    20.04安装16.04的docker,运行小乌龟时报错,请问是什么原因
    一键安装 docker ros
    • 5719500795
      放飞自我
      [ INFO] [1700659514.191845325]: Starting turtlesim with node name /turtlesim
      [ INFO] [1700659514.196146707]: Spawning turtle [turtle1] at x=[5.544445], y=[5.544445], theta=[0.000000]
      libGL error: failed to create dri screen
      libGL error: failed to load driver: nouveau
      libGL error: failed to open drm device: Operation not permitted
      process 315: D-Bus library appears to be incorrectly set up; failed to read machine uuid: UUID file '/etc/machine-id' should contain a hex string of length 32, not length 0, with no other text
      See the manual page for dbus-uuidgen to correct this issue.
      QXcbConnection: XCB error: 2 (BadValue), sequence: 472, resource id: 500, major code: 130 (Unknown), minor code: 3
      QXcbConnection: XCB error: 2 (BadValue), sequence: 473, resource id: 500, major code: 130 (Unknown), minor code: 3
