    Debain10系统开发板下载ros1 noeteic(基础版),运行roscore,报错。情况:默认python是3.7;已经把ros添加到了系统环境变量中;在/opt/ros/noetic/bin路径下存在rosmaster
    运行roscore rosmaster
    • 31168687513
      学习使我快乐
      root@ATK-DLRK3568-Debian:~#$PATH
      -bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/ros/noetic/bin:/usr/bin/python3.7:/usr/bin/python3.7m:/opt/ros/noetic/bin/rosmaster: 没有那个文件或目录
      root@ATK-DLRK3568-Debian:~# $PYTHONPATH
      root@ATK-DLRK3568-Debian:~# roscore
      File "/opt/ros/noetic/bin/roscore", line 36, in <module>
      from rosmaster.master_api import NUM_WORKERS
      ModuleNotFoundError: No module named 'rosmaster'
      root@ATK-DLRK3568-Debian:~# cd /opt/ros/noetic/bin
      root@ATK-DLRK3568-Debian:/opt/ros/noetic/bin# ls
      catkin_find rosclean roslaunch-logs rosrun
      catkin_init_workspace rosconsole rosmake rosservice
      catkin_make roscore rosmaster rossrv
      catkin_make_isolated roscreate-pkg rosmsg rosstack
      catkin_test_results rosgraph rosmsg-proto rostest
      catkin_topological_order roslaunch rosnode rostopic
      rosbag roslaunch-complete rospack rosunit
      rosboost-cfg roslaunch-deps rosparam roswtf
      • 31168687513
        学习使我快乐
        已经解决了,python中PYTHONPATH变量需要设置一下。
        在开发板上运行roscore之前,还需要运行 source /opt/ros/noetic/setup.bash,否则会提示找不到roslaunch
        • 31168687513 3116868751 将这个主题标记为已解决,在
