task:[sudo apt install ros-foxy-desktop -y]
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      下列信息可能会对解决问题有所帮助:
      下列软件包有未满足的依赖关系:
      ros-foxy-desktop : 依赖: ros-foxy-depthimage-to-laserscan 但是它将不会被安装
      依赖: ros-foxy-image-tools 但是它将不会被安装
      依赖: ros-foxy-intra-process-demo 但是它将不会被安装
      依赖: ros-foxy-pcl-conversions 但是它将不会被安装
      依赖: ros-foxy-rqt-common-plugins 但是它将不会被安装
      依赖: ros-foxy-rviz-default-plugins 但是它将不会被安装
      依赖: ros-foxy-rviz2 但是它将不会被安装
      [-]Result:code:100 是它将不会被安装 它将不会被安装 装
      请注意我,检测你在安装过程中出现依赖问题,请在稍后输入n,再选择y,即可解决(若无法解决,清在稍后手动运行命令: sudo aptitude install ros-foxy-desktop)
      然后我按照操作,先n然后y
      下列动作将解决这些依赖关系:
        保持 下列软件包于其当前版本:
      1.  libcurl4-gnutls-dev [未安装的]
      2.  libgdal-dev [未安装的]
      3.  libgeotiff-dev [未安装的]
      4.  libopencv-calib3d-dev [未安装的]
      5.  libopencv-contrib-dev [未安装的]
      6.  libopencv-dev [未安装的]
      7.  libopencv-features2d-dev [未安装的]
      8.  libopencv-highgui-dev [未安装的]
      9.  libopencv-objdetect-dev [未安装的]
      10. libopencv-stitching-dev [未安装的]
      11. libopencv-videostab-dev [未安装的]
      12. libpcl-dev [未安装的]
      13. libpyside2-dev [未安装的]
      14. libpyside2-py3-5.14 [未安装的]
      15. libqt5designer5 [未安装的]
      16. libqt5designercomponents5 [未安装的]
      17. libqt5help5 [未安装的]
      18. libqt5opengl5 [未安装的]
      19. libqt5opengl5-dev [未安装的]
      20. libqt5positioning5 [未安装的]
      21. libqt5printsupport5 [未安装的]
      22. libqt5qml5 [未安装的]
      23. libqt5quick5 [未安装的]
      24. libqt5quickparticles5 [未安装的]
      25. libqt5quickshapes5 [未安装的]
      26. libqt5quicktest5 [未安装的]
      27. libqt5quickwidgets5 [未安装的]
      28. libqt5sensors5 [未安装的]
      29. libqt5sql5 [未安装的]
      30. libqt5sql5-sqlite [未安装的]
      31. libqt5test5 [未安装的]
      32. libqt5webchannel5 [未安装的]
      33. libqt5webkit5 [未安装的]
      34. libqt5webkit5-dev [未安装的]
      35. libqt5xml5 [未安装的]
      36. libtiff-dev [未安装的]
      37. libvtk7-dev [未安装的]
      38. libvtk7-qt-dev [未安装的]
      39. libwebp-dev [未安装的]
      40. python3-pyqt5 [未安装的]
      41. python3-pyqt5.qtsvg [未安装的]
      42. python3-pyside2.qtcore [未安装的]
      43. python3-pyside2.qtgui [未安装的]
      44. python3-pyside2.qtsvg [未安装的]
      45. python3-pyside2.qtwidgets [未安装的]
      46. qhelpgenerator-qt5 [未安装的]
      47. qt5-assistant [未安装的]
      48. qt5-qmltooling-plugins [未安装的]
      49. qtbase5-dev [未安装的]
      50. qtbase5-dev-tools [未安装的]
      51. qtdeclarative5-dev [未安装的]
      52. qtdeclarative5-dev-tools [未安装的]
      53. qttools5-dev [未安装的]
      54. qttools5-dev-tools [未安装的]
      55. qttools5-private-dev [未安装的]
      56. ros-foxy-cv-bridge [未安装的]
      57. ros-foxy-depthimage-to-laserscan [未安装的]
      58. ros-foxy-desktop [未安装的]
      59. ros-foxy-image-geometry [未安装的]
      60. ros-foxy-image-tools [未安装的]
      61. ros-foxy-intra-process-demo [未安装的]
      62. ros-foxy-pcl-conversions [未安装的]
      63. ros-foxy-python-qt-binding [未安装的]
      64. ros-foxy-qt-dotgraph [未安装的]
      65. ros-foxy-qt-gui [未安装的]
      66. ros-foxy-qt-gui-cpp [未安装的]
      67. ros-foxy-qt-gui-py-common [未安装的]
      68. ros-foxy-rqt-action [未安装的]
      69. ros-foxy-rqt-common-plugins [未安装的]
      70. ros-foxy-rqt-console [未安装的]
      71. ros-foxy-rqt-graph [未安装的]
      72. ros-foxy-rqt-gui [未安装的]
      73. ros-foxy-rqt-gui-cpp [未安装的]
      74. ros-foxy-rqt-gui-py [未安装的]
      75. ros-foxy-rqt-image-view [未安装的]
      76. ros-foxy-rqt-msg [未安装的]
      77. ros-foxy-rqt-plot [未安装的]
      78. ros-foxy-rqt-publisher [未安装的]
      79. ros-foxy-rqt-py-common [未安装的]
      80. ros-foxy-rqt-py-console [未安装的]
      81. ros-foxy-rqt-reconfigure [未安装的]
      82. ros-foxy-rqt-service-caller [未安装的]
      83. ros-foxy-rqt-shell [未安装的]
      84. ros-foxy-rqt-srv [未安装的]
      85. ros-foxy-rqt-top [未安装的]
      86. ros-foxy-rqt-topic [未安装的]
      87. ros-foxy-rviz-common [未安装的]
      88. ros-foxy-rviz-default-plugins [未安装的]
      89. ros-foxy-rviz-rendering [未安装的]
      90. ros-foxy-rviz2 [未安装的]
        保留下列未解决的依赖关系:
      91. qtbase5-dev 推荐 libqt5opengl5-dev (= 5.12.8+dfsg-0ubuntu2.1)
      是否接受该解决方案?[Y/n/q/?] n
        保留下列未解决的依赖关系:
      是否接受该解决方案?[Y/n/q/?] y
      再然后就是提示安装失败了
      Run CMD Task:[sudo apt-cache search python3-colcon-common-extensions ]
      [-]Result:success ackage aggregating colcon-core and common extensions.
      [-]Result:success 卸载 0 个软件包,有 0 个软件包未被升级。
      Run CMD Task:[ls /opt/ros/foxy/setup.bash]
      [-]Result:code:2
      [-]Result:code:2
      求助大佬,能够帮忙看下问题
